Question about Kenmore 15129 Built-in Dishwasher
Dishwasher restart Please help! I started a cycle and about 1 hour later I went to check and it was no longer working- no power at all. There is water at the bottom inside but I can't make it drain. This happened once before and the technician people gave me a way to restart the dishwasher by pressing certain buttons - I can't remember which ones. Does anyone know??? I need help!!
  • rlmanderson Dec 27, 2007
    I already did the breaker thing . . . it didn't work. Does anyone know anything about panels? Maybe mine is out???
  • 833 Answers
I don't know about a button sequence but I would suggest that you turn off your breaker and then back on. That will reset most electronics.
Posted on Dec 26, 2007
Dishwasher took 3 hours to complete cycle
If you have set the unit to heated water or your hot water is not hot will delay the wash cycle. The heater in the dishwasher is very slow!
The following is from the user manual.
15
TROUBLESHOOTING
First try the solutions suggested here and possibly avoid
the cost of a service call...
Dishwasher is not operating properly
Dishwasher does not run or stops during a cycle
Is the door closed tightly and latched?
Is the right cycle selected? Refer to the "Cycle Selection
Charts."
Is there power to the dishwasher? Has a household fuse
blown or circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shut-off valve (if installed) turned on?
Dishwasher will not fill
Is the overfill protection float able to move up and down
freely? Press down to release.
Dishwasher seems to run too long
Is the water supplied to the dishwasher hot enough? The
dishwasher runs longer while heating water. Refer to the
"Dishwasher Efficiency Tips" section.
A delay automatically occurs in some wash and rinse cycles
until the water reaches the proper temperatur
Hope this helps?
http://www.repairclinic.com/UserManual/f75a81f2957b4b86b396c8c3629d9078/8531130/Use-Care-Guides-Owners-Manual/Use-and-Care-Guide-8531130
Oct 16, 2016 | KitchenAid Dishwashers
Frigidaire FDB520RHB Dishwashers : We bought this dishwasher about 3 months ago. Today I ran the washer before I left to do errands and when I returned, I believe the washer had finished its cycle. But...
Try to run the dishwasher on a short cycle like rinse and see if it finishes the cycle.
It is likely the heater or hot water temperature is not reaching the desired level and this could cause the extended wash cycle. Feel water temperature inside dishwasher after some time. If cold then it is the heater not working. Perhaps try without Heat Dry Cycle. That will also extend the cycle if heater is not working well.
see cycle diagrams in the page 2 of this sheet. Gives you and idea how Heater Delay affects cycle times.
Apr 21, 2013 | Dishwashers
Fridgedaire dishwasher will not start a cycle. The green "clean: light stays lighted up and it will not reset the system. I have to turn off the breaker and then turn it back on. then the...
Hello
Ensure the Frigidaire dishwashing machine is fully connected to a power supply. Shut the dishwasher door firmly and select a wash cycle. Press "Start" to begin. Check that the "delay start" option was not selected.
  • 2 Verify that dishwashing detergent is placed in the dispenser and choose a longer washing cycle for heavily soiled items. Do not overload the dishwasher, as this may prevent proper cleaning.
  • 3 Check the household water pressure, which should be between 20 and 120 PSI (pounds per square inch). A water pressure gauge can be obtained at most home repair stores or hardware stores.
  • 4 Turn on the hot water at the sink closest to the dishwasher prior to starting the dishwasher to raise the water temperature inside the dishwasher. Check the hot water temperature, which should be at least 120 degrees Fahrenheit for proper cleaning.
  • 5 Check the spray arms in the dishwasher and move dishes that may be blocking the water spray or preventing the spray arms from rotating properly.
  • Read more: Frigidaire Dishwasher Wash Cycle is Not Working ' eHow.com http://www.ehow.com/how_7877923_frigidaire-wash-cycle-not-working.html#ixzz1Xow3qbbv
    Sep 13, 2011 | Dishwashers
    The dishwasher runs for 1 1/2 hours on the wash cycle.
    This may sound strange but that is a normal cycle time for today's dishwashers. They use much less water and the water is 'recycled' within the filtration system in the pump.
    By reusing and filtering this water they save on heating energy and water consumption. The motors are not as powerful so they use less power even when running longer. Many machines will alternate the wash between the upper and lower arms, this type uses much less water and energy but again the trade off is long cycle times.
    If you were to select a heavy or pots and pan cycle with hi temperature wash and a sani rinse your times can be up to 4 hours in some machines today.
    The reason behind these savings are mostly due to the energy standards that the appliance manufactures have to abide by today.
    I know this may not have been what you wanted to hear but it is how they work today.
    May 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
    Opened door on cycle, will not continue cycle after closing door
    The most common problem for a dishwasher to not restart after the door being closed is a failed door latch interlock switch. Adjusting / repairing it is not too difficult.
    Of course this assumes that the Dishwasher power circuit from the circuit breaker remains powered up.
    Post back here if you are looking for more details.
    Good Luck!
    Apr 16, 2009 | Bosch 24 in. SMU40 Built-in Dishwasher
    Dishwashwer won't start and can't reset to restart
    Check the float. (dome shaped thing inside the washer) Mine was stuck but as soon as I lifted up on it and then reseated it I was able to return to normal. Almost too easy. Saved $!
    Apr 15, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
    LG LDF6810ST Stainless Built In Dishwasher
    It is very common that high eficiency, low water using dishwashers take longer to finish all cycles. The best way to "hurry" the washing is to make sure that the water heater is providing hot water of at least 120 degrees. But no hotter then 140 degrees.
    If the dishwasher runs even longer, check to see is the dishwasher is actually connected to the cold water line. This dishwasher can be run from cold water but the water heating phase in the cycles will add much time ti the entire cycle.
    This unit has a sensor that detects the detects the water clarity towards the end of the wash cycle. Rinsing the dishes may speed the load a little, but encourage not to go crazy on the rinsing because the dishwasher actually counts on the food particles to help clean the dishes.
    Also, note that the final (third) blinking light means drying. You can simply open the door anytime after the final draining and power off the dishwasher, allowing the hot dishes to air dry.
    Hope this helps. Please resply with your findings. Thanks!
    Sep 16, 2008 | LG LDF6810ST Stainless Steel Built-in...
    Kenmore 15129 Built-in Dishwasher Logo
    93 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    Fred Sops
    vince
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
