Question about Hotpoint RGB745 Gas Kitchen Range
How to clean an oil spill
I have a hotpoint RGB745 gas kitchen oven.
We had a grease fire inside the oven that I extinguished with a fire extingusher. This sloshed a lot of oil, grease and depree down through the 4 slots in the bottom pan. I need to clean this out. How do I remove the bottom (inside the oven) so I can clean this.
Thank you
  • Anubis123 Dec 25, 2007
    I have a Hotpoint RGB745 Gas Kitchen Range.
    We had a fire inside the oven that I put out using a fire extinguisher. Oil, grease and debree flowed through the 4 slits in the bottom pan and needs to be cleaned before the oven can be used.
    Can anyone tell me how to remove the bottom pan inside the oven?
    Thank you
    Thanks for the reply but I need to know how to remove the bottom pan (inside the oven). Oil sloshed down the 4 vents and remains there. I've cleaned inside the oven but need to get underneath the bottom pan (Not the storage area for pots and pans) but under the oil pan inside the oven
    Thank you
All of you are MORONS. the guy is asking "quite clearly", how to remove the bottom pan so he can clean under it. It's quite obviouse he understands how to clean the the main part of the oven. He just want to know HOW TO REMOVE THE BOTTOM PAN.......
Posted on May 08, 2008
    New Friend:
There are two light metal tips that stand out at the back of the oven. Lightly slide those tips forward and then you should be able to gently lift up the corners and pull the bottom pan out to clean.
Posted on Aug 19, 2014
"Debree" is spelt D-E-B-R-I-S
Debris.
How do you remove the bottom PAN!!!
Posted on Jan 21, 2008
    Problem Solver:
  • 9 Answers
Hi clean w/ oven cleaner , scrape w/ gently remove first the thick mist and applied w/ oven cleaner , clean w/ oil absorbent rug. then assemble it.
Posted on Dec 25, 2007
How to fix gas oven that has been extinguished by an ABC fire extinguisher?
Entire oven inside will have to be dismantled, and individual parts cleaned with a soapy solution and rinsed and dried thoroughly
.Show your appreciation by pressing the helpful button and follow me on fixya for more info and tips.
Feb 17, 2016 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Cleaned my electric hotpoint oven now it wont go on bake
If after cleaning your Hotpoint oven and know it will not work. Ckeck you Hi Limit fuse. Very common problem after a self clean.http://www.on-timeappliance.com/ovenrepair.html
Mar 27, 2012 | Hotpoint RGB745 Gas Kitchen Range
The oven won't come on. turn the oven on and there is no fire coming on underneath
Is this a current connection with gas service in other parts of the home that are working?
If the gas service is working in other parts of the home, check to see if there is a turn off valve where the gas connects to the oven.
Mar 07, 2011 | Hotpoint RGB745 Gas Kitchen Range
RGB745 Gas oven does not lock so i can not self clean. any help will be appreciated. Thanks, Jim
Before you go and run the self clean.. Check out this tip...
There are many problems caused by that feature...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Mar 30, 2010 | Hotpoint RGB745 Gas Kitchen Range
Fire in oven. Fire Department had to force door
no,you need a new range or a new oven door depending on how bad the fire in the oven was.
Jan 28, 2010 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
1,073 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
