Question about LG 42LC2D 42 in. LCD HDTV
Swivel Base for a 42LC2D
I want to remove the Swivel Base to mount the TV on the wall only the manual does not give instructions for removal
  • Anonymous Dec 30, 2007
    Hi, I can't get the swivel base off my LG LCD flat Screen can anyone help???
  • 4 Answers
Hi there is normally a set of 4 to 6 screws that hold the base to the tv set that you remove , you can then possibly use the same screws to attach the wall bracket to the back of the tv before mounting on the wall
hope this helps
cheers John
Posted on Dec 26, 2007
How do I remove the base stand to wall mount a Samsung model T24C55OND flat screen TV
The wall mount attaches to the top 1/3 portion of the TVs rear panel. The bottom of the back of the TV should not interfere with your wall mount if it's the correct size. Full instructions are listed starting at page 39 of the manual.
http://downloadcenter.samsung.com/content/UM/201404/20140426112621559/[X13_NA]BN46-00319C-04ENG-0312.pdf
Jan 08, 2015 | Samsung Televison & Video
I purchased an element electronics 32" Full HD digital LCD from Walmart with a Ready Set Mount LCD/Plasma Wall Mount, however the mount does not attach to the tv at the base. Do you know if this is...
The wall mount is not made to be fit into the base, it is attached to the back the TV, TV uses what they call VESA mounting which had different pattern for each TV. Look at your TV user manual to find out the VESA mounting number.
If you want TV wall mount that can swivel you can try looking here: http://www.mountsdirect.com//index.php?cPath=1_4&osCsid=b3fd26fc27f668e207c3741b09abfe51&gclid=CJrL-5Dx1acCFYrs7QodUiUq9Q
http://www.toptvmounts.com/collections/swivel-tv-mounts?gclid=CK7kzPrx1acCFYXu7QodlFc4-A
Or Google "swivel wall mount"
I got my from COSTCO.
Mar 17, 2011 | Element Electronics FLX-3211B 32 in. LCD...
How do I remove the swivel stand from my Hitachi 42PD8900TA for wall mounting?
That seems to be a good question. Page 12 of the manual refers to the mounting instructions for alternative mounts for specific details. I'm guessing that Hitachi has alternative mounts for specific models, and the swivel removal instructions would be found there.
I'll keep looking. Please post if you find the instructions.
Jan 09, 2010 | Televison & Video
How do I take the stand off of the TV? (For wall mounting)
There will be clips or screws on the back of the TV which will need to be removed and the base stand will slide out of the bottom of the TV. Do NOT start taking screws out of the back of the TV without the wall mount with instructions. Sometimes there are spacers that need to be used with the wall mount and generally only four screws need to be removed from the TV. The TV should have instructions on how to prepare the TV for a wall mount as well. All are different, but very similar to do. If you lay the TV face down on a soft surface (do not slide it around) you probably can see what screws need to be removed to remove the TV base. Keep the screws with the stand for later use if desired because you will need them to re-install the case later. Here are two examples;
I hope this helps and good luck!
Nov 12, 2009 | Televison & Video
How do I remove the swivel base?
Steps to remove swivel stand:
  1. Carefully place the product screen side down on a cushioned surface that will protect the product and screen from damage.
  2. Remove the 2 screws that are vertically in line next to the power socket.
  3. Remove the 2 screws that are vertically in line under the RGB socket.
  4. Pull the stand out from the bottom of the TV.
  5. Reinstall the stand in reverse order.
Nov 03, 2009 | LG 42LC2D 42 in. LCD HDTV
Not sure how to take the swivel base off for wall mounting on a 42lb1dra
If you look at the back of your TV, locate four big screw/bolts. Its the biggest screws/bolts you'll ever find at the back. 2 each side that holds the unit to its swivel base. roughly 12" from the left edge and 12" also from the right edge. remove all this four (4) screws/bolts then ask someone to help you lift from the base.
Dec 07, 2008 | Computers & Internet
Akai PDP42Z5TA 42 in. Plasma base removal
If you ever get the base off, I'd like to buy one.
Apr 13, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Remove Swivel Base on 42LB1DRA
Good Luck.
Dec 30, 2007 | LG 42LC2D 42 in. LCD HDTV
Removal of base
Most LCD HDTV televisions come with the option to remove the base, refer to your manual for proper instructions on removing the base. But make sure the TV is certified for wall mounting before you do anything - some are not certified and will not be wall mountable.
Sep 07, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
LG 42LC2D 42 in. LCD HDTV Logo
727 people viewed this question
