Your ice dispenser door may not be closing tightly, allowing air to leak in causing it to frost up and block the ice.
There is a solenoid that operates the door that
could have stopped working. Can you hear it?
The hinge on the door could be broken or the
bracket it goes in could be broken. You'll have to look to see what's
wrong.
Remove the dispenser cover by gently prying starting at the
bottom going round and round a little at a time to prevent from breaking it.
When it's off the screws will be exposed to access the other components.
I see this a lot with people who mainly used crushed ice. It will leave small pieces of ice behind and add up to a clogged situation. If you mainly used crushed ice you will need to run full cubes thru every so often to keep the chute clear. Another cause of this would be the flapper door on the dispenser doesn't close completely and warm air gets in and melts the ice in the bin so it clumps together and won't dispense. In this case you may need to replace the solenoid that shuts the door and/or the door. Let me know what you find.
