Question about Toshiba CX36H60 TV
Broken wires my tv has 3 conection for cable tv wires its a silver box part number is WSA2170-0007R 811YA RSU 133X5 its got 2 big black wires conected to it and 3 little wires yellow red and blue they got ripped off i just need to know where they go on to on one side and one on other just need to know what color goes where
  • mortgagewhiz Nov 30, 2008
    I pulled out my TV and the cable and dvd were stilled hooked up.. ended up with ripped the a small silversame result.... there are 3 small wires that became detached.. red, blue and yellow.. there are 2 larger, black wires still connected.. i need to solder the 3 wires but am not sure where the wires connect.. a better description is the a small silver rectangular box around 3 inches wide, by half and inch thick and 2 inches deep.. many thanks...
  • 36 Answers
Sounds like uve got a component hookup, make sure the box has it too...should be labeled component, if not, and u only see yellow, white, and red, then uve only got composite hook up (AV) and u cant hook up all 3 cords to it. If it was working before... It was rigged in a way to make it work, I'd have to kno the brand of the TV, as well as the model that you've provided.
Posted on Jan 08, 2008
Airhandler- the themostat is on auto/I understand cool,heat.emerg heat,The (G) terminal-then why heat mode or,emer heat fan blows?Only when i switch to cool mode the handler still want start up blowing...
the fan fill come on with the sequencer (stack switch you call it) it will also come on with the fan relay. on some goodmans the fan relay is the black box on the circuit board. use a jumper to jump red to green, this should bring the fan on sounds like you could have a broken green wire, try using a different wire instead of green
Sep 12, 2013 | Goodman Heating & Cooling
How to conect recever for tv tuner card
Check signal strength from receiver(set-top box)? Or call cable company?
Feb 09, 2012 | Televison & Video
The replacement switch has 4 wire ports marked L,1,2,3. The fan has a black wire (power) and 3 other wires from a plastic capacitor box, 1 green and 2 brown. How do the wired connect to the switch?
dear sir
try to find out first all wire wich type of you shold use ampere meter for testing thise wire .
ampere meter turn into continuty mode and conecect its one lead (wire cable) to your motors black wire and watch the display what is rating there .and write it next wire check and date write like this way check your all 4 wire and now who is high number data its conect to number 1 after that some low conecet number to switch number 2 after that who is lowest conect to number 3 and that black colour wire conect to the L mark then try to start your motor
hope answer the question
thank you
Jul 09, 2010 | Westinghouse Electric Westinghouse...
Sound problems
May 13, 2009 | Sony Playstation 3 (PS3) Console
Your HDTV does not support HDCP
This is normal in HD 4250.Problem is ( box software).You need to disconnect HDMI cable from the box,or leave TV "ON" during recording.
Apr 04, 2009 | Sony Playstation 3 (PS3) Console
I bought a C80 Raymarine Plotter this has a NMEA pigtail with Brown, Screen, Yellow, Green And White wires I haave also bought a RS 125 Receiver this has a pigtail lead with Red , Green, Yellow, Brown and...
If you have a Raymarine pilot it makes sence to wire it all up to Seatalk. Wire as follows Red to red , silver to silver, yellow to yellow, brown(on rs125) to silver on seatalk buss Green (on rs125) to red on seatalk buss.The above is for the conection between RS125 and C80.
To hook the pilot to system you just need to hook the seatalk lines (red, yellow,silver) from the pilot to the conection with the RS125 and the seatalk cable to the C80.(Color for color).The sea talk connection for your pilot can be picked up from you course computer they are labeld and colored on the unit.
If you are not running a course computer as in the case with the older wheel and tiller pilots you will need to take a sea talk cable and cut it. Once it is cut you will see the red yellow and silver wires and you can tap into there . Remember to connect the cable back together were you cut it. Hope this helps
Dec 15, 2008 | Raymarine C80 GPS Receiver
Toshiba tv 32ax60 3 thin wires disconnected
belive your referring to rf converter assembly. entire unit can be replaced  or if threaded end pulled out can be repaired. dont understand 3 wires unless worked on previously. avg shop prob min bench to repair. .
Dec 02, 2008 | Toshiba CX36H60 TV
Conecting DVD/VCP to tv through DIRECT SAT. BOX
You will need what is called an RF modulator. What this device does is to take the place of the internal mod that Used to be included on old VCR/DVDs....accordianman
Feb 26, 2008 | Televison & Video
Help with ceiling fan
black with black is for fan motor from swith red with red is for light fan from switch blue goes conect to black thats power for the remote white wuth white thats streat line is call comun or negative green withe green that streat conection for ground protection
Dec 26, 2007 | Hampton Bay 46175 Cameron II Plus Ceiling...
The picture has a double image.
All conections to the set need to be check very carefully starting form the cable to comes into the cable box from the outside and the cable that goes from the box to the tv,eliminate the cable box and conect the wire from outside direct in the tv and and see how it looks bring a small portable and conect the cable to it to see how it looks,once all the possibilities have eliminated then consider a problem inside the tv in the tuner area starting at the very conector where the cable conects.All this can help if the double image is not related to misaligned convergence.
Oct 01, 2006 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
60 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
