I have a Sony KDL46XBR4 LCD that has a problem with the backlight. It is dark on 2/3 of the screen from the middle to the right side. After about 35 minutes the problem goes away.
You are getting the issue on a cold start which means the LCD Panel is bad. It is usually the inverters that cause the issue. They are what light up the panel. This problem was present in many of Sony's LCDs released around the same time as yours.
You can check the voltages to see if the inverter boards are functioning correctly. If Inverters should be replaced. Part numbers: Inverter Left: 1-789-839-11 Inverter Right: 1-789-840-11
If the voltages are fine or the Inverters did not fix the issue, you need to replace the whole LCD panel which is very expensive. The part number depends on the serial number of your TV.
1-802-491-12 for S/N 8,000,001 TO 8,199,199 AND 8,500,001 TO 8,599,999S/N
1-802-491-31 for 8,200,001 TO 8,499,999 AND 8,600,001 AND UP
The inverters list for $93.11 each while the LCD Panel lists for $1400 with a $3100 core charge.
I have a Sony kdl46xbr4 bravia that seems it zoon is oversized. I ca see only the images, but the...
(More)
I have a Sony kdl46xbr4 bravia that seems it zoon is oversized. I ca see only the images, but the printed words of informations on the button or in its sides are hidden. How can I fix this problem?
I have a Sony
KDL46XBR4 LCD . It is dark on 2/3
of the screen from the middle to the right side ...
(More)
I have a Sony
of the screen from the middle to the right side that does not seem to be going away and I'm experiencing ghosting when there is any fast motion on the right side as well. I'm hoping its the right inverter board not the LCD itself. Thanks
