Question about Toshiba 20AF44 20" TV
Toshiba mo# 20AF44/xbox360 ISSUE
When I try to set my xbox 360 to the HDTV mode that I believe is supported by this tv all I get is a garbled pic with lines in various colors. Any suggestions? Additionally, when I watch movies from my computer on a different input (s-video) the pic is fine but I get a horizontal line across the screen. I believe it has to do with the refresh rate and the H-hold. Problem is I don't have the original remote or the manual this tele was a gift. Suggestions for correcting the prob?
    Genius:
  • 1,694 Answers
Just because a TV has RGB component inputs does not mean
HI-Def will work......Component range = 480 to 720 to 1080....
You can download owners manual off web..Toshiba.com..
click on HDTV then click customer support....owners manual.
............................................................................T.
Posted on Dec 25, 2007
Hi, I've had my xbox 360 elite console for
might want to check the cable, if you are not getting light from the xbox360 most likely you have changed something on the TV. make sure its on the right setting
HDMI device has to be on first in some cases.
make sure the plug is good and well connected.
restart the xbox360 and try again.
try the xbox on another hdmi device to see if it working.
or try the regular mode of the xbox.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
May 26, 2010 | Microsoft Xbox 360 Elite Console
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
What is the universal remote control code number?
Try this link:
http://support.xbox.com/support/en/us/xbox360/hardware/accessories/ media/universalmediaremote.aspx
If you follow these instructions, you should be able to program the remote to your tv. Good luck! Sincerely, Der Strom
May 05, 2010 | Polaroid FXX-321C 32 in. HDTV LCD TV...
Not supported mode
The 360's video output source is automatically detected by the system. Ps3 has a reset sequence you have to use when you switch from one outpot cable to another, but the 360 doesn't have this. If you're able to see your dashboard then you are good to go and do not need to change any features.
Sep 14, 2009 | Microsoft Xbox 360 Console
Toshiba mo#20af44 hooking up 360 xbox
As far as I'm aware, the only way to switch inputs on the TV is by using the Toshiba remote--there aren't buttons on the TV itself to do it. Which means unfortunately, if nothing on your universal remote will do so and you don't have the Toshiba remote (either to use or to reprogram your universal remote with), you may be out of luck.
Oct 11, 2008 | Toshiba 20AF44 20" TV
Xbox 360
make sure the TV in the correct mode, VIDEO, COMPONENTS.
if it was working before. a button might have been pushed by accident.
also your xbox360 may have died, you can try it on another TV to be sure, even though the lights come on doesnt mean the xbox360 is working.
Jun 16, 2008 | Microsoft Xbox 360 Console
My xbox360 Wont work on my WS-55513 MITSUBISHI COMPONENT
Try changing the settings on the Xbox under display to 1080i. If it is 1080 p, or 720p, the image will look funny so make sure it is at 1080i.
Your welcome
Your friend from down the lane!
May 21, 2008 | Mitsubishi WS-55513 55" Rear Projection...
360 video problem on HDTV
I need a little bit more info on the TV its an RCA what?,
In the mean time what you could try is finding someone with a HD tv and trying it out at there house so that you can single out if it is your system or the TV. This will help alot you can also try someone else's xbox 360 at your house on your tv to see if it is your AV cable / xbox360.
Dec 31, 2007 | Microsoft Xbox 360 Console
Video problems
I would check to see if the AV cord you have is set to HDTV or reg TV if you dont have a HDTV then your setting needs to be on TV.
Trying to use the HDTV will give you this issue where you here sound but no video.
The setting is on the neck where you plug it into the xbox360.
Nov 30, 2007 | Microsoft Xbox 360 Console
Samsung 40 inch lcd mode not supported
i have the same problem as well
wtf?
i used mine for ages then suddenly last night i looked all cell shaded and swirly so i left it over night. i turn it on this morning and get mode not supported. i thought it was my xbox but now i know it is the tv. thanks for at least that much. someone please help
Aug 17, 2007 | Samsung LN-S2651D 26 in. LCD Television
Toshiba 20AF44 20" TV Logo
168 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
