Question about KVM Switches
Laptop my laptop has no picture in the LCD. the drivers are not working & only the power is working & battery. can u please help with my problem. the internet was updating this & after that it hanged & i removed the battery to restart again. I noticed that the LCD was black color only & i keep on repeating the operation. Looking forward to solve this problem. Thanks, Philip
    Problem Solver:
  • 9 Answers
Re: laptop
Are you able to view the post ( power on self test ) in the LCD. or you are albe to vies the laptop make log when you poer on.
and check the LED staues of the key board after you powe on the laptop.
This is the basic troubleshoting.
Posted on Dec 27, 2007
  • 79 Answers
Re: laptop
1. Start pressing F8 right after you reboot...
2. Then select Safe Mode from the list of choices..
3. Use System Restore to go back to a date previous to the one you did you upgrade..
Start > All Programs > Accessories > System Tools > System Restore
Best of luck!
Posted on Dec 26, 2007
0 characters
3 Points
My touch pad not working properly
Call Toshiba and talk to experts from the actual company. This should help. :)
Technical Support: 1-800-457-7777
Jan 11, 2008 | KVM Switches
IOgear KVM not working with laptop
First, you have to make sure that the KVM switch is directly connected to your laptop, and NOT to a docking station.
This KVM switch is designed to work with direct connections to the computers.
Second, the light indicator on the KVM switch is not an indicator for power. It's an indicator to see which port is active. If your laptop is connected to port 2, but the focus of the KVM is in port 1, then the port 1 will have a light, not the port 2.
You may also refer to the user manual of the KVM.
Thank you!
May 13, 2010 | IOGear GCS634U KVM Switch
Tripp Lite KVM monitor light doesn't come on anymore .....
The switch may be the problem but it also may be the monitors internal power supply. To check you can open the case by the little switch and remove the plunger ( the little pin that moves up and down) If you get a picture back then the switch is the problem and you will have to bend the flat spring up to give it a little more movement. I would be if the monitor is about 2-3 years old that the problem is in the power supply board. After a few years many LCD monitors have issues with the power boards blowing capacitors. It happens on desktop monitors and rack mount units too. If you have an external power adapter for the monitor check the voltage output and replace if it is not steady. If the power supply is internal to the monitor then you will need to open the case and check the capacitors for heat damage. Check our site at: for pictures of what to look for. Replace any that look like the pictures and you should be back going again. The values that you will need are going to be marked on the sides of the bad caps. Be sure to use a high temp replacement or the problem will be back in a month or two. If yo don't want to do the repair yourself we do offer a repair service of the monitor for $40 plus return shipping. If you have any questions just let me know.
I hope this helps, if so please rate our solution.
Corporate Computer
Sep 22, 2009 | Tripp Lite Lite 16-Port 1U Rackmount...
Starview 4 not working
reset to factory default then do a rescan that will fix it
Dec 21, 2008 | StarView SV211K 2-port KVM...
Causing fatal error when not plug into KVM Switch
dear sir,
her eu have a chek yr kvm switch is connected thru earth.. this becouse some of time eart bypass thru switching yr monitor keyboard and mouses and mosr of time laptop don't face high static electricity.. it's first chance........ other is that yr pc has serious visus problem may be it's face thru Pen drvier or a internet or a some cd's which has infaction before data write in to cd.. so have to cek virus........ one more thing happen if yr pc is connated thru electticity and yr laptop is thru battry that time when u switch yr kvm module it's pass bunch of power so u have to chek all this thing's it's help u...:)
IOGear 2-port KVM Switch
Nov 17, 2008 | IOGear GCS632U 2-port KVM Switch
No cd
well i say go to google type in the driver you need and google will find it rember and put in download driver
Feb 13, 2008 | VIA JKP1158e: 1U Rackmount 15" LCD Monitor...
Lcd problem for laptop
can you operat an function key,
Function key Fn in your key pad hold and press F5,
it will togell the screen,,,,,
Dec 26, 2007 | Belkin F1DL102U 2-port KVM Switch
Laptop lcd
On laptops there is usually a soft switch to change the way video output is routed. The keypad should have an "FN" key on it (blue lettering mostly on the lower left of keyboard). Also look for one of the "F" keys (F1, F2, etc) to have an icon for a screen/blank screen. Hold done the FN while hitting the appropriate F key. The way it normally goes each time you press - laptop LCD only, VGA output, both, off. Sometimes just first 3 or the order may be different. When just VGA enabled or off the laptop screen will be blank.
When using a KVM switch, you must have the VGA ouput enabled from the laptop.
Dec 26, 2007 | Rackmount Keyboard Drawer 1U USB (AG072A)...
No picture on my laptop
Jackboy is right. When did the picture fail on you and what were you doing? Can you see any picture at all even the smallest trace?
Dec 24, 2007 | KVM Switches
KVM Switches Logo
69 people viewed this question
Top KVM Switches Experts
Peter Parker
Peter Parker
Are you a KVM Switch Expert? Answer questions, earn points and help others
