Question about Intel D845GVSRL 533MHz FSB 845GV Chipset DDR333 Socket 478 microATX Motherboard with Vid... (MB47IN5GVSRL)
Installing new powersupply
I posted this problem once, and was directed to a diagram. it was most helpful, but wrong mother board. http://emachines.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T2742 is the specs of my system. the power supply number is ayx-250gu. 3 chords are left, and are as follows power led, hdd led, and pwr s/w. if you know of any manuals, or diagrams, it would be most helpful.. merry christmas guys, and God bless
    Master:
    Sergeant:
  • 482 Answers
What is your problem? the wires go up and go on 2 wires sticking up they should have something below them that match, you may not need all of them hooked up. the power you need, tri hooking them up and turn the computer off and on each time till you find out where the go.
Posted on Dec 25, 2007
Replaced powersupply managed to unplug all three connectors at bottom of motherboard labeled front sw, HDD led, and pwr led. need manual or diagram to reconnect
If you look closely at the mother board, the connectors should be labeled. It will be in small white lettering.
Example:
Mar 06, 2011 | Computers & Internet
Front panel motherboard samsung harappa-30 PBA:BA59-00905A
i wont to sound drivers for polaris motherbrod
Jun 12, 2009 | Computers & Internet
Motherboad processor getting hot,new fan change,powersupply change & ram change but its still too hot plz what that problem u can tel me
install orinal fan of intel or cpucoolar .............and check your prosser is cool ...ok and all problem in mother board in prosser panal .................
Mar 19, 2009 | Gigabyte GA-K8NXP-SLI Motherboard
New builded pc wont install, system is schut down.
Hi Henrick,
Are you using the correct spec R.A.M.? or is it faulty.
I relate to your problem and all looks fine apart from memory.
Don't rule out the possibility of a Mother Board fault? I have had similar& severe grief in the past, tried all routes and replaced loads only to find sata circuit connection dry joint/ un soldered. (So New Motherboard under warranty)
Good Luck!
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Jan 14, 2009 | Ultra Products Ultra Defender Intel Gaming...
Brand new coolmax cug-950b power supply. everything appears to be hooked up correctly, but it wont power up the mother board
the best thing when you can't see power going through your computer is
1. check the obvious once again (the current setting in the back of the ps.. is it 115??
2. replace the powersupply for known good powersupply.. if it works, your powersupply is defective (likely) if it doesn't your motherboard (unlikely), your memory (likely) or your cpu (unlikely) maybe the one defective.
Sep 26, 2008 | Computers & Internet
No External Speaker Sound
Hi jdnimrod,
This is not you're first post about the Foxconn mother board.
You have an issue with the PS2 keyboard as well. This Foxconn model ( 761GXK8 you listed ), is not 100% correct.
Please check this link:
http://www.foxconnchannel.com/EN-US/searcher.aspx?key=761GXK8
Find which is you're board.
Than post back into this answer.
It is important you run the exact CPU that is compatible with the mother board.
Foxconn's Compatibility chart for MB to CPU.
761GXK8MB-ERS/EKRS
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200606271133082354761GXK8MB.htm
761GXK8MC-RS MB Compatibility chart:
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200603210922432734761GXK8MC-RS.htm
761GXK8MB-KRS MB Compatibility chart:
http://www.foxconnchannel.com/EN-US/Upload/Compatibility/200606300744394666200606271143263290761GXK8MB[1].htm
I'll help you further once I know the correct mother board.
Mike
Aug 08, 2008 | Foxconn 761GXK8MBRS AMD Athlon 64/Athlon...
Intel 845 chipset mother board no reaction - expecting solution
this is normal No-Ram. No-Beep.
The ram is all part of the bios analysis beep codes.
install memory, and setup the board to the manufacturers specification.
1 beep at post is normal on many bioses.
Mike @ compurepair.
Feb 22, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Mother Board problem
Are there any beep/s sound that you can hear when you try to Boot your desktop? If there are none then do some check the following: 1. Please check if you have properly connected the connectors for ATX 20 pins powersupply and for ATX 12V Power Connectors. 2. Press the POWER Button to turn ON your Desktop and Check if the Powersupply FAN is spinning to ensure that there is Electricity power for your Powersupply BOX. Then press (approximately 5 secs) the Power Button if Turn Off again. If its shutdown then your motherboard is OK. But when you press the Power Button and you hear a sound like a BOAT's Horn/Fogging sound then your Power Supply is not sufficient to provide power to your Desktop or CPU.. 3. If you got 2 or more memory Cards installed in your motherboard then try to install those Memories one at a time. To determine if one of those card is defective..
Apr 08, 2007 | ASUS P5ND2-SLI Deluxe Motherboard
Computers & Internet Logo
105 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
