Question about Intel D101GGC Motherboard
Sound Device Not working
My pc displays the PCI devices as Unknown.
I have the motherboard CD and i have also installed the correct driver but I cannot access my games. And the Unknown device is there too.
Plz Help me!!!! This Christmas I want to play some games.
Sorry For My English
  • VinayDesai Jan 18, 2008
    i have d101ggc motherboard of intel i have installed all the relevant drivers that are required but i still find and unknown PCI device in device manager. please help i m not able hear any sounds and all the sound drivers are well installed.
  • Anonymous Mar 24, 2014
    access code for call of duty ghosts
Gigabyte p41-es3g MB pci simple communications controller drivers missing
Do you have a modem that is no longer in use?
Some LAN cards have more than one device. It may be a bridge or something. I think that is noted on your question. Look for the manufactures driver.
"Don't fix it, if it ain't broken." If you can live with a non-impact warning.
Nov 22, 2012 | Computers & Internet
Sound not coming in win xp sp3 even after updating correct sound driver?
Do you still have the unknown device in device manager? If so, you need to install a different driver. If not, go into device manager, expand Sound, Video, and Game Controllers. For each device under that heading, right-click the device, then click update driver software, choose "Search Automatically..." It will then go to the windows update site and see if there is a driver there that is listed as more recent, and it will install that driver, if such a driver is found. If that doesn't work, make sur ethat y ou manually find the correct sound driver installer, and then right-click whichever device obviously represents the sound hardware driver, and click Uninstall. Reboot afterward. Then reinstall the audio driver. If that doesn't work, you may have to reinstall windows.
Mar 02, 2012 | Computers & Internet
Found the Problem with albatron px865pe pro with multimedia and usb problems. When I install the software somehow it miss the drivers so manually intsalled the drivers off of cd that came with the pci...
if you are running windows,
  • Control Panel
  • System
  • Hardware
  • Device Manager
Make sure that your drivers were not installed as Unknown Device:
  • Uninstall
  • Reboot
  • System will try and reload drivers after reboot, or you can manually load then
  • Control Panel
  • Add Hardware, system will look for new hardware, follow steps
Feb 24, 2011 | Albatron PX865PE Pro Motherboard
A8v deluxe have no sound after rebuild of system, have try different driver and update but still no sound
Did you checked the bios setting for your audio? It should be set to Auto. See the Advanced tab in bios, onboard Devices Configuration section 4.4.4 page 4-23 in your manual. On the other hand if you open windows device manager and within Sound, video and game controller you see either unknown PCI device or a yellow pair shaped icon with an ! point in it, than you'll need to install the audio software through windows device manager. Make sure your Asus driver CD is loaded into your CD-Rom drive. Open windows device manager again. Right click once on the unknown PCI device and left click once on update driver. Follow the on screen prompts. Point windows to the CD. You may need to open the driver folder on the CD and click on it once so it is high lighted. Than click OK. The audio driver software should install. If this fails to fix your issue than the onboard audio chip is defective. You can not repair this.
If your MB is still in warranty (Asus 3yr). You can RMA the MB.
Happy holidays!
Dec 11, 2009 | ASUS A8V-E Deluxe Motherboard
I have a problem with my p5sd2-vm motherboard
have you tried downloading asus pc-probe utilities it might help you can get it here
Don,t have sound and do not detect the sound at all Very frustrated
Open windows control panel. Open add-remove programs. Uninstall any sound driver software. (Reboot the system when finished). Download RegCure, its free (This will clean your windows registry). Click on the link below; (Re-start when finished).
Check your bios. Once your in the bios,
go to the Advanced menu. Open, Onboard Devices Configuration.
Check your settings against the manual. See page 2-24. Save & exit the bios. Boot your system.
Open windows device manager. Look for a yellow pair shaped icon with an ! point or an ? in it or an unknown PCI device. If you see any, you'll need to install the driver software from here.
Right click once on the device, (Like unknown PCI device). From the pop-up window that opens left click on, update driver. Load your Asus CD into your CD-ROM drive. (Follow, Hardware Update Wizard screens).
Point windows to the correct sound folder on the CD. Click on the correct folder so its high-lighted, than click OK. Windows will do the rest. When you first got the board the jumper settings for sound are set for AC97. See top of page 1-30.
If windows does not detect the sound device while in windows device manager, it is possible the onboard sound chip is defective. Asus warrants their boards for 3 years. You may need to call Asus for an RMA & send the board back. Call Asus tech first at, 812-282-2787 IL EST. M-F 8:00AM-4:00PM
Call, 510-739-3777 for RMA
Below is the link for your board;
May 03, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
yes, install new drivers, ****.
Feb 21, 2008 | E-Machines W3050 PC Desktop
Sounds disorted and skipping
Check that you are using the correct audio drivers for your PC. Eventually you can buy a PCI sound card, which is quite inexpensive, and install it on the motherboard. It can replace the sound card integrated with the motherboard. once the new card is installed the old card must be set on ' do not use this device (disable)' from device manager.
Feb 14, 2008 | E-Machines eMachines Desktop PC
I cannot install drivers
Sometimes motherboard cd drivers bring multiple sound drivers, you have to make sure you choose the correct one. Below is the download page for audio driver for Intel D975XBX2 motherboard. Hope one of these from this page works for you.*%20XP%20Professional&lang=eng
Apr 24, 2007 | E-Mu 0404 Sound Card
Intel D101GGC Motherboard Logo
403 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
