Question about Jabra BT350 Bluetooth Headset Headset
My bt350 will not trun on
It worked fine for about six months then i went to turn it on and then nothing help!
  • jabra Dec 26, 2007
    i also have the same problem. it is turning on.it is charged fully.
  • unruly6 Jan 09, 2008
    my bluetooth was working then it stoped, my phone can't recognize the passkey. it is vbt185z jabra. please help
I just had the same problem. I have the bt350. The phone would find the headset, but wouldn't pair with the code. I tried numerous things, from reconnecting it to a power source (to make sure I disconnected it gracefully) to checking the visibility, etc. It finally worked perfectly after I turned the phone off. Sometimes, a reboot is all you need. Good luck.
Posted on Feb 13, 2008
Ryobi drill seized
Take it back to the supplier as it will be under warranty
Aug 15, 2017 | Ryobi Drills
I have a mitsubishi ws-65313 projection tv i was waching it and went black now its not working the green light is on but tv isnt working and i try to turn it off and the ligth still on i push the botton...
Hi. i believe this to be either of these three problems.
1. Power: it could be that there is a problem with the power electronic element(s). the solution is to go see an engineer.
2. Screen: if the television uses LCD display, it could be a problem with the liquid in it. Solution is to see an engineer.
3. Sleep mode: the TV could be in sleep mode which makes the screen go blank until removed from sleep mode. Solution is to read the TV's users manual to see how to wake a sleeping TV. Get back.
Jul 15, 2011 | Mitsubishi Televison & Video
Zebra Printer LP 2844 not feeding
Thanks for the response. It turned out to be a faulty power supply which did not send enough power to turn the printer. now it works like a champ
Apr 06, 2009 | Zebra LP 2844 Thermal Printer
It's connected fine, now it won't connect, what's up? Jabra BT350
Delete the problem unit off the phone's list then turn the phone off then back on. Next you will have to go through the pairing procedure for the headset again.
Mar 24, 2009 | Jabra BT350 Bluetooth Headset Headset
Garmin NUVI 200w
the same issue with mine, but mine cut out after one day. Purchased 6-9-08
Jun 09, 2008 | Garmin nuvi 200W GPS Receiver
BT350
try turning bluetooth off . first erase bluetooth connections on phone. turn off phone and take out phone's battery for ten seconds. put battery back in and turn on phone. plug bluetooth into charger for ten seconds and unplug it. try re-pairing bluetooth with phone. This worked for me!
Mar 06, 2008 | Jabra BT350 Wireless Headset
Jabra BT 350 has stopped connecting
Hey everyone! I had the same problem, and I actually got it to work again! I hope these directions will help you get yours to work (from the manual):
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on. <== THIS IS VERY IMPORTANT! HOLD THE BUTTON UNTIL YOU SEE A SOLID NON-BLINKING LIGHT! (This is where I was going wrong with the directions.)
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
Nov 30, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 Bluetooth Headset Headset Logo
81 people viewed this question
Top Jabra Radio Communications Experts
Greg Cann
Greg Cann
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
