Question about Refrigerators
Fridge compressor runs continuously
My Westinghouse fridge has decided to run continuously...that is the compressor doesn't cycle off.....
it's a BJ433V .....
  • Anonymous Mar 13, 2014
    Will a refreigerator run continuously without breaks even after attaining required temperature?
    Sergeant:
    Champion:
  • 362 Answers
Make sure its cooling well it could be low on freon and causing it to run continually, it should be iced up if running and freon is not low.
Posted on Dec 27, 2007
    Champion:
  • 249 Answers
Change thermostat I could go on and on ,but thats it!
Posted on Dec 26, 2007
Fridge working as normal but when compressor runs it makes noise like it can't decide what gear it is in and 1 of the 2 noises is more of a groaning sound (like it is going to quit) the alternating ...
DOES IT HAVE A CONDENSER FAN AT THE COMPRESSOR?
WHICH MAY BE IMPEDED OR GOING BAD?
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Apr 02, 2015 | Refrigerators
Westinghouse Fridge/freezer RJ340M. Not freezing cold.
Could be several problems, it may have a leak in the coolant system, the compressor may be bad, or the control system may be malfunctioning.
Mar 17, 2013 | Refrigerators
Fridge starts up when plugged in but only runs for 10 seconds then shows an E in the Freezer temp and and F in the Fridge temp. What is wrong?
Let it stand in the on position at least an hour to check it's not going through a self defrost cycle. If the temp display then doesn't change and the compressor doesn't run check you have power to the compressor and condenser fan
Jun 13, 2012 | Frigidaire 22.6 Cu. Ft. Counter Depth...
My refrigerator is not cooling. the compressor is cycling on and off rapidly
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Jun 17, 2011 | Whirlpool GS5SHAXN Side by Side...
We bought a used but newer model White Westinghouse refrigerator; brought it home, plugged it in. We can hear the condenser motor running, but neither side is getting cold. There is an additional hose of...
Some fridges have an internal fan that sounds like the compressor. If the compressor is running and the fridge is any good the inside will quickly cool and the condenser will become warm. If the outside gets warm but the inside doesn't get cool it is possible the defrost heater is permanently switched on because of a fault.
If the compressor is running and nothing is happening the fridge has probably lost it's refrigerant gas. Moving fridges can upset them and it is unwise to switch on straight away - they really need to settle for at least 4 hours. Switching on too soon can damage a lubricant deprived compressor.
Oct 04, 2017 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
My Westinghouse freestyle fridge freezer is running but is not cooling the fridge at all.
Mar 19, 2011 | Refrigerators
Hi,I have a westinghouse fridge model RJ215M,have had it from new,it has just stopped cooling,both fridge and freezer also the fan,only thing working is the light,could it be the thermostat or the fuse....
Top of Form
Feb 19, 2011 | Refrigerators
Have maytag fridge about 5yrs old and is triggering the safety switch to go off every 5-6hrs , the freezer is ok the fridge is not cooling, what is the problem
Most likely it is short cycling because the start components or condenser fan are defective. This causes the compressor to run for a few minutes and stop because of overheating. The overheating is tripping the breaker. The cycle will not change until the issue with compressor or fan is resolved. To continue to allow it to run like this risk permanent compressor failure. Thanks, Sea Breeze
Feb 20, 2010 | Refrigerators
Comperssor kicks on but quickly cuts off intermittently every 5 minutes on my frigidaire fridge side by side
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
Kenmore model 253 fridge cools then issues....
Ye, try to first replace the Relay, if that does not help then go to the run capacitor. Those are going to be your only 2 problems that you will have as long as the compressor is still doing its job by atleast running
Feb 09, 2009 | Frigidaire FRS26RLECS Side by Side...
Refrigerators Logo
651 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
