Question about HP ProCurve 2524 24x10/100 Mbps Networking Switch
Connecting to console
Im not able to connect to the console of the switch. as per the manual instructions i had already connected switch console port and pc through db9 cable.but on pc when i connect the switch through pc emulator then blank screen appears
    Scholar:
  • 79 Answers
The proper way to console to a switch (at least as far as Cisco Catalyst Switches are concerned) is a rollover cable and a DB9 adapter... I then use HyperTerminal to connect..
What type of switch are you connecting to, and what kind of hardware are you using?
I always use Cisco for networking (Cisco is the king of switches and routers).. here is their step by step for connecting to one of their swtiches:
http://tinyurl.com/b4o0
DG
Posted on Dec 26, 2007
How to manage Ericsson T720G switch?
(1) Console cable if you have desktop
http://www.instructables.com/id/Simple-RJ45-DB9-Cisco-console-cable/
For laptop console to serial cable
http://d32plhejlomyli.cloudfront.net/catalog/product/cache/6/image/500x500/9df78eab33525d08d6e5fb8d27136e95/1/4/14184.jpg
(b) Reset the switch it will work as a normal switch
skype id johnwalker800969@gmail.com
Aug 18, 2016 | Computers & Internet
How do you connect to a terminal with avocent dsr8035
You should have a DB9 to RJ45 converter in the box. This converter is used to change from DB9 serial to RJ45, which is the port on the DSR that is used to connect to the serial console.
Should you do not have such connector, call Avocent Tech Support, they will help you to get that converter.
The NullModem Cable might also be requiered
Also remember:
9600
8
none
none
Apr 23, 2014 | Avocent DSR8035 KVM over IP Switch KVM...
Access denied
yes, you should be able to connect to the console port using a roll-over cable RJ45-DB9, connect using hyper terminal or similar using the com port settings 9600,8,N,1
You can then configure the switch from the CLI...
Have you set the 'Login' command on the VTY lines in the switch setup and an IP address on the management VLAN to connect to.
You also HAVE to have a password enabled on the vty lines in order to connect via telnet.
hope this helps.
May 09, 2012 | Cisco Catalyst 2960-24PC-S Ethernet Switch...
Not connect from console port
Verify that the correct settings and cable/connectors (rollover cable, correct COM port specified) are being used when establishing the console connection.
From the manual-
3.9.2 Connecting to an IBM or Compatible Device
To connect an IBM PC or compatible device, running the VT terminal emulation, to an
Enterasys Networks module Console port (Figure 3-20), proceed as follows:
1. Connect the RJ45 connector at one end of the cable (not supplied) to the Console port on the
Enterasys Networks module.
Connecting to Console Port for Local Management
Hardware Installation 3-31
2. Plug the RJ45 connector at the other end of the cable into the RJ45-to-DB9 adapter (supplied
with the device).
3. Connect the RJ45-to-DB9 adapter to the communications port on the PC.
4. Turn on the PC and configure your VT emulation package with the following parameters:
Parameter Setting
Mode: 7 Bit Control
Transmit: Transmit=9600
Bits Parity: 8 Bits, No Parity
Stop Bit: 1 Stop Bit
source: Install Guide for Enterasys 1H582-25 / 1H582-51 (http://www.retrevo.com/support/Enterasys-1H582-51-Switches-manual/id/2785dj098/t/2/)
Jun 22, 2011 | Enterasys MATRIX E1 (1h582-51-g)...
I cannot install the mouse to my pc.
Its very easy , what type of mouse, and what interface does the mouse have, if its USB connect to a usb port on the system, if its the DB9 pin type connect it to the db9 port, and once connected the system will identify the hardware automatically, if it requires drivers, it will request for it and follow the instructions
Apr 24, 2010 | Gateway Computers & Internet
Can the modem's ethernet port connect to a video game console?
Most modems that have both usb & ethernet connectors are either/or, not both. I recommend using
the ethernet connection to your computer than the usb - the ethernet connection is faster & more
reliable. It also frees up your usb port for other use. If you want both your computer & game console on
the internet, then you need to buy a router which will allow you to share the modem.
Jul 08, 2009 | Computers & Internet
I cann't connect to my switch
The primary connection method for those switches would be serial connection. In the box there should have been a DB9 serial to RJ45 cable. Hyperterminal default settings would allow you to connect.
Jul 25, 2008 | 3Com 4500 24-Port Ethernet Switch
Help with connection
Serial port and com port help In the illustration below you can notice several factors to help correctly identify the DB9 Serial connection. First, you will notice that the DB9 , pictures are included click read and follow instructions.
Good Luck, Please dont for get to Vote. Thank You.
Dec 23, 2007 | Gateway E-4200 Notebook
Open Questions:
HP ProCurve 2524 24x10/100 Mbps Networking Switch Logo
838 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
