Microwave Ovens Logo
Posted on Oct 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I purchased a Magic Chef under cabinet microwave from Home Depot on clearance. Got it home and installed when testing all the functions all worked well but the night light function. if you press the light button you will see a quick flash then nothing. I replaced the bulb but still no light.
William Miller
Level 3:
  • Magic Chef Master 9,179 Answers
  • Posted on Oct 11, 2009
William Miller
Magic Chef Master
Level 3:
Answers
9179
Questions
Helped
4478271
Points
21747
Since it's a clearance item, it may not have a warranty.
But you should check with Home Depot on that if you haven't already.
Otherwise, you'd have to have it repaired yourself.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
[email protected]
http://www.microwavedisplay.com
My magic chef microwave locked itself. it wont unlock when i hold down the cancel key. what do i try next?
PDF]microwave oven and keep it for future reference. - Home ...
www.homedepot.com/.../ef8a2fd1-648b-424f-81d1-37...The Home Depot... of insurance loss. Once again, thank you for purchasing a Magic Chef product. .....To Lock/Unlock Control: The microwave oven must be in for 3 seconds until
7helpful
Microwave won't Work
sounds like a fuse for starters, remove outer cover there will be a white cartridge appx 1"longX1/8"dia this is a ceramic fuse avail at most hardware stores in 15 or 20 amp configurations, if this blows again after repl suspect a faulty H.V. Diode/H.V. Capacitor, or the magnetron tube unless while inside unit you see something obviously wrong 2 fuses are under $5.00
1helpful
The light bulb burned out in my Magic Chef microwave oven. I took the burned out bulb to Home Depot to buy a replacement. The manager recommended a different bulb that he said would work. I came home and...
It's possible that it is ruined, but the Home Depot guy should NOT have suggested a different bulb anyway--I would say contact the manager of the Home Depot store that you got the bulb from, and tell them what happened. If you can remember the employee's name, they might be able to help you better. This is something they should be able to compensate you for, because it was THEIR recommendation that may have ruined your microwave, therefore THEY are at fault, and should hold responsibility.
I have an magic chef mvp V microwave and have just put in new cabinets. Do i need to cut an air vent in my cabinets or does it vent through the front?
Consult your installation instructions for that information.
For more help from Magic Chef / Ewave see here or their contact page or order parts here.
You can download owner's manuals for many Magic Chef models here.
Microwave not heating up food
This model is a lower-end type that probably didn't cost very much. Since it's over 2 years old, you have no warranty left. Most appliance repair shops charge extra $$ for servicing installed items in the home. You'd probably be better off purchasing a new comparable model. The labor fee alone might equal what you paid for it.
2answers
MCO160UW goes dead after 3 minutes
I returned the item to Home Depot and they took it back no questions asked.
LAST NIGHT OUR LESS THAN 1 YR OLD MAGIC CHEF MICROWAVE TURNED ON BY ITSELF AND WE TRIED EVERYTHING TO GET IT TO CANCEL INCLUDING UNPLUGGING IT SEVERAL TIMES. IT HAS A MIND OF ITS OWN NOW. MODEL #MC0160UB...
Have you looked on the magic chef recall website? I read about the same problem on the Samsung recall website about microwaves turning themselves on.
13helpful
6answers
Magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Top Magic Chef Microwave Ovens Experts
Jerry Naidoo
NOEL
NOEL
vince
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
