You need to set the IP address correctly in the Network Settings.. Make sure it corresponds with the routers IP address and is on the same Network... what I mean by this is .. the gateway should be 192.168.1.1 or similar the printer should be 192.168.1.10 or in that fashion... the 1 after the 168 is the network and the last number of 10 or what ever is the number the device is on the network.. sort of like a home address on a city street.. sounds like you need a person there that knows how to set this up properly... to connect it to the router and configure it properly... Look up a Geek!
I try to fax and the transmission verification report say in the resulot line says busy and then...
(More)
I try to fax and the transmission verification report say in the resulot line says busy and then on the bottom of box it says busy: busy/ No response
I have one line for my fax and phone and I would like to put two different rings tones on the...
(More)
I have one line for my fax and phone and I would like to put two different rings tones on the machine so I can tell which one is a fax and which one is the phone line. Pleas Help, Belinda
