Question about LG LD40E Dehumidifier
Fan the humidifier is only 1yr old and I lost the manual  I had not cleaned the filter  for a yr and it was very dusty. now because I can't find the manual i'm not sure it us working properly  does it have a fan that should be running constantly?  I hear the motor running but there is not sound of a fan. where is it?   can a new instruction manual be sent to me?
  • 283 Answers
Depending on the ambient temp/humidity and how its set it could definitely run continually. If you don't hear it it's possible the blade is broken or just stuck.
Call 800-243-0000 or go to www.aic.lgservice.com
Posted on Jan 08, 2008
My LG LHD45EL all of a sudden
Short on refrigerant... or a failed compressor. are most likely or a system problem, causing it to trip off.
There may also be a failed electrical component, you need to check for voltage at the compressor.
cheers
Jul 02, 2010 | LG LHD45EL Dehumidifier
How do I access and clean the filter, and how often?
Pull out drain bucket, under lip of bottom front of cabinet (top of bucket area) remove blue tape and slide down filter, rinse or vaccuum off 1/yr.
Manual should be on line, but google full model number (sticker at rear of bucket area)
Jan 04, 2010 | Kenmore 54351 Dehumidifier
How to clean it
check the manual, it will be described there. if you don´t have one, ask here: http://manualfox.com/link/sunbeam.htm
May 19, 2009 | Sunbeam Warm Mist Humidifier Dehumidifier
Kenmore 580-52650100 65 pts./24 hour
Humidifier is fairly old. I put it on the curb for garbage pickup.
Apr 28, 2009 | Dehumidifiers
Soleus CFM40E
http://www.soleusair.com/soleusair/Manuals/Dehumidifiers/CFM-25E_CFM-40E_manual_revised%20_07-24-2007_.pdf
Looks like 1 yr warranty so if a coolant system problem and more than 1 yr old, not worth repairing, but try:
contact@soleusair.com
Jun 26, 2008 | Soleus CFM-40 Dehumidifier
Does not collect water
ok Carmo
first remove the back of the unit and turn it on. it sounds like the fan motor may not be working.there by making the dehum get hot. make sure your filter and coils are cleaned. you may need a new motor. if so buy a new motor and fan blade.be careful with the 5/16th nut holding the fan blade. the blade might look good but you have to check the hole where it rides on the motor shaft. if you into the hole it should look like the letter "D" because the motor shat is shaped that way.---good luck
Nov 11, 2007 | Kenmore 54501 Dehumidifier
Parts
What is the model # from the sticker on the unit? I'll see if I can help.
Nov 03, 2007 | Dehumidifiers
Humidifier Runs but no water collected
Are you talking about a dehumidifier or a humidifier. If you are talking about a dehumidifier, it works by blowing air across a cooling coil causing condensation and the water will drip and pool. The cooling is caused by a compressor working like refrigerator, but using the effect to dehumidify. To check if the cooling coil is working there will be a metal can like in it with tubes in and out. One of the tubes should be warm(input) and the other tube should be cold, if not your compressor is not working. If freezing up, low freon. Check to see if the compressor shuts off very quickly, that would be too much freon. This is not user servicable. Now a humidifier works several different ways. One way is a fan with cloth belts rolling through water using evaporation to humidify. Another way is for a circular fan like on a motor to turn. It has a hollow piece into the water. It picks up water and then through centrifugal force aerates. One way is for a sonic humidifier. All the types have a problem with eventual calcification or mineral build up in the water handling paths. Lime-away or Concentrated Lemon Juice will dissolve this. The lemon juice is the most fun. It will turn your toilet bowl white and also remove rust stains from laundry...
May 01, 2007 | Maytag M7DH65B2A Dehumidifier
LG LD40E Dehumidifier Logo
213 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
