Sony Cyber-shot  DSC-S700 Digital Camera
Problem for Sony Cyber-shot DSC-S700 Digital Camera
Flash wont work
By chant01234 on Oct 09, 2009
flash wont work, settings are on for flash, and the multiburst is switched off.
Clarification Request
Posted by miteshanand on Oct 11, 2009
Please note that: 1. You can not use the Flash when the Camera is set to Burst or Multi Burst mode. 2. You can not use the Flash when the ISO or Twilight mode is selected in the Scene Selection. 3. You can not use the Flash when mode dial is set to Movie. 4. Ensure that the battery is fully charged and the flash is turned ON. Please set the Landscape mode or Snow mode or Beach mode in the Scene Selection and check if the flash is working. 5. Try initializing the Camera and check if it works normally. NOTE: Initializing the Camera will reset the settings of the Camera to the factory settings including date and time. It will not delete any data saved in the Camera. 6. Please press the Menu button on the Camera. Then, select the SETUP menu and select the SETUP 1 option of the Camera. Then, select the Initialize option to OK. 7. Try to power reset the Camera and check if it helps to resolve the issue. I suggest that you reset the Camera by removing the battery from the Camera and inserting it after 1 minute. 8. If the issue still persists then the Camera requires service. Good Luck!!!!!!!
Solution #1
posted on Oct 11, 2009
Not Rated)
miteshanand
Rank: Guru  Sony Expert
Rating: 90%, 238 votes
Please note that:
Good Luck!!!!!!!
Was this helpful?
Yes
No
Popular Solutions for Sony Cyber-shot DSC-S700
Questions and Unsolved Problems for Sony Cyber-shot DSC-S700
Do you recommend Sony Cyber-shot DSC-S700 Digital Camera?
Answer
Answer
Sony Cyber-ShotD SC-S700 will not focus, orange light above the lens does not come on. can it be... (More)
Answer
preview screen is mostly white, I can not properly see to line up shots or review photos. pictures... (More)
Answer
my camira is sony dsc-700 but when i turned on evrey thing is darck and i don't know how i reformat... (More)
Answer
I have the cybershot DSC-S700. It has the date and time built in to the camera but I can't seem to... (More)
Answer
how do I transfer images from internal memory to memory stick
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Cyber-shot DSC-S700...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 400
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
