Question about HP Pavilion zd8000 Notebook
HP Pavilion zd8000 PC Notebook turns on...
But the icons overt the keyboard blink on and off-this with the fans running and then seeming to stop. Did nothing to it. just wont come on & flashes the3se lights;
whats the matter? Been at it all year, and something's got to give as it is a nice laptop 'comperter.'
  • 62 Answers
Time to take it to the repair shop.
I've seen instances where the thermal control unit goes bad and causes a similar problem.
Posted on Dec 26, 2007
    Novelist:
  • 77 Answers
Since you have not indicated what SYMBOL is on the "icon" you say is flashing, there are some other (less fatal) possibilities:
Your laptop may have been corrupted during ACPI suspend. Try this solution: Remove the battery AND the external AC Power supply (PSU).
Press and HOLD the start button for ONLY 6 seconds (nothing should happen here, this just clears PRAM).
Let laptop sit 5 minutes, then plug in ONLY the AC power supply and try starting the laptop.
If it starts, and runs normally, there are THREE possible causes for the problem that you must now identify, as follows:
Shut down the laptop
unplug the AC power supply
reinstall the battery
and then (again) re-connect the power supply.
If the laptop starts and runs normally now (including indication after time, that battery is recharging), it was only a corruption in the ACPI or hibernation functions.
However, if the original symptoms reappear now, then you have either:
1. A bad battery (dead cells can consume all of the PSU power and deny sufficient current to CPU/HD.
2. A defective power supply, unable to deliver sufficient current to BOTH the battery and laptop CPU/HD.
3. Or a bad power regulator circuit, which controls the distribution of power inside the laptop, and monitors the battery charge.
A voltmeter/ammeter can identify number 1 and 2 above, when output is compared to your laptop specs. If both are within tolerances, then number 3 is the problem. Hope not, because that is the most expensive possibility (it is usually cost prohibitive to replace a laptop motherboard). If you have no voltmeter, download and/or write down the voltage/current specs and take the battery and PSU to a repair shop and ask them to check these for you.
Posted on Dec 27, 2007
I had the exact same problem. I sent the notebook to HP Service Center. They told me it was a bad graphics card, which is attached to the motherboard. They told me it would cost $1080 to replace the motherboard to fix the graphics card. I told them to send it back without fixing. I am researching the possibility of adding an external video card to override the existing one. I'm not pc savvy so I have no idea if that will work but it's a thought. If that doesn't work I think I'm out of luck.
How do i get the hotkeys to work on a HP zd 8000 laptop
If you have the remote for the HP Pavilion zd8000 you can use that to switch if the keyboard is faulty.
Feb 05, 2012 | HP Pavilion zd8000 Notebook
How do you turn on wi fifor hp pavilion zd8000
To turn on the wireless function:
1.If your wireless notebook is off, turn it on.
2.Press the wireless button. (The wireless light is turned on.)
3.Right-click the Wireless Assistant icon (select models only) in the notification area (lower-right corner of the screen), and then select the Open Wireless Assistant window. Select the appropriate settings to toggle on/off the integrated 802.11 and Bluetooth devices.
for more information you can also check the user manual on the manufacturer website.
May 16, 2010 | HP Pavilion zd8000 Notebook
I have a zd8000 hp laptop...MB # 374711-001 screen is good. can see win xp up and running, with a flash lite on it... but no video thinking the ATI chips are burnt..... a fan stopped working.. but replaced...
take it to a hardware tech...only he can fix it...here you may not be able to get a solution....
all hardware failures can be fixed only in a tech shop...that's the shortfall of this system here in this site.
Mar 16, 2010 | HP Pavilion zd8000 Notebook
Keyboard overheating
This is a charactoristic problem with many brands of laptops. How long has it been since you changed the battery? Overcharging the battery is what causes the heat to seemingly heat up the keyboard.
Jun 20, 2009 | HP Pavilion zd8000 Notebook
Problem with the laptop keyboard (HP pavilion zd8000)
is filter keys in ease of access center in control panel turned on?
Apr 01, 2009 | HP Pavilion zd8000 Notebook
I have a HP Pavilion TX 2000, PC Tablet & the keyboard locked ((
just see the option is given on your laptop keboard for locking and unlocking .
Mar 14, 2009 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 keyboard skips characters
The most common reason that your cursor skips around is that you are touching the touch pad when typing. Some are more sensitive than others. On my Toshiba I had that problem, but it has a Fn key that allows me to turn off the touchpad. Problem went away when I went to a mouse instead.
Had a client with a Dell with the same problem. I had to actually physically disconnect the touchpad and her problem went away.
Now as for the first problem, (the HP), I'd say you have a stuck key on the keyboard. It would make that noise.
Feb 14, 2009 | HP Pavilion zd8000 Notebook
HP Pavilion ZD8000 Manuals
Hi, the manual is available in FixYa itself.
The link is http://www.fixya.com/support/p381158-hp_pavilion_zd8000_pf456av_pc_notebook/manual-3309
One external link is
http://www.onlinefreeebooks.net/?s=Maintenance+and+Service+Guide+HP+Pavilion+zd8000+Notebook+PC.pdf+
May 09, 2008 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 wont turn on, just blinks on and off
are you referring to a small coin-cell sized battery mounted to a circuit board or the main system battery?
May 29, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
258 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
