Question about ASUS P4PE Motherboard
Not powering up
I had a p4pe working perfectly. Then my powersupply failed. Bought a new powersupply, and the motherboard worked almost perfectly. The only problem was taht the USB-ports did not work. Everything was ok when I checked the system. Bios was ok, I tried to disable them to make the computer find them during startup. It did, and installed the ports again, but they still didn't work.
I assumed that the power-crash had damaged something, so I managed to get a brand new p4pe. Yes I know it sound strange to buy a new p4pe in 2007, but I thought this would make everything easy and cheap. (i.e. same prosessor, same RAM and so on)
I set up the motherboard in the same matter as the old one, connected all hardware and got a green light. But when I turn it on, hardly anything happens. The fans starts but that is about all. No signal to the screen, I'm not able to open any cd/dvd drives. As you understand, I'm not able to get into BIOS to see if there is something wrong.
I have not tried to remove all hardware yet, I thought this should work easily... Any suggestions will be appreciated.
  • pero_66 Dec 25, 2007
    Ok. Tried to disconnect the lot... Just Ram (one single). But still nothing. Not more than the fans running. Not a beep....
  • najalubar Feb 08, 2009
    'VE SAME PROBLEM, I'VE TRIED BARE BOARD WITH RAM AND CPU & NEW POWERSUPPLY, BUT NO POWER TO MOTHERBOARD. All comonents works with other motherboard. Any Help Please
First test the MB with only the minimal components (ie. cpu + ram + vga card if not onboard). Disconnect all other components. If still not starting, try using just a single ram module, if you have more than one, to try & determine if one of them is faulty.
Posted on Dec 25, 2007
I have the same problem now, My powersupply crashed and I have replaced it and then the usb stopped working, dont have any idea why its happened, I have tried everything, and nothing works, if you have any idea how to fix it please email me at effy8000@gmail.com,
I cant take photos from my camera because of it.
Posted on Jan 01, 2008
TV shuts off after 3 seconds
If the sound is still heard then the inverter board has failed and is triping the powersupply,if no sound the powersupply has failed.
Len..
Mar 29, 2014 | Panasonic VIERA TC-P50U50 50-Inch 1080p...
Tip
I must say that the diagnosis that you do on the first video that the USB...
Have a external Hard drive? Does not power on or the computer does not find it? Do these steps below for your fix.
Folks I am going to demonstrate to you how to save your data on your failed external usb hard drive.
The Videos below will show you how to retrieve the hard drive out of a My book 1TB drive. This method can be used for all external hard drives as there all basically SATA drives.
1. You need a flat head screw driver.
2. You take the drive in your hand and you pry it open around the sides and back there are no screws on this drive.
3. Once you got it open you basically follow the steps below in the video and what you can do is put this hard drive inside of another case or directly into the computer.
The videos are kinda dark but you can basically see and hear what I am doing here folks.
When you follow my video's here you will have a fix as long as the drive is not crashed. Opening the drive up VOIDS the warranty for the drive so please if you have a warranty and care less about the data sent it back to the manufacture.
I hope you find these video's helpful
gps, home theater systems, home theater, tv repair, computer repair, laptop, repair, computer, laptops, home, computers, desktop, pc, parts,printers,refills,printhead,plunger
on Dec 20, 2009 | Computers & Internet
Need to replace button battery on asus p4pe
Hello the manual can be downloaded here:
http://www.asus.com/Motherboards/Intel_Socket_478/P4PEX/#download
Select first your windows system.
Open the manual folder and click on global for download.
Unzip the file and you need adobe reader to read the content.
The cmos battery (C2032) should hold the power for at least 5 years.
The power rating is 3,3 volts.
When the battery power is lost the bios can`t remember the settings
and you have to enter the bios clock settings and etc. everytime you turn on the pc.
The battery looks like this:
This type of battery can be bought almost everywhere.
The battery type is called ( C2032 )
You have to setup the bios settings when you change the battery
and take antistatic precautions when working on the mainboard.
Good luck
Dec 16, 2012 | ASUS P4PE-X Motherboard
DOES p4pe supports sata dvd writer
The ASUS P4PE-BP does not support SATA drives. See the manual link provided;
http://dlsvr02.asus.com/pub/ASUS/mb/sock478/p4b-lx/e1155_p4pe-bp.pdf
You'll need Adobe reader installed to view the manual.
If you bought a SATA writer you can still connect it through an IDE to SATA Serial ATA Splitter Power Cable Connector. See the link below.
http://www.google.com/products?hl=en&source=hp&q=IDE+to+SATA+Serial+ATA+Splitter+Power+Cable+Connector&um=1&ie=UTF-8&ei=8HZJS4r3C8ymlAe0s8wG&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CCIQrQQwAg
Hope you fing this helpfull
Mike
Jan 09, 2010 | ASUS P4PE-BP Motherboard
PC with motherboard foxconn 661fx7mi-s NOT POWER ON, NOTHING
Good day, there are several things that can cause your motherboard to not power on. Most likely your PC is shorted on the casing. You should do. 1. Remove the entire motherboard out of its casing, IDE cable, front panel connectors, USB cables and the powersupply as well. 2. On a table, assemble the motherboard and powersupply. 3. place the memory on the board. 4. connect your monitor and keyboard. 5. power on your PC. do this by shorting power switch jumper on the front panel conncetor. Does your PC turned on? check your power supply fan? any beeps. if still nothing happens this is a serious Motherboard problem. better buy another. hope this helps. feel free to send me updates on your pc. thanks
Jul 21, 2009 | Computers & Internet
Power switch notworking ( ASUS P4PE-X Motherboard)
Please refer your motherboard manual and fix the front panel cable including power button. After this if power button is not working than swap the power button cable and reset button cable.
And then start your PC by pressing the reset button.
Else you just recheck all the cable + RAM + CPU.
Mar 09, 2009 | ASUS P4PE-X Motherboard
I bought a 1GB samsung PC2700 DDR memory for P4PE motherboard. After installed it, the PC could not started. Is that memroy compatible for P4PE?
This page lists the type of ram that is compatible with your system, pay close attention to the voltage.
Take the part number from the stick you're trying to install and punch it into Google to see what the exact specs are.You may find that the voltage is different...
Note: I am not affiliated with the linked vendor it's for illustrative purposes only.
Mar 06, 2009 | ASUS P4PE Motherboard
Starting computer of a new build
it must be ultimately wron in which u connected ur motherboard with the powersupply...
Sep 21, 2008 | Computers & Internet
Drivers for using with vista
http://support.asus.com/download/download.aspx?modelname=P4PE-X&SLanguage=en-us
Asus motherboard, no vista drivers for components listed, however I bet a new installation of Vista would detect proper driver installation
Feb 27, 2008 | ASUS P4PE-X Motherboard
ASUS P4PE Motherboard Logo
120 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
