Modems
Problem for Modems
Generic problem for all Modems
Port forwarding
By AARIF on Dec 25, 2007
Need to forward port from 5060 to 8000 for an application but not succeeded.Even putting on DMZ didn;thelp.
Solution #1
posted on Dec 25, 2007
Somewhat Helpful)
pasha19
Rank: Guru
Rating: 86%, 760 votes
What is the manufacturer of your router so I can get a user guide and taylor the instructions if needed?
Generally I would statically address the device to be forwarded to. If your router address is 192.168.1.1 and Subnet mask of 255.255.255.0 and it's DHCP server controls address 192.168.1.100 for 50 leases to 192.168.1.149 then consider using the range 192.168.1.2 - 192.168.1.99 uniquely as static IP addresses. There are more starting at 192.169.1.150 but let's ignore them for now. In the network adapter to recieve port forwarded content assign a static IP address based on the above as say 192.168.1.15 with a subnet mask of 255.255.255.0 and a default gateway of 192.168.1.1. The DNS addresses should also be static however depending on your router there may be an option. Some routers allow their address to be entered as the DNS address and pass requests as appropriate to the DNS servers loaded in their lan configurations, otherwise you will enter your ISP supplied DNS addresses into the network configuration.
Now that we have established a stable IP address to forward the port to we need to tell the router everything it sees for port 5060 gets forwarded to IP Address 192.168.1.15 port 8000. If detailed instructions are needed I will need to know the manufacturer and model of your router.
Please provide the additional information and any questions in a response to this problem and I will respond when available.
Was this helpful?
Yes
No
Popular Solutions for Modems
Questions and Unsolved Problems for Modems
Answer
The cable light is blinking every 1 second on my PCX1100. Is that a problem with the incoming data... (More)
Answer
Need to open UDP PORT 3658 so I can get EA game to connect on my Wii. How do I do that? Also have... (More)
Answer
It says that I dont have enough ram, but i have 3g and it keeps saying the usb needs to be... (More)
Answer
Ezgear ps3 controller wont connect to my ps3 lights just just stay flashing how do I fix it
Answer
adjusting waiting to scan message is constantly on and i cannot fax or copy anything
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Modems:
Top Modem Experts
Rank: Guru Guru
Solutions: 3608
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Modem Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
