Question about DVD & Blu-Ray Players
0 characters
1 Points
How can I root Oppo Find 7a? Please help.
Yes you can easily oppo find 7a smartphone. This guide will help root your smartphone and install custom recovery like TWRP on it.
How to Root Oppo Find 7 7a and Install TWRP Recovery
Nov 27, 2014 | DVD & Blu-Ray Players
The player won't power off and on. I tryed to play a dvd and it wouldn't load and it is currently stuck in the player as it won't eject the disk. It also smelled like hot wiring
Any kind of 'burning smell' in any electrical appliance is extemely serious, and can be potentially dangerous, depending on the appliance, and its voltage rating. In your case it generally means the power supply has developed a short and its associated protection circuit has also failed, resulting in a high DC output voltage feeding directly across the lower current rails to the motherboard and possibly the rest of the unit.
I doubt this particular player is economically repairable (the cost of parts and labour involved in restoring it to working condition in a service centre would be higher than the retail price of a brand new one; not worth it really since it is not a recorder - there is also a small chance some of the required parts may not be available anywhere), so the only course of action you have is as follows:
You may be able to 'manipulate' the disc tray to get your disc out (this can be done with tools, where you can carefully disassemble and/or remove the DVD deck, then retrieve your disc unharmed - make sure the player is not plugged in when you do this).
The other option is simply to buy a new player - this one is U/S; the extent of the damage to the PSU could be far too severe; and I don't think any workshop would touch it.
Save yourself the financial agony; it is cheaper and easier to buy a new one rather than spend hundreds of dollars in repair costs/modifications to the old one. It is up to you what you do from here. DVD players are great units when they work, but they can be costly burdens when they suffer major breakdowns.
Sad news, but I wouldn't want you to go through this sort of problem with a new player again.
Mar 07, 2011 | Oppo Digital DV-981HD DVD Player
Display is all weird the on/ off is almost a hot pink the open/close light is off
Send the player back to OPPO as they have become aware of this issue. OPPO has a flat $49 repair service for the LIFETIME of the unit after the warrantee period expires. I experienced the exact same issue and it's the main power board. OPPO will provide you with an RMA# when you call them, give them a credit card number for the $49 and then pack the player securely and ship it to them. They pay the return shipping and in about ten days you'll have it back working better than new with new firmware and the latest upgrades as well. You'll have to reset your Region Free settings and all your special parameters but it's a super deal. And they then warranty it for 90 days and if it breaks down at any time in the future again after that, it's still only $49 for another complete fix.
Feb 22, 2011 | Oppo Digital DV-981HD DVD Player
Our Oppo blu-ray player is make a strange noise and sometimes it won't open, close or turn off....we bought it on January 10, 2010 so I assume it's still under warranty. Do you have a suggestion of where...
If it makes a noise when you try to open the drawer, then I would suspect the drawer mechanism is faulty. They are usually belt driven and therefore could be just a new belt needed. Or the mechanism requires oiling . If under guarantee then where did you buy it (send it back).
Nov 08, 2010 | Oppo Digital BDP-83 Blu-Ray Player
Change Change Oppo DV-980H DVD player to play DVD's from all regions.
1. Press Setup.
2. Press "9210" in quick succession. A new window should appear.
3. Press "0" to set the Region to R0.
4. Press Setup to exit.
Dec 12, 2007 | Oppo Digital DV-980H DVD Player
DVD & Blu-Ray Players Logo
51 people viewed this question
Top DVD & Blu-Ray Players Experts
Are you a DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
