Question about Sony PlayStation Portable (PSP) Console
PSP game won't play
Try to run the game and recognises there is a UMD in but when loading it comes up with 'Game could not be started (80020148)'.
Tried then to update software to ver 3.51 and it comes up with 'Game could not be started (DADADADA)'
  • 5 more comments
  • MelanieD Dec 25, 2007
    Same problem, everytime i try to start a game i get "The game could not be started (80020148). When i try to update ver 3.71 i get "The game could not be started (DADADADA)
    Please help... its christmas day
  • cfhurt Dec 25, 2007
    same prob. put in any game and it will not play just keeps trying to load.
  • Anonymous Dec 25, 2007
    i have a psp everytime i try to put in madden o8 the game do not come on. even the umd. but evertime i put in mortal combat unchained it come on.
  • kamil12345 Dec 25, 2007
    my psp is on the setting screen, how do i get it to play a game. i have a game in but it wont load
  • Anonymous Feb 18, 2008
    I have a same problem.
  • Anonymous Nov 23, 2008
    psp
  • aubr080 Nov 23, 2008
    every time i put a game in it makes a weird noise an while its making that noise it is trying to load the game it takes about half an hour for it to say can not read disc. but wen i charge it for three days straight then try playing it it works until i turn it of or it gets frozen.
Now I'm so Sick ! OF MY PSP CAUSE WHEN I PLAY GAME IT ALWAYS SAY THE GAME COULD NOT BE STARTED (80020321) PLEASE I VERY NEED HELP HELP ME!
Posted on Jan 20, 2008
Pilon izzz ggt
Make sure the lesn is clean, and once you insert the UMD, push the metal holder against the flap lightly.
i've had the same problem before.
Posted on Dec 25, 2007
I put the disc of tron in my psp and when i open it it a pears that the game cant open because of a eror code 80020148 how do i fix it
This is how I managed to fix the psp error 80020148. Ok I found some program online that works on my 3.40 OE-A and it rips the UMD games for me. but when I went to play them the "The game could not be started. (80010002)" message came up. Then I tried to play the original game (UMD DISK) I got this message "The game could not be started. (80020148)". So I went online here is what i found......
TO FIX THE PROBLEM FOLLOW THESE STEPS:
1. Goto Recovery Menu (turn off then hold R and turn on) 2. Configuration -> Use NO-UMD (Disable it) 3. Go all the way back to main menu 4. Advanced -> Advanced Configuration -> (Disable all of them)
Feb 01, 2011 | Disney Tron: Evolution for PSP
When i try to run a iso/cso game, the white psp would shoe up and then the screen truns black went back to the psp menu and it said Game could not start 80020148 my psp's system software is 5.00 M33-4
What you need to do is disable the umd from within the custom firmware menu. Completely turn off the PSP (hold the power button up until it turns off). Then while holding the right shoulder button, turn the PSP on. The recovery menu will load. Select configuration and then disable the "no umd" option. Exit from the recovery menu and insert a umd disc into the PSP. Make sure auto start is also disabled in the PSP menu settings. You should now be able to run your game.
Hope this helps and thank you for using FixYa
Jan 06, 2011 | Sony PlayStation Portable (PSP) Console
When I insert a new UMD i get the game could not be started. 80020148. The UMD is recognised and the thumbnail appears on the menu, but the game will not start. Please help.
Solution: 1) You must first backup ur data on your memory stick to your PC. Mainly the saved games data. ( directory is PSP\SAVEDATA) 2) Format the memory stick using the PSP format tool in system settings...not your PC. 3) In System Setting UNCHECK or UNSELECT "UMD Cache" this must be off!!!! 4) Connect your psp via USB cable 5) Copy your game saves / data back to your psp remember >> PSP\SAVEDATA . 6) Do a hard reboot of your psp ie hold the power switch for 3 seconds and it will reboot. 7) Your UMD games should now work with no probs.
Nov 25, 2010 | Video Game Consoles & Games
PSP Error 80020148
Had the same problem also but just solved it..
Just go to Recovery then Advanced>Advanced Cofiguration>Execute BOOT.BIN in UMD/ISO --> Set this to Disabled..
Sep 12, 2009 | Sony PlayStation Portable (PSP) Slim...
if you hold the right trigger then power on your console you should get the recovery menu then select configuration then umd mode and try
eitherm33 no umd driver or sony np9660 -no umd driver if you are using custom firmware
Aug 26, 2009 | Sony PlayStation Portable (PSP) Console
WHEN I TRIED TO PLAY A GAME IT CAME ON THE SCREEN THE GAME COULD NOT BE STARTED (80020148)
Apr 15, 2009 | Sony PSP (Piano Black)
Psp keeps giving code 80020148
you only have to do is you will insert your UMD, then you can play now your down load games....
Jul 20, 2008 | Sony PlayStation Portable (PSP) Console
Psp fault code
Can you run other UMD's and it read them?  If so you need to possibly clean the Original UMD.  If your not able to read any UmDs, or it will see the UMD and not load it up and run the UMD, you will need a new UMD drive.  I can replace your UMD drive for $45 including return shipping.  Contact me at Repairtech@playstationclinic.com.   I run the website www.playstationclinic.com
Oct 07, 2007 | Sony PlayStation Portable (PSP) Console
Error:80020148 is coming up when i start my UMD
Its happen to me also, while I am trying to play Harry Porter & the Pirate game. What I find is: My PSP firmware is not update enough to play the game. So I update my PSP to 3.40-OE...
Aug 06, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
350 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
