Question about Epson Stylus CX6600 All-In-One InkJet Printer
I cant believe....
That i cannot find the plug in where the cord that runs from the computer to the printer plugs in.
If its the Eoson cx6600
then lift up the lid the bit under the scanner so you can see the inside of the printer
the usb connecter is in there on your lefy hand side
geri
Posted on Jan 21, 2008
    Master:
  • 619 Answers
A USB cable are selling in Epson printer distributor.
Posted on Jan 01, 2008
Hp 1050 3 months old, new hp ink cartridge and its not printing .
I am sorry to hear you are having trouble with your new HP printer. Before we do anything - did you remove the tape from the cartridge before you put it into the printer? A common error. Check this now.
The first thing to do is open your 1050 software (control panel/printers) and run a maintenance procedure. Search through the several tabs to get to the maintenance or cleaning cycles. After you perform the cleaning, print a test page. If there is no improvement in the print, go to the next step.
I suggest you delete the printer from your system and reinstall the driver. Here is how: First, go to www.hp.com/suppport (you may have to select a country), find your device listing and download the latest drivers available for the Operating System you are using. Save to your desktop.
Open the Control Panel - find the printer folder - delete the 1050. Turn your computer off, unplug the printer data cord from your computer and unplug the printer power cord from the wall. Turn on your computer. Run the software you downloaded and follow the instructions which will appear on the screen. When you are instructed to plug the printer in ... remember to first plug the power cord in and wait for a minute before you plug in the data cord.
Thank you for your quesiton @ FixYa.com
Feb 15, 2011 | HP DesignJet 1050c plus InkJet Printer
Cant find the cord in my clutter of cords, what does the cord look like that comes with it ?
You want a cable with a Series A plug one end, to plug into your computer, and a Series B on the other, a square plug with 2 edges beveled so it's a D shape for the hard drive.
The cable type is commonly also used for connecting printers.
This site www.accesscomms.com.au/reference/usb.htm has some pictures.
Feb 06, 2011 | Maxtor OneTouch II external hard drive...
Canon i865 printer will not turn on plug ok lead ok no power to on light
If your are sure that you have power at the end of the connector that plugs into you printer and the printer's power switch will not turn the printer on then you either have a bad power switch or other power problem inside the printer - you will have to take the printer to a PC technician to have it repaired.
If there is is no power at the end of the connector that plugs into your printer then you have to replace your power cord.
If you believe that this information was helpful to you please return to the FixYa website and rate this response to your question.
Regards,
Yavacotech
Dec 07, 2010 | Canon i865
I plug my computer in and it will not do anything.it did say that the battery was low. should the device turn on while plugged in even if the battery is low or dead?
yes, you can take the battery out and still run the laptop with the power cord plugged in, if you cant you may have a problem with the cord or plug
Sep 19, 2010 | Computers & Internet
My Lexmark x9350 only turns on and off if I plug and unplug...
This, probably, is a power issue on the printer. Unplug the printer from the computer. Unplug the power supply from the printer (it's the black box behind the printer where the power cord is attached). Try not to use any power strips or extensions for the power cord. If possible, plug the power cord straight to the wall outlet. With the power cord plugged in straight to the power outlet, plug the power supply back in the printer. That should refresh the printer. When everything's powered on, plug printer to computer. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 13, 2010 | Lexmark X9350 All-In-One InkJet Printer
I have brought the printer with me to use in our 5th wheel- I am trying to hook up- I have 2 cords- beige cord for printer to computer- power cord -3 round openings- where do I plug in??? There is an open...
I believe you're missing the power supply for the printer. The 3-prong power cord plugs in to the power supply. If you lost that part of the printer, I can only advise you to call Lexmark. They might be able to send you one.
Apr 05, 2010 | Lexmark X5470 All-In-One InkJet Printer
Cant print. error message wrong cartridge, cant change
try this,
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Mar 24, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Can't connect to computer to do printouts
I believe the cord between printer and computer is an ordinary USB cable, available from lots of places in different lengths, and I suggest you try to get one and see if it does the trick.
Sep 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
Telephone line connection
Two options:
1) Pick up a phone line splitter (Radio Shack or just about any other retailer has them) that has a plug on one side and two jacks on the other. Plug this into the phone jack where the line to your computer is connected. Plug the cord to the computer back into one jack on the splitter and plug the line to the fax machine into the other jack. (If it will physically fit into the space on the back of the computer, you can just plug the splitter into the modem connector, plug the line cord into one jack and the fax cord into the other.)
2) (Useful if the phone jack is behind furniture or just hard to get at.) Get a phone line splitter with all jacks (two on one side, on on the other). Unplug the line cord from the computer and plug it into the single jack on one side of the splitter. Then run a new line cord from one of the two jacks on the other side back to your computer. Plug the cord to the fax machine into the other jack.
Jan 27, 2009 | Dell A940 All-In-One InkJet Printer
Lost cord
hi,
you can try looking at thrift stores, usually they have a "cord wall" or cord bin, that lexmark I believe has the power supply that kind of fits into the back of the printer so it should be easy to spot, but when you look at the power suppliy make sure it says lexmark on it before you buy it,
just an idea
J
Jul 29, 2008 | Lexmark X1240 All-In-One InkJet Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
