Question about Avanti EWC28 Wine Cooler
AVANTI WC40D It has two panels of glass on front door. One pane of glass has shattered.... can I get it replaced? Or get a new door?
  • moot Dec 28, 2007
    Any idea where I can get a new door and how much it would cost?
  • moot Dec 29, 2007
    It is an Avanti #WC40D
  • 66 Answers
It is replace able but if you get the new door is better for you.
Posted on Dec 26, 2007
  • sohail anjum Dec 28, 2007
    if you give me the m# ican help. the M# wc40d is not in my system or who make it.
Can I replace the glass on my french door myself? My doors have miniblinds in between the panes.
You need to have a glass shop replace the broken pane because the original one was vacuum sealed and unless you are able to do that then the window is going to cloud over once it is back together. Now if you just want to replace the broken pane and not seal it then you can have the glass cut to size and just install it.
Jun 04, 2015 | Refrigerators
1996 cadillac deville how to replace passenger front door glass
remove interior door panel inside you will see where it mounts to should be two to three bolts and possible a clip that holds it in place remove old glass and install new glass from top of door remount into window gear mechanisim
May 20, 2013 | Cars & Trucks
Tecnic 1426 inside glass of oven door smashed
It can be replaced. I am not familiar with that unit.You can check with the company at this link for more information on the part you need.
Oct 20, 2011 | Tecnik TKC1426 Electric Kitchen Range
The main oven inner glass door panel has shattered
Unfortunatey, it happens quite frequently, there is no one reason for it to do so.
The only solution is to replace it.
Over a number of years use, the glass looses it's properties, and this is what can happen.
Jan 24, 2010 | Zanussi Ovens
How do I replace the shattered glass in my GE oven door
No doubt this is a double paned glass panel. Two panes of glass with a divider strip separating the two for a "thermal break". Okay, you will need to remove the door from the hinges, and along the sides of the door, or possibly under the door gasket, you will find multiple screws that hold the two sandwiched halves of the door together. There should be a front panel, formed sheet steel, and an inner formed sheet steel panel which is coated with porcelin. When you have the front and back halves of the door separated, inside of one or maybe both of the panels you will find the clips, screws, or materials that hold this glass panel in place. Possibly it is in it's own frame, and the frame and glass both remove as one unit. Then it will be a matter of contacting Customer Service and Parts for your product, giving the Model #, Serial # and any other data that may be needed in order to replace the part with the correct one. Since this should be tempered glass, it will be quite heavy and at least 1/4" thick or so. The "thermal break" or space between the panes is so that heat does not transfer readily to the outside panel. Watch for any electrical connections for a door switch for the oven lamp, and be careful when removing the springs which allow the door to close and seal when in the closed position. And it might be helpful to take some photos of the disassembly process so that you can have a reference when you are ready to re-install the door. Be careful when removing the broken glass, and dispose of this carefully. Take your time, be patient, and don't force any thing, and you should be fine. Good lock. Kindest regards, Slats.
Sep 26, 2009 | GE Kitchen Ranges
My TV set keeps turning off by itself.
Since the lamp is the original I suggest replacing the lamp. There is a Black Lamp Door in the rear of the set. Remove the Door and then the Lamp Exhaust Duct. Then you will see the lamp. Loosen the one screw on the Lamp and pull straight out. Now look at the front of the lamp. If you see shattered glass in side then you have a bad lamp. Note: Sometimes there will be no shattered glass and the Lamp can still be bad. When you have the new lamp becareful not to touch the front glass, not even once. Reinstall the new Lamp in the reverse order and make sure that you reinstall the Lamp Door and tighten the screw as the tv will not work with the door missing. The Lamp part# is BP96-01472A.
Jul 15, 2009 | Samsung HL-S6187W 61 in. HDTV
KitchenAid Built-in microwave middle glass shattered
not a problem, first you can refer to your user manual as to how to remove door, (pg 21) heres a link if you misplaced it.
then Ill include this link as well, which is apart breakdown for your GENERAL oven, and i do this so you can see the different panes of glass( ther are 4 of them inthe oven door, each one different so ordering hte right one will be half the battle.
the numbers after you model example, kemc308kss** (01,02,03,04) these last 2 digits will also determine which glass you actually have
Once the door is off and you have the correct glass, changing the glass is nothing more then reomving screws from the door frame, layer by layer until you get to the broken pane, not real difficult at all
Dec 09, 2008 | KitchenAid Architect Series KEMC308KSS...
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Avanti EWC28 Wine Cooler Logo
241 people viewed this question
Top Avanti Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Avanti Furniture Expert? Answer questions, earn points and help others
