Question about Mach Speed MS945G-GLV Motherboard
I've just ordered a MS945G-GLV motherboard made by Mach Speed. Now I see that there is only one IDE connection on the board. Since I have two DVD/CD drives and 2 harddrives am I in trouble with this board or is it dual channel. Their online manual gives me conflicting info, since it states that you can hook up one master and one slave, for a total of 4 drives.
If anyone is running this board with more than two drives or is familiar with it, I'd appreciate some info.
Thanks in advance
    Problem Solver:
  • 19 Answers
You might try to find a PCI IDE Card. That card should provide support for 2 or 4 drive. SASI (sp?, called sassi or scuzi at times) requires replacing the drives you have with scuzi drives.
Be sure it's a PCI IDE (EIDE) Card.
Posted on Dec 25, 2007
I have intel 915 GLV mother board and 256mb ram, now i want to upgrade my ram to 1GB. please let me knw what kind of RAM i need to buy along with its image details.
Intel Desktop Board D915GLVG - motherboard - micro ATX - LGA775 Socket
Max Supported Memory 4 GB Supported RAM Technology DDR SDRAM Supported RAM Speed 400 MHz, 333 MHz Supported RAM (Registered or Buffered) Unbuffered RAM Features Dual channel memory architecture
Aug 10, 2011 | Intel D915GLVG Motherboard
Sir mercury 945 system board interface with core 2 duo i want to set the bios set up
I am assuming that your question is how to access the bios for your pc. The most common bios entry is to hit the DEL button after switching on. If this does not work, try F2 or F1 buttons after switching on.
Other than these, I am unaware of any other methods for entering the BIOS.
Best wishes,
Dec 21, 2009 | Mach Speed MS945G-GLV Motherboard
It is
Mach Speed V881DAS Motherboard
Sep 30, 2009 | Mach Speed V881DAS Motherboard
Need help, put in new mother board and need help putting in usb connection to front of computer have mach speed motherboard, does anyone have a map for this?
There are probably cables coming from the front of the computer. On the motherboard, you will see 2 or more groups of pins where these cables go. Unfortunately, sometimes the cables don't have a single plug, but have one plug that has 3 holes and then 1 that has one. Many times, too, there are 2 sets. So--let's see if this helps:
The pins will be labled something like USB and then several numbers.
The pins look like this ::::. (hope that shows up OK)
If your usb cable end has one large (3-hole) plug and one small, the large one goes over the first 3 pins from left to right. The one on the left is labeled VCC. The separate plug goes on the 4th pin.
You can use the top row of pins or the bottom. Nothing goes on pin #5 on the bottom.
Does this help? If so, rate it accordingly, please.
Apr 19, 2009 | Mach Speed MS945G-GLV Motherboard
Trying to install wd 160gb sata drive on xp home sp2
i think instead of enabling sata y dont u try enabling IDe
Nov 24, 2008 | Mach Speed (PM9MS) Motherboard
My computer wont start, no setup, no bios, nothing...
This is only a stab in the dark but are all your M/board fixing connected correctly
Hard drive etc.
One other way is to disconnect everything from M/board except for Video and memory and try to boot up if it does then connect hard drive etc one at a time rebooting each time until it will not boot that is the wrongly connected one
Oct 17, 2008 | Mach Speed MS945G-GLV Motherboard
SATA Hard Drives
coonnect your sata connection to hdd and aslo its other side to motherbord it is nesar the ide connector.
Oct 01, 2008 | Mach Speed VENOM V2DP Motherboard
Motherboard not recognizing RAM
Is it exactly 3gig of ram?
You may have 4 sticks in but your onboard peripherals share the memory.
as such my 512mg stick is in but it shows me only 482mg.
Take into account your onboards.
Hope this Helps
Nov 27, 2007 | Mach Speed MS945G-GLV Motherboard
Mach Speed MS945G-GLV Motherboard Logo
63 people viewed this question
Top Mach Speed Computers & Internet Experts
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
