Question about HP Scanjet 5470c Flatbed Scanner
Solid background tint
My 5470c had been scanning fine a month ago. Recently attempted to scan a snapshot. The entire screen scan, including the faint shadow you can make out as the actual picture, is red!
I did everything I could think of. Even went into the HP problem solve. I checked all plug in connectors. OK I tried the one to shut down computer, unplug power source, wait, reconnect power, restart computer...no luck.
I uninstalled and reinstalled the software. So far nothing. Just a red screen when I scan.
Any solutions here?
  • 4 more comments
  • Anonymous Jan 01, 2008
    Went to scan about a week ago and no power. Replaced power supply and now everything is green. Any ideas?
  • nvgr8n Jan 03, 2008
    Replaced the power supply. Scanner worked fine for a few weeks. Now the scan is totally black. Sounds similar to the red background problem.
  • John10 Jan 05, 2008
    Simular problem... entire scan area is black. No image of scanned object. Was given scanner and original program disk. Power supply (wall wart) was not working but was replaced. Could not 'read' disk on several different computers; simply didnt even 'see' the disk. Of course HP no longer supports this model !! Found driver online which allowed the scanner to function, partially... with the exception that its entire scan was solid black. Same story for copy function...no image... just solid full black scan.
    Any suggestions appreciated..
  • MorePower Mar 17, 2008
    My six year old 5470C scans the first few images from the flatbed correctly, then each successive image gets darker and exhibits distinct miore lines. Based on this, the problem seems to a bulb or another heat sensitive component. I'm looking for info to decide if a repair or replacement is worth the trouble. If not, does anyone know if the sheet feeder, which has its own scanner and works fine, is compatible with any newer flatbed units or will operate alone?
  • happypc Jul 07, 2008
    same problem here ... scan scans like everything is fine ... the computer sees the scan, but unfortunately the scan is all black. Tried many times, to no avail. This has been going on for awhile now and occasically if i kept trying to scan it would eventually work, but this time ... nothing.
  • Anonymous Oct 17, 2008
    Half of the screen is black and the other half white. I too turned mine on to use it and got the black screen instead of the newspaper article I wanted to scan and email. I did the install repair...unplugged the cords, etc. I have many slides and old photos to scan and put on CD's. Does snyone else make a product like this with the lim and negative scanner attachment?
I bought a power supply from ebay paid $22 with shipping thought it was better than getting a new scanner.
Screen is all Green and resolution is 72 no matter what the settings.
I guess it is time for a new scanner.
Posted on Feb 21, 2008
Driver for 5470c scanner will not work with windows 7
Hi ,
Scanjet 5470c does'nt work under W 7 . No drivers available .
Here are a few hints :
1° hint :
Do not connect scanner .
Load XP driver ( yes , XP) , reboot , connect scanner and wait for confirmation of successfull operation .
Reboot .
Dowload and install FreeKapture ( yes , it's free ) from http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Open Freekapture , clic on Scan and select WIA-Hewlett-Packard . Scanjet 4470c works fine in this mode but if you choose HP PrecisionScan Pro , program will hang .
In any case , no slides or negatives scans possible but the rest works .
2° hint :
If you have the W XP install disc , you could install a virtual version of W XP on your HDD ( http://downloads.vmware.com/d/info/desktop_downloads/vmware_player/3_0 ) You could also partition your HDD ( http://www.partitionwizard.com/free-partition-manager.html ) and install W XP on the new one . Regards .
Jan 06, 2011 | HP Scanjet 5470c Flatbed Scanner
HP 5470c scanner leaves lines on the scanned
This is often caused by dirt or dust on the imaging head. This requires taking the unit apart in a CLEAN area and wiping off the head with lens cleaner and a microfiber lens cloth.
Apr 16, 2010 | HP Scanjet 5400c Flatbed Scanner
Will not start up and blue screen pops up with fatal system error
try booting into safe mode
tap the F8 key during boot up and select safe mode,
attempt a scan disk, virus scan (avg works in safe mode)
then reboot, if it works, fine no problem sometimes windows has a hiccup during booting,
otherwise if you have recently installed anything (including drivers) try removing them in safe mode and booting back to normal windows.
if all else fails windows reinsallation may be required
Sep 23, 2009 | Gateway Computers & Internet
Scanning an image only gives a scan 1/4 the size of original...
if u mean the size of image is reduced, as i know, the resolution of image, dpi, is too small --> try bigger dpi
if u mean the image is cut off, u have to clear the scan area or by default
May 07, 2009 | HP Scanjet 5470c Flatbed Scanner
HP Scanjet 5470c xpa negative scanner not lighting up
as my friends answer, the xpa will light up when the software related to scan negative is run
May 02, 2009 | HP Scanjet 5470c Flatbed Scanner
Original hp scanjet 5470c software disc won't work; need new
have u contact hp in u'r region? maybe they have the cd..
Mar 30, 2009 | HP Scanjet 5470c Flatbed Scanner
Dell 1815 dn printer scanner issue: single line appears in scans
Do you get the same line when you use the adf for other purposes?
If so, check the scanner glass just before the platen for something like white-out on it. Clean both the scanner glass and platen glass with Windex.
That is a common problem on all ADF scanners.
Good Luck
Nov 15, 2008 | Dell 1815dn All-In-One Laser Printer
Problem with 5300 scanner
the inner parts may not receive proper power supply thats why you are not able to scan .......
Aug 19, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Icons green tint to them
I'm not sure but I think this model uses an integrated graphics card which would then involve replacing the entire motherboard.
It may be that the screen backlight is getting old - they often age by showing a tint, usually it is pink but I have seen them go greenish.
Try an external monitor connected to the laptop via the VGA d connector. If the picture on the external monitor has a good colour balance then it is probably not a faulty graphics chip, and likely to be the laptop screen.
Mar 16, 2008 | ASUS A6Km Notebook
HP Scanjet 5470c Flatbed Scanner Logo
242 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
