Question about Furuno GP-1850WD GPS Receiver
Chart @ track control
The track control on my old 1650 was in the soft keys to turn it off and on now I bought a1850 and the track control is in the meneu is there any way I can get it in the soft key because I use it for circle netting. Also the old chart showed more detail I believe it was a navnoic chip and now I have a c-map. Does the furuno by any chance have the tide tables like northstar
2 Suggested Answers
Maanita
  • 1142 Answers
SOURCE: Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Posted on Sep 02, 2008
Can't turn the Air Con. All other buttons on the remote work but the Blue Power button doesn't. I checked it with my Digital Camera and the power button is the only one that won't flash
The carbon track on the remote could have weakened due to heavy use or pressure. Slowly remove this unit clean with a soft dry cloth and check the traacks , if the tracks are fine check on the carbon on the inside of the pads, You can replace with any old pads from old remote or calculator or even you could get to buy these carbondots. Try out an reply
Jun 29, 2010 | Hitachi HL01891 Remote Control
I bought a stereo from a friend who is selling their car and the pass code is missing and i am trying to find the pass code for a kenwood kbc mp7028.
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Mar 20, 2008 | Audio Players & Recorders
I bought a lovely old 1995 BMW soft top but it only came with one key. I got another one cut locally and it opens the doors but when i put it in the ignition it does not start the car
will it turn the ignition? if not the key is cut wrong. If it turns the ignition and the engine will not crank you probably have some type of anti theft system that requires a special key to make it work.
Mar 11, 2010 | 1995 BMW 3 Series
Hi we just bought a used truck with a kenwood KDC-MP4028 cd player. After unplugging the battery we cant seem to unlock the security code.... Im going crazy with out my music, Help!
push buttom "track up" for 3 seconds
Oct 18, 2009 | Kenwood KDC-MP4028 CD Player
Video output settings
You might have to reset your display settings. You will need to turn off your PS3, Holding down the power soft key, turn the unit on in the back. Keep holding the soft key until the unit turns back off. Wait for about 15 seconds. Press the power soft key again. You will hear one beep, then a second beep. Then you will hear 2 quick beeps, as SOON as you hear those two consecutive beeps, let off the power soft key and a screen should come up to reset your display settings. Good luck!
Aug 04, 2009 | Ubi Soft Entertainment Blazing Angels:...
Just bought used kenwood kdc-mp825 its in lock mode
This is the official method right from the Kenwood service manual for this model.
You must use the remote to do this, there is no other way.
If you do not have the remote, you will need to take it to an authorized Kenwood service center and they can do it for a nominal fee. My shop charges $25
If you find this helpful a rating of "FixYa" would be appreciated.
Here it is:
1. During code request mode, press the Track UP key for at
least 3 seconds while holding down the AUTO key. (– – – –
will disappear)
2. Enter, “KCAR” with the remote controller as described below.
• Press the remote controller 5 key twice, and press the Track
Up key. (Enters a “K” )
• Press the remote controller 2 key three times, and press
the Track Up key. (Enters a “C” )
• Press the remote controller 2 key once, and press the Track
Up key. (Enters an “A” )
• Press the remote controller 7 key twice, and press the Track
Up key. (Enters an “R” )
3. Security function is canceled and unit sets to All-Off mode.
4. Code request mode appears if a mistake was made in entering
the numbers.
TEST MODE
Jun 26, 2008 | Kenwood Car Audio & Video
Security code for a kenwood kdc-319
This is the workshop procedure for resetting the code.
Type 1
Type 2
Type 3
Model# DPX-4020 and DPX-4030
Please rate me FixYa for this solution. Good Luck :)
Feb 17, 2008 | Audio Players & Recorders
Display
try this
Type 1
Type 2
Type 3
Dec 26, 2007 | Kenwood KDC-MP435U CD Player
Unlock code
Type 1
Type 2
Type 3
Dec 15, 2007 | Car Audio & Video
Need to find out the four digit code
Type 1
Type 2
Type 3
Dec 14, 2007 | Car Audio & Video
Furuno GP-1850WD GPS Receiver Logo
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
