Question about Onkyo TX-SR605 Receiver
Set-up problem with sound and speakers
I have a Sky HD and a Toshiba HD-EP35. I have connected both units by HDMI and recieve video fine. When trying to run through the set-up for the speakers (I have 5 + woofer) using the automatic sound detection mic, it get to the first speaker and tells me (speaker not detected). I can hear sound but only when I turn the receiver up to a high volume. i have checked all the speaker connections.
  • 1 more comment
  • deshanoop Dec 31, 2007
    I cannot get my HDMI output to go via the receiver. It works fine while going directly to the TV but i do not get any signal while routing through the receiver. Is there a setting in the Onkyo receiver which needs to be changed?
    Please help!
    Thanks
  • Zenist Jan 03, 2008
    I have the same problem for speaker automatic setting. The first time I was using the TX-SR605, I don't have any speaker yet. The receiver is used fine with HDMI Video and Audio input/output from blu-ray and to the TV. Yesterday I just got my 5.1 speaker system, as I plugged in the setup mic, it runs the Automatic setup directly. I can hear the sound from left front speaker, three times with higher volume each time. But the receiver always say" Ambient too noise" (we are not making any noise). And I cannot quit Automatic setting even I unplugged the setup mic. The only way is to plug in a headphone, then I can watch the TV from DVD again. What's the problem? Can someone help?
  • jeffpheff Jan 06, 2008
    The automatic speaker setup can not detect the left surround back speaker and the subwoofer speaker. I checked the wiring, switched the left surround back speaker and the right surround back speakers and still the same result. I swtiched the wiring for the left and right surround back speakers and still got the same results. I retried the automatic speaker setup serveral times and got the same results.
    What is the problem?
    Sincerely
    Jeff Phefferkorn
I sent this TX-SR605 system to an authorized dealer for repair. It seems like it is a very simply problem - the internal set-up mic jacket closed circuit, so the system think the set-up mic is always plugged in (even when physically unplugged it, the system still detect plugged in). And it enters the automatic speaker setup and never quit.
Now I have the receiver back home and tested it. Everything worked O.K. now. It is a pity that this new-bought equipment (just one month) need repair for just a small action of plug in a mic ( I swear I plugged it in very tenderly). It is shame for such a unreliable performance happened on brand name like ONKYO. How can you be confident for an equipment failure in one month.
Posted on Jan 07, 2008
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
Got sky installed today only thing getting on screen is "no video signal"
Sounds like the "channel" you are trying to watch on is not the one it's plugged into, or a faulty lead.
check the connection from the sky box to the tv, and select the av or hdmi channel that it is plugged into on the tv.
check the lead by swapping it for a known good one, for example from a dvd or ps3, but unplug from the dvd/ps3 and plug into the sky box(make sure that all the units are powered off when swapping leads) and try on the channel you normally watch/use the dvd/ps3.
If you suspect the sky is at fault, press menu on the sky remote and then flick through all the av/hdmi channels until you find the menu, then try to reinstall/retune the sky box.
If that don't work phone sky......................
Dec 30, 2009 | Toshiba 32HLC56 32 in. HD-Ready LCD...
XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
Mar 09, 2009 | Yamaha HTR-6130 Receiver
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
Yamaha DSPAX761 no s-video to HDMI
S-Video and Composite are analogue and HDMI is digital. Your receiver dose not have the capability to convert from analogue to digital and hence you are not not getting any video.
Feb 28, 2008 | Televison & Video
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Display on but no sound from any input
I have a similar problem. I connected a Toshiba HD-a2 dvd player and cannot get digital audio from any of the hd movies. Regular dvd's play just fine. Toshiba told me the receiver is to old and can't process the new format. I was wondering if there is an upgrade for the receiver or any other way I can get 5.1 out of this receiver with out having to get a new one..
Dec 29, 2007 | Denon AVR-1700 Receiver
Toshiba HD-A30 won't play digital sound with HD DVDs
Try checking your audio output in the setup screen of dvd player. Try setting Digital Out HDMI to Auto, if it isn't already. See if that helps.
Dec 28, 2007 | Toshiba HD-A30 HD-DVD Player
Onkyo TX-SR605 Receiver Logo
265 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
