Question about Gigabyte 7VM400M-RZ (GA-7VM400M-RZ) Motherboard
Gigabyte 7VM400M-RZ ----NO display from onboard graphics only video card is working
My on board display is not working. iverified tht its not the problem wid the monitor, bcoz display form external graphics card is working.. help plz
also plz give me some call center no for giagabye in mumbai area.
thanks
  • gettosandy Dec 25, 2007
    i wanted a help line no for gigabyte(call center no) as my motherboard is still in warranty
  • Anonymous Apr 15, 2008
    I have gigabyte 7vm400m-rz motherboard but it doest give me nothing on my monitor my on board and external graphic cards dont work
Plz.. help me the problem of my motherboard gigabyte 7vm400m-rz, the problem is when i was turn on the comp. when is okey but, the display will not longer in 5 minutes then the beep has came in then, the computer has turn off.....help me please.....
Posted on Feb 23, 2008
    Master:
    Sergeant:
  • 482 Answers
Get a new card and put it in, this will bypass the onboard display
Posted on Dec 25, 2007
Onboard video does not disable on my Gigabyte 7VM400M-RZ
PUT EXTERNAL GRAPHICS CARD AUTOMATICALLY DISABLES ON BOARD VIDEO
Apr 06, 2010 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
One long beep tone---NO Display on monitor(monitor checked ok)
Definitely not your monitor. It is either a CPU or a Memory problem, is this a new build or did an existing computer suddenly start doing this?
Is that your motherboard, the Gigabyte 7VM400M ?
Jun 26, 2009 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Memory up-grade
you can go max 2GB (1GB each) DDR333 PC2700.
you have to reset the bus rate to match the RAM speed.
if you stay with DDR266 then you don't have to reset the bus rate
Nov 13, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
No display
can you test with a cheaper ram, seems some high ram have issues on motherboards, sounds shittyn but give it a try, also look at http://www.hardwarecanucks.com/forum/guides-how-tos/914-10-step-no-post-bios-recovery-guide.html
Aug 17, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Gigabyte 7VM400M-Rev.1 Onboard Video
format ur computer once again.. n install the driver..
Feb 14, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Disabeling display drivers on motherboard
If there's a configuration option for it, it would be in your BIOS. every model has a slightly different way they portray this option. some BIOSes tell you straight out, labeling it "enable/disable onboard video" option. others give you a prompt asking what you would like to ''prioritize'' for graphics. there are also specific jumper configurations you can use that would be documented in your motherboard's manual.
However, you may not find any such option there, as most boards today automatically disable onboard video when a card is installed. Make sure that the video card you are installing is snug and secure in the AGP slot, with all pins in the proper places, and with the plastic clamp locking it in place. It shouldn't feel loose, or be bent when you're positioning it.
Also, make sure that if the card needs to be plugged in to your power supply directly (there should be a white jack or two with four metal pins on one side of the card if there is), that you do so. If the card isn't getting any power, that could be why the motherboard isn't detecting it. Also, check to see if your power supply can handle the rating... some video cards require stupidly high amounts of power to run properly.
if all this doesn't help, either the video card itself or the AGP port ont he motherboard is malfunctioning. test a different video card if you have one in that system board, or take it to someone else to test on their computer. If you recently bought the card, you can have it sent in to the store you bought it from, and I'm sure that if you request it, they will test the video card themselves to see if it's defective, and give you a replacement if it is.
Dec 30, 2007 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Disabling the onboard graphics for this motherboard
hi, go to system bios, i think in the second options check out for primary display , you will have options for add on, or onboard, change it to add on, or there is also an option to disable the primary display somewhere there, browse the bios around , you will find either of it. let me know
Dec 16, 2007 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Gigabyte 7VM400M-RZ (GA-7VM400M-RZ) Motherboard Logo
790 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
