Question about Nintendo Wii Console
Hi i have connected up my wii to a samsung wide screen using the yellow red and white cable have got sound and picture but am unable to get colour after trying all combinations do you no how to sort this problem out please
  • pableckie Dec 28, 2007
    u useless prick
  • Fioney Jan 25, 2008
    we have bought wii today and have same problem. It is so frustrating. Going to phone panasonic shop tomorrow and see if they can help. If they do will let you know
Hi I went into Pansonic shop yesterday and problem solved. When you go to av screen and press dvd press green button on remote control and suddenly your wii works in colour. You only need to do this once it resets it and next time you use your wii it will be in colour.
Hope this helps.
Posted on Jan 30, 2008
  • 46 Answers
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Posted on Dec 25, 2007
I,ve connected my wii to the led tv using a wiii component cable(5 leads) but have used only 3 of them red green & blue 1,s leaving a red & white 1 left i have good picture but no sound help please
your cable is split into two different connections for your tv... the red green and blue cables are for HD only. They are their own little set. the yellow cable is your video cable for normal tv's. the red and white cables are sound cables, also for normal tv's. I would unplug the red, green, and blue cables, and use the yellow, red (right sound), and white (left sound).
Dec 31, 2010 | Nintendo Wii Console
Having just installed a new Wii console I have good sound but everything is in fuzzy black and white - no colour at all. What should I do to get colour?
    • With the yellow, white, and red AV cables that came with your system:
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs
      • If this is your first time hooking up the Wii console or have you moved it to another TV, Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
    • With the blue, green, white, and red component cables (sold separately):
      • Review our step-by-step Wii Component Cable connection guide to make sure the cables are properly inserted and that your TV is set to the proper input.
    If you have verified the connection is correct, and are still receiving a blank or black and white screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700
Dec 26, 2010 | Nintendo Wii Console
Why is picture black & white? Sound and picture are good otherwise.
Hi, i bought a wii a few days ago and like everybody else mine too was in black and white with a grainy picture. I have a Panasonic lcd flat screen and thought I had connected it corrected, I got somebody out to have a look at it and found out there are some connections on the side of the TV which I hadn't even noticed before, once I put the red white and yellow leads in these and set the TV to AV3 everything is in perfect colour. Hope this works for some of you.
Take care
Jun 13, 2010 | Nintendo Wii Console
We have sound but no picture on our Wii
Connect a DVD player using red white and yellow to the TV if you get picture and sound, then reconnect the wii red, white, and yellow to the same input.
If only the wii does not show video you will need new red white, and yellow cables. I would try a friends red, white, and yellow cables first even to their TV where their wii is already working.
If new cables are not working you will need to contact Nintendo as there is an issue with your wii. You can't change the wii video to progressive without a component kit, and since you have yellow you obviously don't have a component cable for the wii.
May 15, 2010 | Nintendo Wii Console
Want to use the tv to play the Wii, but when I turn the tv on it only searches for channels, but can't find any. It then says to check cable connection and search for channels again. No channels found. It...
Ok, the Wii connect to the tv thru the Audio/Visual connections, generally at the back, or side of the unit, usually they are Yellow, Red, and White, or Blue, Green & Red. Please ensure you are connected Colour-to-colour, and then on the TV or remote, select one of the Auxillary, A/V inputs.Then you should see the Wii picture on ya TV. That is why you cannot "find" anything on scanning.
Jan 03, 2010 | Quasar VV-2002 20 in. TV/VCR Combo
Nintendo Wii works fine on standard tv but not on hdtv.
FOUND THE PROBLEM !!!!! The problem appears to be the Freeview somehow interfering with the Wii signal. When the aeriel lead is removed the Wii works fine, and the audio/visual signal is great. When the aeriel lead is in I have the problems. I hope this solution proves to be of use to anyone else having similar problems.
Dec 29, 2009 | Nintendo Wii Console
Connection of wii to 37LF2500 tv
The cables you are describing are composite (Red, yellow, white) and most likely you are plugging into a component input (Red, Green, Blue) try looking for another input set, possibly on the front or side of the TV. Make sure to correlate the colors, this should also provide sound for you.
Dec 28, 2009 | Televison & Video
I have video but no sound from the TV
hi there send it back to nintendo the sooner the better here is there phone number for them to collect it and repair
> Nintendo UK
Quadrant
55-57 High Street
Windsor
SL4 1LP
Tel: +44 (0)870 6060247 (Calls charged at National Rate)
Fax: +44 (0)2392 383 444
Registered at
Companies House, Cardiff, (31st January 2001)
Company No. FC022968
Branch No. BR005889
Managing Director
Satoru Shibata
if you need any othere phone number or address ill be happy to post it up for you cheers
Thanks From Me and FixYa
Feb 02, 2009 | Nintendo Wii Console
Wii gone black and white, no colour
I bought a wii a few days ago and like everybody else mine too was in black and white with a grainy picture. I have a Panasonic lcd flat screen and thought I had connected it corrected, I got somebody out to have a look at it and found out there are some connections on the side of the TV which I hadn't even noticed before, once I put the red white and yellow leads in these and set the TV to AV3 everything is in perfect colour. Hope this works for some of you.
Dec 11, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
49 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
