Question about Dell TrueMobile 2300 Wireless Broadband Router (TM23001)
Truemobil 2300 cannot access internet via wireless
Just got a wireless addapter for my xbox 360 when i rest the router the wireless light comes on for aquick munite and then goes off and wont come back on help please?
  • 556 Answers
Is there a computer or another device connected to this router that can access the internet?
IF yes -- by wire?
IF yes - by wireiess?
The more of the above that is true the less we need to research.
Initially I will assume (until informed otherwise) your router is working both via the wire and wireless to the internet.
IF you have a working wireless computer --
When it was configured did you load an wireless SSID (name)?
Where you required to enter a passpharase, password or network key?
Did you provide any entries to the following fields during configuration for the computer's wireless.
IP Address --------- (like 192.168.1.?)
Subnet Mask -------(often
Default Gateway - (router lan address like
DNS Address ----- (maybe the router lan address or
---------------------------- as supplied by your
-------------------------------- internet service provider)
Being able to answer the above is a requirement for completing the steps outlined below
The generic connection and configuration document
This is a good description of possible router options. These suggest strongly the creation of a static IP address for the XBox to enable all functionality in the online environment, if desired.
If you need assistance setting this up in your environment leave a comment on this problem and I will respond.
Posted on Dec 25, 2007
Hi, I'm trying to set up a TrueMobile 2300 broadband wireless router... It is turned on and both Power and Wireless lights are turned on. I can connect to it from my laptop but it doesn't connect to the...
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
Apr 21, 2011 | Dell TrueMobile 2300 Wireless Router...
My router is on, and is hooked up to my verizon modem. My xbox 360 and my computer are both hooked up to the router and all the lights are on but only my computer is working for the internet where my 360...
with verizon, you need to set the modem to full bridged mode so that the connection from your modem will be opened. This certain firewall is called NAT. Your modem and your router has this feature. To disable NAT on your modem, you need to set it to full bridged mode. To disable the NAT on your router, you need to open ports on your router.
You need to open this port on the router for Xbox live to work
TCP: 80, 3074, 53
UDP: 88, 3074
forward it to the ip of your Xbox.
this should set the NAT on your xbox to open, not moderate.
Sep 18, 2010 | Dell TrueMobile 2300 Wireless Broadband...
I have a Dell Truemobile 2300 wireless router. We have 2 xbox's in our house and we want an Open NAT setting on each (Current NAT setting is moderate) Can this be done? If so, how?
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Aug 23, 2010 | Dell TrueMobile 2300 Wireless Broadband...
How do i clear my port for forward settings? Recently I set up port forwarding for my xbox. However, thru researching im reading that enabling dhcp and dmz is all i need for a the bext xbox live experience
Access the router's built-in web-interface, and access the router's web-page where you "enabled" the port-forwarding. Then, "remove" or "delete" the settings.
Then, access the router's web-page that defines which of your computers/XBOX is to be placed into the 'DMZ' ("De-Militarized-Zone"). Put your XBOX, not your desktop, into the 'DMZ', to allow it "full" access to the Internet, i.e., bypassing the protection of the "firewall" that is inside your router.
Apr 07, 2010 | Dell TrueMobile 2300 Wireless Broadband...
Router not speaking to modem
you need to change dhcp from the modem to the router to be a different network than what your router hands out via dhcp. you will also need to set dns up in the router to forward to the upstream modem.
Jun 03, 2009 | Dell TrueMobile 2300 Wireless Broadband...
How do I set up a password to secure my wireless network??
Enabling the WEP for the Dell TrueMobile 2300 Wireless Router
Click the Start button.
Click All Programs.
Click Internet Explorer.
The Internet Explorer browser window appears.
Type the following in the Address line:
Click the Go button.
You are prompted for a Username and Password.
Type the following as your username:
Type the following as your password:
NOTE: If you previously changed your administrator password in the advanced settings of the router you will need type the password that you set.
Click the OK button.
The Dell TrueMobile Setup Page appears.
Click the Basic Settings tab.
Click the Wireless Security button on the left side of the page.
The Wireless Security window will appear.
For the highest level of security choose the 128 Bit encryption option.
You will have to type a name for your encryption key in the field to the left of the 128 Bit option.
Click the Save and Restart button on the left hand side of the page.
The Save and Restart window appears.
Click the Save and Restart button.
Your settings will be saved to the router.
More Secure
Configure the 2300 Wireless Router for WPA-PSK with TKIP Encryption.
Double-click on Internet Explorer.
The Internet Explorer window appears.
In the Address Bar type my.router or the default IP address
Press the <Enter> key or click Go.
The TrueMobile 2300 password window appears.
Type the User Name and Password.
NOTE: The default user name is admin and the default password is admin.
Click OK.
The TrueMobile 2300 Wireless Router configuration window appears.
Click Basic Settings.
Click Wireless Security in the left-hand pane.
Click to select Enable Wireless Security.
Under Network Authentication, select WPA (Wireless Protected Access) from the drop-down menu.
Input a network key or password in the field to the right of WPA Pre-Shared Key.
NOTE: Your network key or password can use 8 to 64 characters using Hexadecimal digits or 8 to 63 characters using ASCII characters.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | Dell TrueMobile 2300 Wireless Broadband...
Please consult the manual to reset the router to factory defaults this will give you full access to the router and this way you can reset PPPoE, check this out:
Hope that helped!
Dec 10, 2007 | Dell TrueMobile 2300 Wireless Router...
Truemobile 2300 router
You may need to enable the wireless signal within the router settings, but you will have to connect to it via an RJ45 lan cable, as you would of when you first set it up. Type in the routers ip address in your internet browser and get into the routers settings that way.
Mar 24, 2007 | Dell TrueMobile 2300 Wireless Broadband...
Dell TrueMobile 2300 Wireless Broadband Router (TM23001) Logo
117 people viewed this question
Alun Cox
