Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Canon IR3300 showing the error code E000602-0003
Hello sir,
When the Canon IR 3300 switchs on it displays the Error code E000602-0003 please help me what to do
  • 25 more comments
  • Angela M
    Angela M Jan 03, 2008
    I have a similar problem. When I switch on my Canon IR 3300, I get E000019-0000 error message. Turning it off then on doesn't reset it or fix the problem. What does this mean and how do I fix it?
  • geevenki Feb 11, 2008
    E000602-0003 problem is continue please tell me a soulution
  • javier Mar 14, 2008
    yes i got the same problem and reading this where i can get software for this machine and any idea how much it cost?
  • Anonymous Apr 18, 2008
    E000602-0003
  • rajsmarty Apr 18, 2008
    E000602-0003
  • mbaabhi May 04, 2008
    E 000602-0003
  • Anonymous Jun 03, 2008
    i have e000602 0003
  • Anonymous Jun 04, 2008
    errorE000602-0003
  • Anonymous Jun 05, 2008
    Dear sir
    Best regards to you.
    we are Engineers of main tenance confroting a problem of the code and how to formit the computer and we need cd of formit thanking you
    Irag . baghdad . kahramana company..
    E-mail:sharp20010@yahoo.com
  • Anonymous Feb 26, 2009
    ERROR CODE E000602-0003
  • ajayatl Mar 22, 2009
    "Canon IR3300 showing the error code E000602-0003"
  • Anonymous Mar 23, 2009
    canon IR3300 showing the error code E000602-0003 problem
  • omkar Sep 14, 2012
  • punidhamerin
    punidhamerin Sep 19, 2012
    Hello sir, When the Canon IR 3300 switchs on it displays the Error code E000602-0003 please help me what to do
  • ashishneshal
    ashishneshal Feb 25, 2013
    E000602-0003 problem is continue please tell me a soulutionent for me
  • Nazir Aug 25, 2013
    somebody answer me plz????????????
  • magesh
    magesh Nov 18, 2013
  • deepak salonia
    deepak salonia Dec 13, 2013
    3 proble E000602-0003 problem is continue please tell me a soulutionm is continue please tell me a soulution
  • sunny bharti
    sunny bharti Jan 04, 2014
    CLEAR ALL EROR CODE
  • Anonymous Mar 18, 2014
    i have canon ir 3035 the problem shows error code 000110-0001 how i solve the problem
  • Anonymous Mar 19, 2014
    Canon ir3300 error code 480 how to rectify?
  • latesh
    latesh Jun 05, 2014
  • Pardeep
    Pardeep Sep 13, 2014
  • gamit harishbhai
    gamit harishbhai Feb 06, 2018
ERROR CODE E000602-0003 what i do
Posted on Feb 08, 2010
  • Sivagnanam Siva
    Sivagnanam Siva Jan 20, 2014
    have a similar problem. When I switch on my Canon IR 3300, I get E000602-0003 error message. Turning it off then on doesn't reset it or fix the problem. What does this mean and how do I fix it?
PROBLEM WITH ERROR E000602-0003 CAN U PLS GIVE ME THE SOLUTION FOR THIS PROB ?
Posted on Aug 19, 2012
Error code E000100-002
pls solution sir
Posted on Sep 10, 2010
  • shamminolta
    shamminolta Nov 12, 2013
    laser unit problm
E000007-0000
Posted on May 02, 2010
  • shamminolta
    fixing filim probelm
  • Mohammad Irfan Aug 26, 2014
    replace the fixing film
    Sniper:
  • 57 Answers
Just replace the hard disk and re install fresh software. Yes this is a common problem with this model. Actually it is noted it happens a lot when power cuts are present. Or the machine is powered off recklessly.
Posted on Jun 12, 2008
    New Friend:
Have a similar problem. When I switch on my Canon IR 3300, I get E000602-0003 error message. Turning it off then on doesn't reset it or fix the problem. What can i do how do I fix it?
