Question about NEC Audio Players & Recorders
NEC VH-605 VCR - Very Snowy Picture
I have an NEC VH-605 VCR. It has been working fine until recently. But for the past few3 eeks the picyure is very snowy and when I tried to tune the tracking nothing matters. The diagnostics states that the head is ok. What else could be causing the snow on the played video image. I would highly appreciate your help. Thanks a lot for your help.
Yesh Enjeti
    Top Expert:
  • NEC Master
  • 12,962 Answers
Video head needs thorough cleaning. If no head cleaner, then run a few long tapes through it in the fast scan mode since the tape itself is abrasive and will over time remove debris from the heads. If that does not do it, try a chemical cleaner to dissolve the material.
Posted on Sep 01, 2017
SOURCE: Snowy Picture, Toshiba 42HP84 plasma tv
Similar problem with my Toshiba. I was told it was the power supply and that it would cost about $900 to replace parts and labor
Posted on Mar 02, 2008
SOURCE: emerson ewc1302 13 in. tv/vcr combo problem
We had that same problem. Try a VHS head cleaner. Worked for us.
Posted on Dec 23, 2008
fuzzyyyy
  • 5 Answers
SOURCE: snowy picture, are heads dirty if so will head cleaner work, could there be another problem other than dirty heads?
if it is your heads, a head cleaner tape slowly grinds down your heads. Abrasion bad. Take to shop and have them clean heads with solvent and soft cloth or Q-tips. Might not be your heads, much electronics, but sounds like might be.
Posted on May 07, 2009
ginko
  • 19396 Answers
SOURCE: Recording very snowy and blurred.
If recordings are only blurry and snowy on playback on camcorder, but are OK on a different camcorder or on computer, then the problem is a dirty magnetic head. Use a mini-dv head cleaner tape. If recordings are blurred even on pc or on a different camera, then there is a fault. Faulty CCD sensor, faulty digital board, problem with internal ribbon connector, and dirty or defective lens assembly can cause this kind of problem.
Posted on Jun 16, 2009
  • 3 Answers
SOURCE: Mitsubishi rear projection TV, Model VS-464R
I have the same problem i am looking to solve it
Posted on Aug 11, 2009
Snowy picture since 8 May 2012 Through vcr
in ur case snowy pictures occurs when ur cables are moist resulting to a grounded circuit check both ends of d cables for wets if in case have the cable dried at least the whole day or replace for best results.or on the other hand check ur tv system mode it might be in the wrong system compliance in ur area or just rechannel ur vcr set to auto program/tune.
May 09, 2012 | Televison & Video
NEC 17"1700M Works fine most
Either an overheating video-card, or a loose connection between the video-card and the monitor.
Jun 25, 2011 | NEC MultiSync LCD1700M (White) 17 in. Flat...
The VCR component used to work fine, but now the video is totally snowy (the sound is fine). In the past, I have solved this problem with other VCR's by cleaning them with a head cleaning cassete. ...
Careful cleaning of the VCR tape head with alcohol and a soft cloth (q-tips sometimes leave fuzz behind) may help, but you could have a problem in the circuit that switches from VCR to Tuner.
Dec 05, 2010 | Samsung DVD-V9800 DVD Player/VCR
Snowy picture on VCR with only certain channels
In all likelyhood, you have a bad ground somewhere in the cable. Try other channels through the VCR. If the ground is the problem, there will be a cluster of channels that are snowy with the rest being clear. Check the cable itself and all of the connectors along it.
If the cable and connectors are good, the tuner or power supply of the VCR could be faulty and cause this as well.
Dan
Dec 24, 2008 | Sony SLV-N50 VHS VCR
Daewoo combo - DVD is fine, sound works but not picture appears
The video heads have been clogged. You can try a cleaning tape, but those often do not work. If that fails, you will need to have a professional clean the heads and verify the head alignment. This should not cost more than $50 or so.
Dan
Dec 10, 2008 | Daewoo DV6T844B DVD Player/VCR
NEC VCR VH-603
fixed gratis thankyou
Jul 04, 2008 | Televison & Video
Computer monitor problem
power supply is most likely going could be capacitors on the vga /inverter board also needs to be checkd out at a service location
May 01, 2008 | Gateway FPD2275W LCD Monitor
Emerson ewc1302 13 in. tv/vcr combo problem
Oct 24, 2007 | Emerson EWC1303 13 in. TV/VCR Combo
Vcr locked
Hi Juzzy I fixed my unit with a universal remote ( can buy them at electrical store) or borrow a friends key in 0061 (this worked on my VH-605 ) on the new remote and hit play and away you go !!
Oct 08, 2007 | Televison & Video
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
Open Questions:
97 people viewed this question
Top NEC Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a NEC Audio Player and Recorder Expert? Answer questions, earn points and help others
