Microsoft Xbox 360 Console Logo
Posted on Oct 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have the sound but cant get the picture on screen,is this a common problem?
Terry Herrera
Level 2:
Scholar:
  • Expert 109 Answers
  • Posted on Oct 09, 2009
Terry Herrera
Expert
Level 2:
Scholar:
Answers
109
Questions
0
Helped
36080
Points
323
It may be really simple. check at the sweetch at the end of the video cable, the end that connects to xbox. it has a sweetch for standar quiality and dh quality (standar you will use only 3 cables, hd you will use 5 cables)
if you are using 3 cables (yellow, red, white)
you may have the sweetch on HD you will Hear sound but not video
if you are using the 5 HD connector (red, white, red, green, blue)
and you sweetch is on standar you will have sound but not picture :)
i hope this solve your problem
remember if i help rate me.
thank you
Black screen with sound no picture
Hello
You haven't either given its Brand name or its Model number. Anyway, as it is an LCD TV, this is common fault to all brands. Check its backlight CCFL tubes, and the backlight inverter board.
Actually there is picture, but you cant see it as there is no backlight. OK.
It was perfectly working I just turn it off for 2hrs. when I turn it on no picture . But the sound is good. I cant even bring up the menu on the screen
Turn off the lights in the room and turn your tv on.
If the tv screen is completely dark, and does not have that normal tv glow even without a picture, then it is likely a BACKLIGHT problem.
Shine a flashlight very close to the screen and you may be able to glimpse the tv picture playing very dimly on the screen.
Most likely you have some BULGING / LEAKING ELECTROLYTIC CAPACITORS (BAD) on your power supply circuit board, which are not overly difficult to replace yourself if you are the least bit handy with a screwdriver and soldering iron.
Another common defect is blown SURFACE MOUNTED FUSES on the inverter circuit board which can be checked with a multimeter.
Another less common problem is the backlight bulb itself may be bad which unfortunately is more difficult to replace yourself.
If you don't want to investigate / work on it yourself, then you will have to bring it in to the shop. They will probably be able to fix it for less than $150.
Good luck and keep us posted.
1helpful
Intellesence cant correct wavy color ghosted images on my screen. attempted to manually adjust and line up the colors blue will adjust but red will not.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Cant adjust the color on the tv
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
The picture is in 3d and i cant turn it off?
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
The array will not adjust . One day it just changed and now we cant realign it
These sets have several common problems which are listed below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
Picture is bowed and colors are off, cant read headlines
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Problem with Mitsubishi WS-65315 65 in picture simply off the screen. too big for the screen so u cant see 15% of all picture. on any input source like cable, dvd, components.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV2_bing.gif may have one or more of the following symptoms....
AV-56WP30 not allowing me to access convergence menu
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Pip screen and tv screen wont produce a picture at the same time
Order a new TV....thats what I have to do. I have the Protron 42", and I cant get any sound, and I cant get the remote to work. Figures, too.....the TV JUST passed its warranty period by 4 days! I havent seen any positive things said about this company, either.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