Posted on Jan 20, 2014
  • josiah malekela
    josiah malekela May 27, 2014
    The same problem but mine is ir 3100cn
How do i clear this problem error E 602-00002 on IR 3300 Canon copier?
Posted on Jul 23, 2012
Nevermind. I researched the error code and fixed the problem. Thanks anyways.
Posted on Jan 03, 2008
  • 1 more comment
  • Angela M
    Angela M Mar 06, 2008
    I researched the solution for error code E000602-0003: Your hard drive is going bad. Using the DSK CHK utility (1&9 while powering up) may fix the bad sector and get rid of the error by trying HD clear & then HD check for every sector in service mode , but more likely than not, the error will come back. You can try to upgrade the system software as well. If nothing works, you need to get the HDD replaced. This problem happens alot in these models. Hope this helps. ~Angela~
  • muthenna saad Apr 25, 2013
    ms angela m thank you i wont to now the hdd have software or not becose im opened the hdd from the data and formated out sid on pc to check bad sector now is ok but whare can i found the software to instal before join to data
  • deepak salonia
    how doi software instal
    New Friend:
Posted on Jan 02, 2013
  • konerudasharath Jan 02, 2013
    errorcode e000602-0003 solve proablam
*28* - copier - fuction - HD clear - OK
turn off mc - 1&9 - turn on mc
Posted on Jul 13, 2012
  • Canon Expert
  • 414 Answers
Posted on Feb 12, 2013
Canon ir 3300 display shows error E000202-0002How can i solve thiss errorTone Multimedia
Posted on Mar 22, 2012
  • shamminolta
    check scaning lamp & ccd
  • 3 Answers
E514-002
Posted on Jul 27, 2012
E000014-0000
Posted on Oct 05, 2011
    Master:
  • Canon Master
  • 680 Answers
That problem is the hard drive of the copier, you need to replace the hard drive and reinstall the firmware
Canon IR3300 showing the error code E000602-0003 - e602-gzsi0kvnxjayujk3pbvqfhb1-3-0.jpg
Posted on May 17, 2018
2 Suggested Answers
  • 199 Answers
SOURCE: Canon IR 3300 switchs on it displays the Erro E000602-0003
replace hard disk drive
Posted on Feb 15, 2009
Canon ir 3300 which side is fuser
Sir
clear the error codes in service mode-
Take the help of service engineer.
Thanks.
Dec 20, 2014 | Canon Office Equipment & Supplies
E000003-0000
good morning sir, my ir machine is 3300 the problem is showing to my machine is E000003-0000 please suggest me answer
Thanks
Apr 21, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir 3100 error code e000070-0001
the error code appears when a tension arm (front or rear) of the ITB tension roller is broken.check the tension arms (front and rear) for breakage. If either of the arms is broken, replace it with a new one.
May 03, 2011 | Canon iRC3100 Printer
ERROR CODE e000602-0003 HOW TO CLEAR THE ERRROR APPEARING ON THE SCREEN OF CANON IR 6000
This is HDD related problem, try : turn off copier pres 1 and 9 (hold it ) then turn on the copier. That initalizes the hdd defragmentation. if does not help, you need to change the hdd and "fill" it with system software.
Apr 23, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Error
E000007-0000 code is Fixing Film error.
FM2-3346-000
1 FIXING FILM ASSEMBLY 120V
FM2-3353-000
1 FIXING FILM ASSEMBLY 230V EXCEPT CN
FM2-3329-000
1 FIXING FILM ASSEMBLY 230V CN
Sep 11, 2009 | Canon iR 2016i Black and White Copier
Canon ir 3300 xerox machine display board not working
dispaly and pad is not working who to open it tell me the codes
Feb 13, 2009 | Canon Office Equipment & Supplies
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
15,073 people viewed this question
Clive
Clive
old marine
old marine
