Question about Sony VAIO FX390K Notebook
Help I just got a sony vgn-nr100 I turn it on for the first time and the cord came out. When I turn it back on a message comes on and the computer won't come on. What can I do to get it to come on.
    Sergeant:
  • 239 Answers
What is message that comes on ? We need To know that before I can Help you out. Its 12:30 EST I have to leave in a few hours, So if you can get back May be we can get you up and running, First try making sure everything is plugged in and connections are Tight, Ok now Make sure there are no extras plugged in, Alright Now try and hold down power button for 10 Seconds. I'll be here waiting to here from you. u can mail me to if you want bear350cid at yahoo Thanks and I hope that works for ya.
Posted on Dec 25, 2007
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Please advise how to reset the biose on vgn-s28gp,i try to find reset jumper but i did not find out please help. aqeel.
Not sure which key Sony used but the easiest way to reset the Bios for a laptop is to start teh computer and go straight to Bios and select to restore Default settings. All Bios setups ahve this option. It is normally the F2, Del, F10 or F12 key right after you see the initial splash screen after tuning the computer on. The only other option I can think of without tearing the system open would be to remove the power cord, the main battery and the Bios battery if you have access then put it all back. In some models you can remove teh covers from the hard drive or Ram on the bottom of the computer and get to the Bios battery to remove it. I know a lot of HP models have that so it may be an option with the Vaio.
Jun 16, 2011 | Sony Vaio Vgn-s28gp / Vgn-s380 / Vgn-s380b...
The replacement battery -displays message
Unplug the power cord from the computer and remove the battery. Using a pencil eraser gently clean the contacts on the battery and computer. Check to see that the replacement battery is good.
Jul 17, 2010 | Sony VAIO VGN-NR285E/T Laptop
Wont power up, today.
try doing this
  1. disconnect the ac adapter and the battery
  2. reseat the RAM or memory if you can. if not, its ok
  3. press and hold down the power button for 7-10secs even without the ac adapter and the battery to release static electricity
  4. reconnect ac and battery
  5. try turning it on
Jan 26, 2010 | Sony VAIO VGN-N110G/W Notebook
I have a sony vaio laptop model vgn fs920. when i tried formatting back to original factory using disk it comes up with errors during the downloading??????
What are the error messages/codes? You can get some information from sony's knowledge based system in esupport.sony.com. Just click on FAQ solutions. It will ask you to type the model number of your unit. On the next page, on the right side, you will see
cfaq_search.gif, type the error codes/messages you get then it will tell you what might be causing the issue
hope this helps..
Nov 22, 2009 | Sony VAIO VGN-FS920 Notebook
My computer will not turn on. There is power to
In order to check that, you can try this:
- Remove all power sources
- Remove the battery
- Turn on the computer again with no battery
Please get back for any clarifications.
regards
Sandeep
Oct 19, 2009 | Sony VAIO VGN-FS980 Notebook
Replacement battery in Vaio VGN FE41s wont work
the prob is with battery compatibility with ur laptop.
some times the battery isnt original and it liss some original signs that vaoi detects it and recognize it as orignal and run fine.
try a battery from sony store.
plz rate!
Feb 26, 2009 | Sony VAIO VGN-C140G/B Notebook
Usb device not recognized problem
uninstall driver then turn off the PC then unplug the power cord from power socket, short its legs then leave it unconnected for 5min, then reconnect it to power socket and turn on PC and install driver it should work :)
Dec 29, 2008 | Sony VAIO VGN-SZ110/B Notebook
Sony VAIO FX390K Notebook Logo
29 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
