Home | Epson | Stylus Photo R2400 InkJet Printer | My epson r2400, On pow...
Epson Stylus Photo R2400 InkJet Printer
Problem for Epson Stylus Photo R2400 InkJet Printer
My epson r2400, On power
By richard_c617 on Oct 09, 2009
My epson r2400, On power up the printer goes through it start up sequence then after about 2 mins the carridge stops on the left hand side of its track and all the lights go out. the printer haed seem to be in good condition, and the inks are new, Any ideas Thanks
Comments:
Oct 09, 2009
- Thanks for the reply, The carrier is clean and moves around its travel with ease,
Regards
Rich
Oct 09, 2009
- My epson r2400, On power up the printer goes through it start up sequence then after about 2 mins the carridge stops on the left hand side of its track and all the lights go out. the printer haed seem to be in good condition, and the inks are new, Any ideas Thanks
Oct 09, 2009
- Cheers for the reply,
I have done all the obvious re-installing software trying new ink cartridges, the printer does recognise the fact that I have removed them prior to reinstallation cartridge light indicators all light up, the ribbon cables seem in good and clean condition along with belts etc. Just seem to be at a loss or is the printer getting close to retirement,
Please advise,
Regards
Rich
Oct 09, 2009
- Apologies however as I said the obvious has been checked I believe that the problem lies within the printers software is there a way of totally resetting the printer back to default and totally rebooting the printer.
Cheers
Rich
Oct 09, 2009
- No really apologies I did not mean any negative response to you I appreciate your help in this matter. Is just a frustrating issue, I know you said that its not an expensive printer but £500 is a lot to me,
Sorry for misunderstanding.
Rich
Solution #1
posted on Oct 09, 2009
Somewhat Helpful)
krishmaqvan
Rank: Guru  Computer Hardware  Expert
Rating: 86%, 184 votes
Check that your printer head is not jammed or move freely.
For that put oil in head carrier .
Also clean dust from head contact with carrier .
Let me know if you need more assistance.
Thanks.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
ginko
Rank: Guru  Epson Computer Hardware  Expert
Rating: 89%, 5024 votes
If the printer is turning off completely, then the printer is faulty.
Try a basic troubleshooting by replacing cartridges, and power cycling the printer.
You should also try reinstalling software , that may not fix the problem , but will exclude driver software as possible cause.
The only basic maintenance you can do on hardware is cleaning the encoder strip. The encoder strip is the plastic strip located near to the traction belt. This part determines the position of the carriage, when it is dirty or faulty you can get the problem you described.
Also, after removing cartridge turn printer upside down and shake it gently to find foreign objects stuck inside the printer.
Often this kind of problems are caused by faulty parts, like return motor , encoder strip or traction belt or an internal fault like a short or a lose connector. The printer will park the heads on one side because it detects it cannot work.
Comments:
Oct 09, 2009
- If it is shutting down completely, then there is a fault. The fault can be a bad contact, or a mechanical problem. When printer shuts down it is not just mechanical, some electric or electronic problem is there.
As I said you can try general troubleshooting, and have a look inside the printer for contacts or lose connector. You can also check traction belt, encoder strip or ink carriage contacts. If you are lucky you can spot a fault like a broken encoder strip, a foreign object, or a bad connector to ink carriage contacts.
If there is nothing at a glance, this printer is not an expensive model, and may be not worth repairing. In that case replacement may be the best option.
Oct 09, 2009
- Software is fixed reinstalling drivers.
I fix printers, and I have never seen a printer shutting down (no light) because of an incorrect driver.
Reinstall drivers from Epson website, disconnect and reconnect power cord. This printer has no nvram, and those operation reset software completely.
I am pretty sure that this won't work.
Printer is almost 100% faulty, if all proposed did not work , replace it.
After voting negatively I will be excluded from your problem. For the future, you are not using Fixya in the right way, when you rate solution you either exclude expert or close the problem.
Bye and good luck.
Was this helpful?
Yes
No
Solution #3
posted on Nov 08, 2009
Not Helpful)
hughkoester
Rank: Apprentice  Computer Hardware  Expert
Rating: 40%, 1 votes
I just installed a CIS. When the printer is turned on,the carrier that holds the ink cartridges moves left and right a few times. Then the carrier and the chrome bar drop down and the belt makes a lot of noise and the carrier does not move at all. ..then the system shuts off. I removed the CIS and installed the original cartridges but have the same problem. The belt makes a lot of noise until it shuts down.
Thanks for your help.
Was this helpful?
Yes
No
Popular Solutions for Epson Stylus Photo R2400
Questions and Unsolved Problems for Epson Stylus Photo R2400
Do you recommend Epson Stylus Photo R2400 InkJet Printer?
Answer
Answer
Lexmark P700 (Vista) says printer ready but does not print
Answer
Why does the ink cartridge light remain on after I have changed cartridges?
Answer
My printer, Epson R2400, says it is ready but does not print, I am running Snow Leopard
Answer
I am a teacher. Printer #1 stopped accepting paper...no matter what size. It would make two quick... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Epson Stylus Photo R2400...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
