Question about Canon ZR800 Mini DV Digital Camcorder
Tape I put the tape into camera but it doesnt go down
There is something wrong with the sliding chassis I would only send it in if it has a warranty its not worth it to get it repaired. I repair these models and when I get one with your problem I use the outside pieces for parts and scrap the rest thats if its a return with no customer sorry
Posted on Dec 26, 2007
MY SONY HIFI 8 CAMCORDER THE DEVICE THAT HOLDS THE TAPE WILL NOT GO DOWN SO THE CAMERA WILL CLOSE
Oky can u switch on off the unit.Do not put the tape when u r doing on and off. open the cassette compartment cover,see is there amny movement of Arms or TG
May 13, 2014 | Sony DCRHC26 MiniDV Digital Handycam...
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
When I put my tape in the camcorder and close the metal door, the tape does not go down. but when empty, the tape holder do go down.
Hi, My Sony DCR-HC32 handycam's tape mechanism is giving me some problem. It ejects and the tape deck opens up properly but after putting a tape and closing it, the tape deck does not go in. I tried with or without tape but it doesn't go in. It is still open.
Can you please suggest how it could be fixed?
Thanks,
Pramod
Nov 26, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
Stuck tape
I would try turning the camcorder off, taking the battery pack off then putting it back in. That worked for me several times.
Jun 24, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
Sony Handycam DCR-HC38 is rejecting the head cleaning tape
camera has bad tape loader and or bad tape sensors. sounds drastic but bang it a few times with the palm of your hand. if this doesnt work contact sony service center
Jun 01, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Canon zr 300 won't take tape inside
FONZIE FIX! It worked for me.
close the tape load door and with your fist, wack it. worked first time for me. the instructions were to wack it harder each time until it closes with the tape. Look up FONZIE FIX.
Dec 01, 2008 | Canon ZR300 Mini DV Digital Camcorder
Eject error R
Use different tape. Is the tape still attached to the feed spool, or has it become separated ?
Jul 11, 2017 | Samsung VP-D361 Mini DV Digital Camcorder
Gs36 tape door doesnt open
In case anybody read this....     I have a GS-36 that would not eject the tape. I removed all the screws from the bottom and pulled the bottom plate off. Then I fidgeted with the mechanism near the eject button towards the front of the camera.  In my case it had just become stuck and needed to be gently pried open.    Tested it a bunch of times with tape - seems to be o.k.!
Oct 13, 2007 | Panasonic PV-GS36 MiniDV Digital Camcorder
Canon ZR800 Mini DV Digital Camcorder Logo
46 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
