Question about Microsoft Xbox 360 Console
When I turn on my Xbox Everything Works Fine Apart from The Screen...
When I turn it on, the display that I should be seeing is split into 3 static screens, vibrating making it near impossible for me to see, apart from the colours.
  • 121 Answers
This sounds like your t.v. may be going out or some other issue post your problem in the t.v. problem category and you may find a solution quicker sorry i have no solution
Posted on Jan 14, 2008
Black screen
it will be the cable for the screen i have had to do a few of these, the cable snaps on the hinge, you will need to replace this cable they dont cost to much. take the screws out of the back of the laptop and remove the key pad then the top cover, you will then see the cable /s unplug them and on the back unplug the wifi wires and remember what way they go, push them through the hole so they are on the top. undo the screws for the hinges and carefully remove the screen from the base. now you will need to take the rubbers off the . screen lid and undo the screws and split the cover seam, when it come apart you will see where the wire is and replace it, you will find a few of the wires on the cable have split. there are two types of cables one type is for if you have web came and other is for no web cam. you need the cable that is right for your screen. put back together in reverse and it should be fine put a bit of grease on the cable were the bend is in the cable around the hinge will help it no split so easy. hope this helps.
May 29, 2014 | HP Pavilion dv6928us Notebook
My xbox 360 causes my hdtv screen to crash and display colored static. It only does this on the 'optimal display' of 1680x1050. I plugged in my laptop on the hdmi and it worked perfectly. Is t
Try manually choosing lower resolutions in your xbox display settings. My Insignia HDTV does that when switching resolutions like on Hulu in between commercials and then back to the show but only for a second or so. Also does this when going from the loading screens to the game screens for a few seconds when playing the game Split/Second
Jan 10, 2013 | Microsoft Xbox 360 Console
My Xbox 360 shows a grey screen, the sound works fine and i do have picture
Hey dude, I had this problem and found a solution on another website. Basically, I had either changed the display settings on my tv, or it had done it by itself or my new ps3 had done it or whatever, but to fix it I went into the TV menu, went to display options, on my tv it has something entitled 'Colour system' I changed that to PAL-60 and I now have colour, just to give you an idea of whether you have the same problem, try setting your x-box display to pal-50 and see if that shows colour (if it's easier to do), if it does then try then solution above! Hope it helps!
Mar 13, 2012 | Microsoft Xbox 360 Console
My Xbox 360 is fuzzy and has green dots all over the screen
I doubt it's the 360 since everything else is working just fine. The menu works fine, the game works fine. However if you downloaded one of these maps from the marketplace it may be corrupt, and you will have to delete and re-download the map pack.
May 15, 2010 | Microsoft Xbox 360 Console
Two red quadrants light up on the left and screen goes blank.
there are two posibilitys to your problem it could be either there is something unpluged in your 360 or your could have a virus you should take your 360 apart and check it if it is still under warrenty through microsoft you should send it in to them and let them fix it but if it is out of warrenty then you should get the tools at your nerest radio shack and take it apart and check it out and let me know what happens
Feb 28, 2009 | Microsoft Xbox 360 Console
My screen is faded kind of like the backlight is out
Yes I can. Sounds like a laptop or flat panel display. Both have a small florescent bulb in them that backlights the screen.
If you can order the bulb the bulb is easy to replace.
Laptop/Monitor: Split the plastic case around the lid/monitor (if there are screws you will need to remove them - check under the rubber pads on the inside of the lid as they often hide screws underneath.)
Run a small knife or flat screw driver around the seam and the two halves will split apart. Once you have done so you can easily access the bulb - replace it - reassembly is reverse of dis assembly.
Feb 06, 2009 | HP 98785A 16" Monitor
My dv2000 boots but screen is split into like 8 parts (each part showing same thing) there are some wavy lines..sometimes its ok ...i try to load windows vista recovery (from partition) - it crashes on...
I have the same problem that my screen splits into 6 but occasionally screen comes normally. I gave to HP service center and they told me to change my mother board. I was worrying about the cost of Mother Board bcoz it costs 1/3 of my purchased rate and also my warranty was expired just 2 months before.
So, I tried some way to fix this temporarily, while screen comes normally, I went to Safe Mode, it works fine. So, I got an idea, it works in less hardware access, I think, how it works when removing NVIDIA display driver. So, I removed it. Now, it works fine but there is a difference in display but that doesnt matter while comparing previous.
I'm still searching permanent solution. I'm planning to change the Hardware of NVIDIA card. Lets see,
Jan 19, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Hannspree 37" with Xbox 360 HD
Try to use a HDMI cable, your component cables may not be usable with your TV.
Apr 20, 2008 | Hannspree (K206-10U1-005) Television
Xbox 360 has sound but no picture on HD setting
Is the tv rated for HD? if its not the inputs will be at a wrong voltage and will create that snow like effect.
Is the TV you normally game on HD?
Dec 16, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
41 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
