Question about Aiwa AV-D77 Receiver
No power I have a AIWA av-d77 reciever that won't power up all the time just when it fills like it, it frustrating. A red power light/stand by light is on but it still only powers up once in a green moon ( not even a blue moon lately. Please I say please help before the holidays HAPPY HOLIDAYS
  • Anonymous Dec 30, 2007
    I have the same problem : statup failled even trying to hold the enter button when pushing on button.
    looking inside the equipment I've founded on the power supply board a
    faulty transistor marked C114. I did not find any data sheet about this
    transistor (2SC114 I suppose).
    If anyone has an idea or schematics about this part of equipment, i'm very interested to fix this failure.
    Bruno
Clear pre set tuner stations on CX-NA909
The manual is available for free at retrevo.com. On page 12 it explains it.
It's basically an interplay between a tuned station and the keys that stand for Pause or Stop.
Apr 10, 2010 | Aiwa NSX-D77 CD Shelf System
Will not turn on
Page 23...
There may be a short circuit in the speaker terminals.
Disconnect all speakers and try it. If it works troubleshoot each speaker one at a time. Shorted wires are indicated.
© Disconnect the AC cord, then correct the speaker connections.
May 04, 2009 | Aiwa AV-DV75
AV-D77 power issues
Please let me know symptoms of AV-D77 receiver.
Nov 14, 2008 | Audio Players & Recorders
Issue with the power. Reset doesn't work.
If you know basic electronics and can recognize parts inside receiver, then I'm here to help you but please don't call it as junk. Its beautiful piece of Aiwa.
Nov 08, 2008 | Aiwa AV-D77 Receiver
Power on problem
Well this helped me find the relay but I found that after i pulled it off the board that it has some corosion around the metal prongs that hold it to the board. Could not get the relay open to do what is posted above , tryed opening it several times. Not sure if you are supposed to open it but could someone let me know. I am scraping around the prongs to get the corosion off hoping it will help but might just replace it alltogether. Further info on how to open the relay to do what is posted would help, I would appreciate any help, plzzzzz! :)
May 21, 2007 | Aiwa AV-S17 Receiver
Sudden failure to power up
I've had this happen a number of times with my receiver. This trick from the Troubleshooting guide in the owner's manual usually does the trick: To reset If an unusual condition in the display window or malfunction occurs, reset the unit as follows. 1 Press the POWER button to turn off the power. 2 Press the POWER button while pressing the ENTER button. Everything stored in memory after purchase is canceled. If the power cannot be turned off in step 1 because of a malfunction, reset by disconnecting the AC cord and carry out step 2.
Aug 01, 2006 | Aiwa AV-D77 Receiver
Aiwa AV-D77 Receiver Logo
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
