Question about Microsoft Xbox 360 Console
New XBox 360
We just got the XBox 360, we plugged it in and a E74 Error came up. What is that? The 360 will not work. Can you please HELP???? Thanks
Rodriguez Family
  • 29 Answers
E74 is a problem with the A/V cable.  Check to make sure it is connected to the tv correctly.  Unplug all the peripherals (hard drives, coolers (if you have one), controllers etc).  Unplug and reseat the A/V cable into the xbox and try again.  Next try another A/V cable and if that don't work it is a problem with the scaler chip (A/V chip in the 360).  If you just bought it return it to the store for a replacement.
Posted on Jan 12, 2008
What is the error E74 on the Xbox360? what should i do?
My Xbox 360 has a similar E74 error. It can mean a lot of different things, but it's usually a hard drive issue. If you're lucky, that's what it will be for you too. Follow these steps for a possible fix:
  1. With everything plugged in and ready to go, remove the video cable from your Xbox 360.
  2. Turn your Xbox 360 on. It should start flashing red lights indicating that there's a video problem.
  3. Count slowly to 10. After 10 seconds, plug the video cable back in.
  4. Cross your fingers.
If this works, all you should have to do is follow this process every single time you turn your 360 on. It's a bummer, but it happens when parts age. If this doesn't work, try removing your hard drive completely (assuming you can). If that's all that will fix it, you'll need a new Xbox 360 hard drive... this could however still be covered by warranty if you're lucky!
Mar 12, 2011 | Microsoft Xbox 360 Console
How to Repair the Xbox 360 E74 Error
Oh no, it happened, you are the victim of an error on the <b>Xbox 360 E74</b> feared. Well do not worry my friend, in this article I will show you exactly how to <b>fix E74</b> error free shipping on your system in two months.<br /> <br /> The first way to correct this error is very simple, it might just be the AV cable. The first thing you can try is to unplug the AV cable and blow off the dust that could be built up contacts. Then try hooking it back up and turn it on.<br /> <br /> If you still have errors trying to get a new AV cable, or you can borrow one from a friend so you do not buy a new cable, if not the solution either. Once you have the new AV cable, plug it in, turn on your <b>Xbox 360</b>, and if the error is still ongoing, so you must go to the following method to determine the<b> error E74</b>.<br /> <br /> If the AV cable is not working, you have to go to a bit of a more complex method to correct the error. You can still fix, but the methods can be explained in an article.<br /> <br /> You can find the <b>Xbox 360 repair</b> guide on the internet which are very detailed instructions on how to correct the error E74 and other errors, such as freezing, no video problem and the Red Ring of Death. These instructions are usually very detailed step-by-step. Better manuals including pictures and video of the process, so you can be sure you understand every step of the repair.<br />
on Mar 08, 2011 | Video Game Consoles & Games
Xbox360 e74
Oct 17, 2010 | Microsoft Xbox 360 Console
One red light flashing on xbox360,code e74 showing on screen
If you have 1 red light flashing it is normally E74 or some other E error you need to stop the heat.
You can send it in and Microsoft will do it for you or you can repair it yourself using a good guide
Dec 23, 2009 | Microsoft Xbox 360 Console
Xbox360 e74 error code
This problem occurs when the Xbox 360 console experiences a general hardware failure. Contact Xbox live 1-800-4my-xbox
Sep 19, 2009 | Microsoft Xbox 360 Console
Error e74
Try using a new AV lead as that could be at fault.
check the pins inside the AV plug and socket on the back of the xbox 360 console to make sure there are no bent pins.
if all that fails the video controller chip on the PCB will need to be resoldered or replaced, i think microsoft can fix this under their 3 year extended guarantee.
Sep 03, 2008 | Microsoft Xbox 360 Console
Xbox 360
What is the error code at the bottom of the screen & check for flashing red lights on the power button if 3 illuminate it the infamous RROD(Red Ring of Death-google it) which you will get a free repair for if its the bottom right quadrant flashing red then its most probably E74 or E61. E61 is a hard drive related problem so try playing without it, & E74 is the AV cable snapped inside or the GPU/CPU inside the xbox 360 has weak solders on it, I suggest MS support ASAP.
Jul 22, 2008 | Microsoft Xbox 360 Console
Xbox 360 e74
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
Try the cable swap if that works then great buy yourself a new cable and bam your set if that doesnt work then you need to contact MS or use a replacement plan. cuz your GPU is fried.
Dec 27, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
19 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
