Question about Dell Inspiron B130 Notebook
No power I have zero power to my laptop and the battery is new and the power cord is new I might add that where u plug the power cord into the back of the laptop it feels like it is loose. How do I fix that can it be welded or do I have to replace something. This is a dell B130
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
A broken power pin is quite common on laptop computers. The pin gets damaged from plugging and unplugging the cord plus all the daily tugs and pulls on the cord. The cumulative damage breaks the connection from the power pin connector to the motherboard.
If you are mechanically inclined the repair can be made pretty easily. The pin usually runs anywhere from $5 - $15. It's the labor at a shop that is expensive ($99 - $250 or more).
Once you get the system repaired get a Cable Retention device and use it religiously so the problem doesn't reoccur.
Here's a video about the problem and the JerkStopper AC Cable Retention kit.
Posted on Aug 26, 2008
First off from what you have described it sounds like the power cord connection to the board is loose, and if that being the case yes it will have to be soldered back securely to the board.
Do this plug in the battery cable and move it back and forth see if the computer comes on if it does then you know that is where the problem lies.
If not then you will have to either open up the computer yourself or have a Technician open it and resolder that loose connection and then go from there, its still possible that there still more problems. but as long as you didn't drop the unit then maybe that's all there is that's wrong with it.
I would have someone who's good at repairing Electronics look at it for me if you have no idea what your doing, because if you knock one of those surface mount ic's loose then your screwed because they are extremely small and a pain to resolder with the naked eye.
Posted on Dec 25, 2007
My Asus laptop model K52J battery icon is blinking Red, whether the power cord is plugged in or not. I always had my power cord plugged into my laptop day and night and never plugged it from the socket....
It sounds like you're battery has died, has you've possibly over charged it. You will find new battery's online cheaper than actually going to some sort of shop. Just simply type in the model name on google and add battery. :) Hope this helps
Oct 12, 2013 | ASUS K52F-BBR9 Notebook
My battery light is off.
The battery might be dead. Batteries only have a useful life and after that they have to be replaced.
Does your laptop work ok off the AC Adapter Power Cord? If so, your battery is dead and your power cord is good. If the laptop does not work off the Power Cord then either your Power Cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. In either case a good battery will not charge if the power cord or the DC Jack is bad.
Check your DC Power Jack which is where the power cord plugs into the compute. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Toshiba Satellite A105 Notebook
Battery won't charge
So put the old power cord back on since you say it charged the battery normally. Why did you change it if it was charging the battery? It's quite possible that the new power cord is faulty. Just because it is new does not mean it works.
Remove the battery and plug the new power cord in. Does it boot the laptop up? Are you able to function with the new power cord plugged in. If so, then your battery is more than likely dead and needs to be replaced. The battery only has a useful life and once it is completely bad it will not charge.
May 01, 2012 | Dell Inspiron 1545 Notebook
Can you help me to reset the BIOS password for your Toshiba laptop Toshiba Satellite A105-S4384 .
take out battery,unplug power cord while plugging back in hold down the zero key & power ,go 45 seconds, go into setup load bios default then save
Jan 19, 2011 | Toshiba Satellite A105-S4384 Notebook
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
My compaq laptop will not turn on. With the power cord plugged in the power port light is on but nothing else happens. None of the display lights light up and nothing appears on the screen. Only the power...
if u know repairing laptop ,u just open the back case of that and remove full outlet & see where the screen display chip is attached to the motherboard,if u see that u just remove the screws and clean it, afterwords add some heat sink compound to that and attach with screws,this is the best best solution & do it carefully
Oct 21, 2009 | Computers & Internet
Son ran battery to zero after he broke power cord, now won't boot
Couple of things
First is to let it charge with the lid down for a few hours.
If that does not fix it then check that your son did not use the alternate display option FN F5 or FN F6 on the acers I think
If you still have no luck you might want to ask questions of your son before you take it to a repair shop
Aug 08, 2009 | Acer Aspire One PC Notebook
Problem with battery or power cord?
it could be a short in the power cord or a lose dc jack in the back. what model acer is this for as power packs for them dont cost to bad.
Nov 29, 2008 | Acer (56.04145.901) (5604145901) Power...
Hp compaq 6910p BIOS Bypass
I removed the keyboard, unplugged the bios battery, holded down the power button about 30 secs, plugged back the bios battery, assembled the computer, didn't plug the battery and instead of that just plugged the ac adaptor and the bios passwd was gone =)
Oct 29, 2008 | HP Compaq Business Notebook 6910p - Core 2...
Dell Inspiron B130 Notebook Logo
159 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
