Question about Sony Ericsson K610i Cellular Phone
Cannot recieve calls
My new K610i cannot receive calls. When I select "answer", I can hear a click as if answering then immediately ends call.
    Brigadier General:
  • 7,752 Answers
The phone needs to be diagnosed so take it to a mobile center to be fixed.
Posted on Oct 25, 2008
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
I cant recieve calls or make any calls from my cell phone
Hello:
You need to restore factory settings of your k800i .
your phone default code is 0000, go to setting then select restore setting or factory setting and enter code 0000 .
If this solution is helpful please click a thumbs-up rating below.
good luck .
Feb 03, 2010 | Samsung Cell Phones
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
How do you change the number of rings before it answers? Please
- Press MENU
- Scroll to "Initial Setting" by pressing the up or down arrow
- Press SELECT
- Press SELECT at "Set Answering"
- Press SELECT at "Number of Rings"
- Select the number of rings using the up or down arrow, or press any number 2 thru 7 or 0
- Press SAVE
- Press OFF
Need the full manual for your phone? You can download/print it here:
http://support.radioshack.com/support_phones/doc73/73355.pdf
Dec 14, 2009 | Panasonic KX-TG2357 Cordless Phone
Problem with outgoing calls--receive can't hear anything
turn the phone off for about 3 sec and back on... happens to me all the time
Mar 10, 2009 | Motorola Cell Phones
Can not recieve fax. currently just hooked to phone line
Receive a fax
Depending on the Auto Answer setting, your HP All-in-One can receive faxes
automatically or manually. If you have set the Auto Answer option to Off, you will
need to receive faxes manually. If the Auto Answer option is set to On (the default
setting), your HP All-in-One will automatically answer incoming calls and receive faxes
after the number of rings specified by the Rings to Answer setting. (The default
Rings to Answer setting is five rings.)
Receive a fax manually
If you set up your HP All-in-One to receive faxes manually (the Auto Answer option is
set to Off) or you answer the phone and hear fax tones,
1. Make sure the HP All-in-One is turned on and you have paper loaded in the input
tray.
2. Remove any originals from the document feeder tray.
3. If you are currently on the phone with the sender, instruct the sender to press
Start on their fax machine.
4. When you hear fax tones from a sending fax machine, do the following:
a. Press Fax on the control panel of your HP All-in-One.
b. When prompted, press 2 to select Receive fax.
c. After the HP All-in-One begins to receive the fax, you can hang up the phone.
Jan 14, 2009 | HP Officejet 5610 All-In-One InkJet...
Recieveing
If all else fails try the manual mode:(Press Receive Mode to select
FAX ONLY, FAX/TEL,TAD:ANSWER MACH. orMANUAL.)
Manual Reception
Pick up the handset while the phone is ringing.
2 Press Fax Start if you hear fax tones (beeps).
3 When the LCD shows RECEIVING, replace the handset.
(best used when you are expecting a fax and know that the incoming call is a fax)
If you are like most people you probably also have a phone with an answering machine or voicemail setup on your home phone. If this is the case you may want to set the reception made to
TAD:ANSWER MACH.
May 28, 2008 | Brother IntelliFAX 2800 Laser Fax
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Landline phone
I gather you are using an IP phone. I would have to say that the only way to trouble shoot is to use a protocol analyzer. If you connect it within the IP path you will be able to see both ends of the call and determine if the call was received or not and if the other end is responding to your call. Your IP PBX might be the problem I would run a diagnostic on it and if it fails, I would suggest calling the manufacture to see if there are any tests you can run.
Aug 22, 2007 | Actiontec (DHUSB00020C01)
Sony Ericsson K610i Cellular Phone Logo
35 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
