Question about HP ScanJet 2400 Flatbed Scanner
A thread like line on the mirror
A thread like line appear on the mirror of the scanner. Thats why when i am scanning the impression of this thread like lines coming on the scaned file. Plz help me to solve the problem.
Thank u.
A.M
When u r helping me then help me totaly. Tell me how to remove glass to clean back side. thanx.
Posted on Jan 26, 2008
  • 55 Answers
Can u confirm that is it a thread or a scratch like a thread,u better clean the glass from both side n see,if u want any help like how to do that pls let me know
Posted on Jan 25, 2008
  • NITIN  BABBAR
    NITIN BABBAR Jan 28, 2008
    1)first open the top flap,remove it by pulling it up 90 degree
    2) u can find 2 screws,open them
    near the screws there r two groves(where the top flaps hinges fixes,under that groves there r two tiney locks push them little on the back side ,at the same time try to lift the complete glass top in the upward direction,
    3)it will come out first from the back side,then from the front side
    4)clean it properly,with soft cloth,also clean the scanning unit(lamp unit section )with vaccum claener,
    after claening fix it again n check
    do reply softly
    thnx
Straight thin line prints on copies from feeder
When the paper is fed through Automatic Document Feeder (ADF) it is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the Control Panel (scanner top )(by pulling it up from front - the area from where the paper to scan comes out). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning and copying! For example see the below picture: -
Inspect for any tron pieces of paper dirt etc.DONT USE PAPER, CHEMICALS OR ANY ABRASIVE CLOTH as it may damage the parts.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 18, 2011 | HP OfficeJet J4580 All-In-One InkJet...
Black line 1 inch wide right side ,when copies are made and faxing
When the paper is fed through Automatic Document Feeder (ADF) is is scanned before copy or fax. The scanner is fixed type and is located just below the ADF.
Also note that your machine can scan an image only 8.15 inches wide, regardless of how wide the paper is.
CreativeTECH
May 31, 2011 | Brother 5750E Fax
Hi a vertical line is in image scanned please tell me how to solve this problem thanks
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the scanner top (by pullung it near the area where you feed the paper to scan). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning!
Good Luck!
Hope this helps! Dont forget to appreciate the solution!!
CreativeTECH
Feb 14, 2011 | Fujitsu fi-5120C
BLACK LINES APPEAR WHILE SCANNING WITH hp SCANJET
mirrors underneath the glass are dirty or "fogged up" . Remove the glass if possible and clean the mirrors carefully with q-tips.
Dec 25, 2010 | HP ScanJet 2300C Flatbed Scanner
Aficio MP1600 - Black Lines are appearing on all copies. One line appears on the ADF copy but muliple lines if using the scanner. I have tried to clean with a damp cloth everything possible, no good..What...
Try to print from the machine, such as function list or counter list. If no lines, then confirm the ADF scanning mirror dirty. If got lines, the probably came from fuser unit or drum unit.
Jan 20, 2010 | Office Equipment & Supplies
Poor scanned image quality
yes u can repair this try to remove the cover clean up the white tiles which reflect the image, also unscrew it and clean up the mirror and lens
Sep 08, 2008 | Microtek scanmaker 3840
Problem in scanned work
The Reflective Mirror Set in the scanner were subjected to dust. Clean the Mirrors (wipe the Dust with a soft hair 1 inch Brush. Do it under an Expert's Supervision
Dec 02, 2007 | HP ScanJet 3200C Flatbed Scanner
Kodak i260 problem
A line appears if a dust particle on the scanner glass is scanned continuously. Clena the galss with Isopropyl alcohol, dont use any solvent. If the line persists even after this, there could be some sensor problem. If accidentally a paper with a staple pin is inserted, the pin can cause scratch and a line will appear.
S. Mohan
Aug 08, 2007 | Kodak I260 Captiva IA-Express Path-Through...
Black line when scanning or copying
If the line only appears when the scanner is used & not when printing directly from the computer, you are correct in assuming the problem lies in the scanner assy. There should be mirrors attached to the scanner assy which will gather dust and cause copy/scan problems. Remove the glass & clean the mirrors with a DRY cotton cloth. Do not use any cleaning solution on the mirrors as they are sometimes treated & can be ruined if they come in contact with a cleaning solution. Use the dry cloth to wipe off the lens while you have it apart.Also clean both sides of the copy glass while you have it off. Reinstall glass & test.Cleaning the optics solves the problem most of the time. Good Luck!!
Jun 25, 2007 | HP PSC 1610v All-in-One Printer
Epson 1640 SU problem, faint yellow line while scanning
Perhaps this: the scanner calibrates itself on a white strip above the place where the lamp is in rest. When there is a spot on that white strip, the scanner wil use the retreived information for the whole scan, resulting in a line on your scan.
Aug 13, 2006 | Epson Perfection 1640SU Flatbed Scanner
HP ScanJet 2400 Flatbed Scanner Logo
137 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
