Videocassette stuck in Panasonic NV-G50 VHS VCR; can't eject
How to get a cassette out, if fully in and can't eject?
  • 579 Answers
Generally, you have to take off the cover, and find the motor that drives the cassette loading mechanism, then turn the motor shaft with your fingers (many many times) until the cassette is unloaded.
Usually the moter is easy to get at on top just to the right of the cassette mechanism. However sometimes it is underneath and you can only get at it by taking everything apart. Don't try this yourself and don't take the cassette carraige assembly apart trying to get at the cassette unless you don't plan on using this VCR again.
Posted on Dec 29, 2007
1990 lexus ls400 cassette player will not read or play my cassetes. i put in my cassettes but my front tape flap doesn't close and it automatically switches back to the radio.
The player has to seize the cassette as it is inserted and seat it in the correct position to be played. Sometimes the manual eject linkage becomes defective or misadjusted, preventing the cassette from seating correctly. The eject button may depress fully without causing ejection or it may depress but not cause ejection.
Dec 03, 2013 | Nakamichi 90 94 Lexus Cassette Tape Radio...
Handy cam hi8 dcr
Try removing the battery and charging it. Then put the battery back on the camera. This will reset the cassette system. The cassette should open or close depending upon what status it is in. Once you get the camera to eject fully, clean your heads with a dry head cleaner cassette for Hi8 video. If your camera is still eating tape, could be a broken pin or damaged heads.
Aug 26, 2013 | Sony Handycam DCR-TRV280 Digital Camcorder
Nv-hv60 panasonic gone dead
Its dead...what can't you understand here?
Feb 02, 2013 | Panasonic NV-HV60EB VHS VCR
VHS cassette accepts and ejects with kir..r...r sound. I have removed the power cord (Power OFF) and cassette was inserted halfway and then plugged the power cord (Power ON). At this time the VCR ejects...
First of I think you have a K-Deck mechanism. If you do a Google search for "Panasonic K-Deck" you should find the free information. If you can't you will need to E-Mail me.
This sounds like a a timing problem, perhaps caused by some damage to the Cassette Holder. The mode switch could be part of the problem too. They are quite tricky to set up to get the timing right, I do know the Cassette has to be inside the machine to set it up. The good news is that parts are easy to get hold of, so if any thing is damaged it can be replaced. Curry's partmaster is a good place for parts.
Oct 25, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I have a VCR Panasonic NV - FJ623 and when I insert a video cassette into it for playback or recording purposes,it always ejects the video cassette.Can you help, please?
I'ts likely that the record sensor that pushes on the tab on the tape is bent or broken. Making the VCR think you are trying to record on to a protected tape.
Oct 22, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and...
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and I've also tried it with power supply connected?
Oct 04, 2011 | Sharp VL-Z5 Mini DV Digital Camcorder
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
The vhs cassettes keep being ejected when put in the vhs player
Well the vcr might be broken for the part that allows the tape to sit in there or something is stuck inside of the vcr so it will need to be fixed.
Jun 17, 2010 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I have a Panasonic VHS Playpak and when I try to view any cassette all I hear is sound but can't see any video.. Any suggestions?
You could check that the scart lead is fully in both tv and vcr end.If the screen is snowy then you may need the heads cleaned
Dec 03, 2009 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
How does the vcr release the tape to be ejected?
When in play the tape is pulled out of the cassette & wrapped around a path that takes it across the heads using guide arms.When you press STOP/EJECT. the guide arms move back leaving the tape slack, at the same time a clutch device engages the take up spool & rotates to turn the spool in the cassette & wind the slack tape back into the cassette. When the arms are fully retracted a selector switch has moved into position to activate a motor which turns the mechanism to bring the cassette housing back up to the start position & relaeses the tape. If there is still tape catching the mechanism when you try to eject or some of the tape not fully back inside the cassette, this is most likely because the take up spool is not turning quickly enough to take up the slack tape.
Aug 19, 2009 | Symphonic Televison & Video
Televison & Video Logo
547 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
