Question about GPX MW3837 MP3 Player
Write protected? why does the file say write protected when i try to put songs on the player
    President:
  • 1,257 Answers
First try to see is there any lock in your usb media drive and see if its not locking it.because some media drives comes with that option to protect it .it looks like slide switch .for one end it will lock the media and when you switch to other side you have the full access
but if that's not the reason it might be the problem with registry
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
http://www.howtogeek.com/wp-content/uploads/DisableUSBWrite.zip
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 11, 2008
Because i believe if u push the pause/usb/mta button and change it to mta then u can drag and drop files.
Posted on Dec 27, 2007
    Master:
    Sergeant:
  • 482 Answers
If you have a memory card, on the side is a switch you move it
Posted on Dec 25, 2007
5 Suggested Answers
silly girl
  • 513 Answers
SOURCE: Player skips over some songs
MP3 files are not a totally homogeneous group. You have different bitrates, and different codecs that output MP3s, let alone all the MPCs and the likes. You should check what your player's recommended bitrate is, and try to find what is common with the MP3s it can't play. Maybe you get them from the same source. If you rip a cd, and output it to MP3 files, my bet is that either all or none will work, there is no randomness here. The only other option is that the files got corrupted somehow, and the player can't read them. Good luck
Posted on Jun 21, 2006
  • 7 Answers
SOURCE: sansa shaker files write-protected
SHAKER ONLY TAKES MP3 FORMAT!!!!!
Use this site to change your format to the correct one for the sansa shaker. This is the only way to load songs from your cds MWA will not work at all. Must convert all files to MWA use site below
http://www.wma-mp3.org/
SOURCE: my coby mp3 player doesnt let me put songs in it
go to www.oldversion.com and download the old bearshare downloading music program and get files that way. For some reason the newer versions of file sharing programs only let you download copyrighted music.
Posted on Jan 09, 2008
SOURCE: how to remove write protect on my usb flash drive
Make sure the hold button isn't on. It's as simple as that.
Posted on Sep 12, 2008
Why do i get format error when i put songs from a cd on the eclipse?
1. Why do i get format error when i put songs from a cd on the eclipse?
= This is probably because the format that your songs are currently in is not supported by your device. Supported devices on the Mach Speed Eclipse 180 MP3 player are: mp3, wav, and wma. If your music is for example filename.cda, it won't be able to play because of the file format being .cda.
2. I also see the song on the eclipse but it says drm protected and will not play the song.
= When ripping your music, check your ripping options in whichever ripping software you are using that protecting music files is off, this may be the reason why your music cannot play - it may be protected to only play on the computer that ripped(recorded or duplicated) the song.
Sep 17, 2012 | Mach Speed Eclipse 180 MP3 Player
My Sansa E260 randomly stopped working
Check and see if the songs you put on the mp3 player are a hidden file Connect to your computer open my computer goto tools on the top of the page folder options click on view Here you will see Hidden files and folder click on do not show hidden files and folders and put a check mark on hide ext....and hide protected Hit apply. Delete any songs you put on the player and start over
Apr 10, 2009 | SanDisk Sansa e260 MP3 Player
Saying my music is there but its not
okay format your mp3 player in FAT OR FAT32. DO NOT FORMAT IT IN NTFS! plug it in irght click on your mp3 player in my computer and select format. Format it with either of those formats and recopy ur files. or if it doesnt work try this link and update ur firmware http://www.tgegroup.com/en/support/users.htm and recopy ur files :)
Sep 25, 2008 | Sears TGE MP3 Player
Philips GoGear mp3
Sounds like the files are DRM copy protected.
You can check for protected tracks.
  • In Windows Explorer, go to the folder where the tracks are stored on your PC.
  • Click on View -----> Details
  • Right click on the header bar in the right hand window and select protected. (If protected is not listed click on More)
  • Tracks will be listed with No or Yes under "protected". Check your non-playing tracks are listed as No, under "protected".
The HDD1830 is not compatible with protected files, although your PC will play them ok.
Feb 29, 2008 | Philips GoGear HDD1830 MP3 Player
My Philips SA21X
The device itself is not faulty. This is Microsoft's fault, not Philips'. Some of the songs may have Digital Rights Management (DRM) encoding that the SA6025 will not support. You can right click on the trouble music file, select "Properties," and select the License or Digital Right tab - look for the msg: This file is not copyright protected. Find out if the songs that CAN'T be transferred have this message. If so, then click on acquire digital rights (or some variant of that phrase). If the files tha CAN'T be transferred DO have Digital rights protection, then you must save the files in a different format that is stripped of DRM encryption.
There are a few possible answers:
1)Start simple - disconnect the GoGear from the computer - let it update - then reconnect it to the computer; if this fails, restart your computer and try syncing again
2)You need a firmware upgrade to make the device compatible with your computer: just open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website; click on the update tab
3) The songs have Digital Rights Management (DRM) protection.Try re-downloading the songs without DRM protection.
4) The songs are in a format not recognized by the GoGear. The GoGear, for instance, will not take iTunes files b/c they are AAC format. With MP3 files, the player supports 32 –320kbps. With WMA: 5-192kbps with sampling rate 8.0kHz up to 44.1kHz. Right click the song file, and select "Save As", and then change the format of the song file. Or, redonwload, in the above-said format.
-Tha Mp3 Doctor
Jan 25, 2008 | Philips SA4010 MP3 Player
M p 3 player
Instruction manual can be found by entering your model number at www.usasupport.philips.com
The device itself is not faulty. This is Microsoft's1.gif fault, not Philips'. Some of the songs may have Digital Rights Management (DRM) encoding that the SA6025 will not support. You can right click on the trouble music file, select "Properties," and select the License or Digital Right tab - look for the msg: This file is not copyright protected. Find out if the songs that CAN'T be transferred have this message. If so, then click on acquire digital rights (or some variant of that phrase). If the files tha CAN'T be transferred DO have Digital rights protection, then you must save the files in a different format that is stripped of DRM encryption.
-Tha Mp3 Doctor
Dec 26, 2007 | Philips GoGear SA261 MP3 Player
Coby mp3 player problem
Write the songs to a CD (or a CDRW) first, then re-rip them to Windows Media Player/iTunes/whatever as mp3s, or unprotected WMAs.
Honestly it's easier to burn and re-rip than remove the copy protection. When you burn it to a CD, the DRM goes away, and you'll have a new file that actually plays on your player.
Dec 23, 2007 | Coby MP-C883 MP3 Player
My coby mp3 player doesnt let me put songs in it
How to convert music from itunes to your mp3 player??
Just right click the song in iTunes and select Convert to MP3. It will make a copy of the song in iTunes that you should be able to move to your MP3 player
Jul 22, 2007 | Philips GOGEAR SA6045 MP3 Player
My Sansa skips the songs I put on it, what can should I do
I restored settings to default factory settings and has been working and not skipping the songs. Restoring to factory settings does not delete any of your data/songs
-Raj
Nov 27, 2006 | SanDisk Sansa e250 MP3 Player
73 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
