LG DBRH197H DVD Player / HDD Recorder
Problem for LG DBRH197H DVD Player / HDD Recorder
Door wont open
By dandy2007 on Dec 25, 2007
hey, i put a dvd recorded disk into my lg DBRH197 and the recorder continually said reading. this can not be stopped and now after turning off the machine it wont allow me to open the door to remove the dvd. Is there a manual release button or another way to eject? i have turnned off the player at the wall and removed the plug with no luck. thank you.
Comments:
Feb 08, 2008
- Hey,
I took my recorder down to the repairers as it was under warranty still and the drive itself was actually faulty. They replaced it and now it works fine (as should be expected).
thanks,
Dandy2007
Same Problem
Aug 26, 2008
-   Same problem Help-   spoynder
Jan 09, 2008
-   Have the same problem. Turning unit off at the wall seems to release the unit - until the next time!!-   Guest
Dec 30, 2007
-   Exactly the same prom. am stuck!!!-   Guest
Best Solution
posted on Feb 08, 2008
Very Helpful)
murderface
Rank: Guide
Rating: 91%, 32 votes
Look, if ur unit is out of warranty you may as well do this anyway, its not hard at all. Firstly, unplug from power source!! Thats important, then simply unscrew case, remove case. remove the four screws holding the dvd section to the case. remove the following four screws that are right beside the four screws you just removed that are holding the dvd section together. now unplug the ribbon that has "2" written on it (to the right of the dvd section. now unplug the cord from the power supply (the one running to the dvd section) but only at the first point. now raise the back end of the dvd section, lift up two little plastic flaps clipping it in and slid it out just enough to take of the case off and remove dvd. put back together in reverse order remembering to reconnect all ribbons and cables. connect to power and bobs ur aunt.
P.s. I do not hold myself responsible for any damage you cause to your unit or yourselves. Hope it helps, Murder-face.
Was this helpful?
Yes
No
Popular Solutions for LG DBRH197H DVD Player / HDD
Questions and Unsolved Problems for LG DBRH197H DVD Player / HDD
Do you recommend LG DBRH197H DVD Player / HDD Recorder?
Answer
Answer
Reposted as got a irrelevant non-solution response before! My LG HDD-DVD Recorder has been working... (More)
Answer
i put dvd into play and it comes up unkown disc it does it to rentals and my own please help ive put... (More)
Answer
I cant set up the timer on the dvd player will start recording and then stop
Answer
Will not detect new release dvd's from video shop, but plays all my old one's fine
Answer
My LG, HDD/DVD recorder Model DBRH1979 cannot read any dvd or cd discs, I hear very little drive... (More)
Describe your DVD Players problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
in Newport, KY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
