Hi my name is Roety,
I can help you with your issue ,
Very difficult to troubleshoot, you can check a few things,
look for swollen capacitors.
If the lamps light for a second and go off you may have a bad panel
CCFL lamp (part of the panel)
If I have helped you with your issue please click accept.
If you have more questions you can still respond
I will reply asap
Thanks
When the tv is on it will lose picture and sound, the green power light stays on and will not shut...
(More)
When the tv is on it will lose picture and sound, the green power light stays on and will not shut off with power button. I have to unplug the power cord to turn it off. Sometimes when it is pluged back in works fine other times the green light comes on automatically and has the same problem.
hello we have a 32 inch Hyundai. and latley when we turn the tv on we get colored lines has to...
(More)
hello we have a 32 inch Hyundai. and latley when we turn the tv on we get colored lines has to sometimes leave it on for.about 10 mins then we have to turn it off and we might get lucky and be albe to watch tv . by the way its about 3 years old
what cable do i need to connect to an av amplifier,if it is an optical lead what are the...
(More)
what cable do i need to connect to an av amplifier,if it is an optical lead what are the connections?
