Question about SanDisk Sansa View 8GB MP3 Player - Black
Brand new sansa view not working
Please can you help. The player seems stuck. It is lit up but with no graphics at all and I can't switch it on or off - seems frozen
  • 2 more comments
  • Anonymous Dec 25, 2007
    Mine is locked up with blue wheel turning on connected screen it won't turn off. need to reset.
    Mine`s stuck on the "connected" screen too.
  • sylvy Feb 17, 2008
    MINE HAPPENS THE SAME WAY BUT I HAVE TRIED TO TURN IT OFF BUT IT WON'T TURN OFF AND ALL OF SUDDEN THE LIGHT WOULD BE OF AND ON THE SCREEN THE PICTURE OF THE BATARY COMES ON HALF WAY EMPTY AND THE OTHER HALF FULL BUT IT HAPPENED WHEN IT WAS CONNECTED FOR COUPLE OF HOURS. LATER I UNPLUGED IT STILL SHOWEN ON THE SCREEN THAT IT WAS CONNECTED. I DON'T KNOW WHAT TO DO.
    PLEASE CAN YOU HELP ME.
  • ChipWire Mar 25, 2008
    Upon charinging the View right out of the box, the "Connecting" label will not leave the screen whether the USB cable is connected to the PC or not. I have had the e260 which is set up differently. I am not sure which button is the power button, and does the "hold" switch have any effect on this?
    ChipWire
Hold the play/pause button and the power button until it turns off then turn it back on and it should be good. hope i helped!
Posted on Dec 20, 2008
A few ways to "fiks" it (try each solution in order)
1) slide the power switch up for a bit and see if it resets it
2) wait for it to get "unstuck"
3) let the it run out of power and try plugging it in again
4) start swearing and cussing at it
5) try threatening it
6) try begging it to work
7) smash the motherf**ker!!!!
8) if u have a warranty (normally ur gauranteed a 30 day warranty just make sure u have the receipt and its not ur fault it broke) hope the smashing didn't break it and exchange it
Posted on Jun 10, 2008
Mine gets stuck on the connected screen too when I try to hook it to computer then unhook it, just hold the power switch up for 10 seconds to reset it
Posted on Dec 26, 2007
Hold up power switch for 10 secs
Posted on Dec 25, 2007
You're all so retarded it hurt me physicly to read this sorry *** excuse for "help". screw you and whatever gay *** music you listen to!
Posted on Dec 17, 2008
I just put in a brand new 4gb MicroSDHC card into my Sansa SanDisk Plus & plugged it into my computer. Now its stuck on "Refreshing your media" & I can't even shut it off. Help?
Remove the microSDHC card. Disconnect the Sansa from the computer. Press and hold the power button for fifteen seconds to reset the Sansa.
Be aware that the e200 series of Sansa media players do not work with microSDHC cards, only with microSD cards.
Mar 14, 2011 | SanDisk Sansa e250 MP3 Player
My sansa view won't turn on, the blue ring illuminates but that is all it does
Alright it seems your sansa is on its way out. I had to essentially mash on the center keypad while holding the power button in the on position before it finally worked. Be prepared to buy a new one, mine only lasted for 2 weeks after it started doing that
Feb 24, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
My brandnew sansa clip is recognised by my
you should update new firmware first at http://forums.sandisk.com/sansa/
if it still doesn't work, change another one.
Good luck
Jan 12, 2010 | SanDisk Sansa Clip MP3 Player
New Sansa View Scroll wheel won't work
If it's brand new and you bought it at a store, exchange it. If it's an online store and not refurbished you should probably call Sansa as it will be in warranty. If it's refurbished (has a silver capital R sticker on the back) or was an auction item then you can either call Sansa (although they aren't much help with refurbs). If you aren't afraid of working with small objects, are reasonably intelligent, and own a screwdriver, then you may want to clean the contacts (I don't know if this will void an existing warranty or not). Instructions are at: http://joustin.com/?page_id=10 Note, he uses rubbing alcohol but a less messy method is to use the eraser from a standard #2 pencil (pink eraser) to do the cleaning. (Alternately you can use any contact cleaner spray made before 1990 without opening the Sansa...of course the good stuff was banned for manufacture so newer stuff may not work)
May 10, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Sansa E200 screen stuck scribbly black vertical lines
When it is on, holding the power button in for 5 or more seconds hard resets the device. Give that a try. If not. it's possible it's been bounced one too many times and needs the LCD cable re-connected or the controller is bad for the LCD.
Dec 31, 2008 | SanDisk Sansa e200 MP3 Player
Sansa View has a "ink blot" graphic and a white background when I turn it on.
if its an inkblot you broke your screen..... the same thing happened to mine and i'm still trying to find a place to repair the screen.... if i find anything i'll tell you
Oct 11, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Sansa View 8MB Player
delete and start over again
it's best to sync a few disconnect, let the database update, and then reconnect, load some more
Jul 12, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 won't show up in devices!
I had the same issue. Brand new Sansa e250 player. My XP SP2 computer would not recognize it. I updated my Windows Media player to version 10. Bingo, all is working now. I previously had version 9. Good luck!
Dec 24, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e260 problem
It might just need to be reformatted. If you don't care about deleting and redownloading everything with songs and videos and pictures, too, then reformat it. Just plug the mp3 player into your computer and right click on the icon in the MY COMPUTER window, and click on FORMAT. It should come to a new window and click on start format. If this doesn't work, then call me to help you any further. Ask for Maxwell at 1-(239)-945-0583.
Jan 01, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa View 8GB MP3 Player - Black Logo
1,073 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
