Question about iRiver H10 MP3 Player
UMS I have trouble switching my iriver h10 5GB into UMS mode. I tried holding O but it didnt work. Anyone show me another way ?
  • Badbasil Dec 30, 2007
    Having an identical problem with 6 GB version. Player will not stay in emergency mode after the message has been displayed. Have tried switching on both before and after connecting to PC
    Problem Solver:
  • 14 Answers
If what Mpiper recommended still doesn't work, try removing the battery for a few seconds. This resets the unit. Then follow mpiper's steps for connecting in the UMS mode.
Posted on Oct 29, 2009
  • 4 Answers
Try plugging it in to the computer first while the device is off. Then, hold the O key and press the power button. Worked for me.
Posted on Dec 26, 2007
Where can I get the driver and music manager for my IFP-799 ?
iRiver IFP-799 is a IFP-700 series player.
Making transfers to the device can be done in either UMS or Manager mode.
UMS firmware matches with seeing the player as a removable disk in Windows Explorer and is also used for updating firmware, using iRiver PLUS software.
Manager firmware matches with iRiver Music Manager software.
When needing the Music Manager go to next site and enter the word
manager in the second column next to GO:
http://www.iriver.com/flash/index.asp?code=0302
iriver music manager ( Ver. 3.21 ) shows up: click the item and read
the instructions for download and installation.
How to update the player's firmware
in MSC mode:
http://www.iriver.com/flash/popup/flash_pop.asp?board=faq&code=47
in Manager mode:
http://www.iriver.com/flash/popup/flash_pop.asp?board=faq&code=252
Need more help ? Just post a comment.
Dec 25, 2009 | iRiver iFP-799 MP3 Player
I River for Mac
I have an iRiver H10 5gb. In order to use it with the Mac, I have to connect it while in UMS mode. This basically turns the unit into an external drive.
To do this you need to first remove your battery to reset the unit.
While the unit is off, connect it to your computer. Hold down the 'o' key while turning the unit on. Holding both buttons down until you see "USB Busy Do not disconnect". Now you can release the buttons, you are in UMS mode. Now just drag and drop your files onto the player.
If you don't mind not being able to use some of the iRiver features, once you drag and drop the music files, you disconnect in the usual way and then play your music files from the browser on your iRiver.
(Unless you add the files using Window Media player or iRiver's Music Manager, you won't be able to access the files in any other way. )
Here are some of the programs/software/firmware that are supposed to help load files from the Mac onto the iRiver. One that most people seem to like is called the easyH10. I have also come across info to sync with iTunes. I have tried these, but because I am in UMS mode, they haven't worked.
Go to these websites and check it out.
http://easyh10.sourceforge.net/ http://www.misticriver.net/forums/h-10-h-20-series/34707-easyh10-mac-os-x.html
http://www.apple.com/itunes/
http://www.misticriver.net/wiki/index.php/H10_iTunes_sync_tutorial
http://ilari.scheinin.fidisk.fi/itunemywalkman/
Oct 16, 2009 | Audio Players & Recorders
I'm looking for for a driver for i-river MP3 IFP-790 and can't find anything right on the web. would appreciate it if someone could direct me to a download link, tnx
IFP-790 can be accessed in UMS and Manager mode:
UMS mode
For firmware upgrades iriver PLUS3 must be used.
Download iriver PLUS3 going to this site:
http://www.iriver.com/index.asp
Click Support on the left side.
Select Download in the second column.
Select "Download iriver PLUS3" in the page: allow download (when blocked / sometimes download has to be repeated).
The size of the iriver PLUS3 download is 59.3 MB.
iriver PLUS3 can also be used for music transfers in UMS mode.
Manager mode
For Manager type connection the iriver music manager must be downloaded and installed.
Go to the support site:
Select Support in the first column.
Enter the phrase 'music manager' and click GO:
download 'iriver music manager (Ver 3.21)' [ 28 MB].
Sep 29, 2009 | iRiver iFP-790 MP3 Player
I replaced the battery in my iriver h10 20g. System file missing
was your player set to ums mode before running updater? to put it in ums mode you have to reset player by removing battery then reinstall battery then connect it to your computer turn on player and at the same time hold the button down with the o on it then run the updatera program again
Mar 23, 2009 | iRiver H10 MP3 Player
Every time I turn on my iriver h10 it freezes on the artists and won't go anywhere. How do I fix this ? resetting doesn't help
not sure what's wrong but try this..
hook up your h10 via the ums trick...
The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Take out the battery, wait a second, and put the battery back in.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For 20 GB MTP Models
  • Poke the "reset" button with a paperclip.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are always in UMS mode!
download and run the free playlist maker software called EASYh10. It will scan the music files on the h10 music folder and save a new playlist to your player.
Mar 03, 2009 | iRiver H10 MP3 Player
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
Iriver h10 20gb not recognized in UMS
I sometimes have to reset my iRiver in order for my Mac to see it. I have an h10 5gb, to do this, I have to remove the battery then reconnect the battery. Then I connect it the usual way to get into the UMS mode. But I think with yours it has it's own reset button. If it was working and now has stopped, I would think you just need to reset it and try again.
Oct 10, 2008 | iRiver H10 MP3 Player
Coping files from iriver H10 20 GB to pc
The USM trick allows you totreat your H10 as an external hard drive. Then it is easy to copy the musicback to your PC using explorer.
The details for the USMtrick are taken from mistic river.
http://www.misticriver.net/wiki/index.php/H10_Tips_and_Tricks/UMS_Trick
H10 Tips and Tricks/UMSTrick
From iriver Wiki, yoursource for everything iriver - a part of MisticRiver.
Jump to:navigation, search
Most people agree that theUMS trick is a great thing to know how to do. With it, you can transfer music,OR treat your H10 as a harddrive to put anything you want on. The UMS trickwill also allow you to use your H10 with virtually any OS.
5/6 GB MTP Models
1. Make sure your H10 is turned off anddisconnected from the computer.
2. Take out the battery, wait a second, andput the battery back in.
3. Turn on the hold switch (so that youdon't accidentally turn the H10 on all the way).
4. Plug the H10 into your computer.
5. Turn on the H10 while holding the"O" button.
6. You will see the message "UMSMode" if you have done everything correctly. You can now let go of the"O" button.
20 GB MTP Models
2. Poke the "reset" button with apaperclip.
5.Turn on the H10 while holding the "O" button.
6. You will see the message "EmergencyConnection" if you have done everything correctly. You can now let go ofthe "O" button.
UMS Models
UMS models do not need thistrick because they are always in UMS mode!
Sep 01, 2008 | iRiver H10 MP3 Player
4.6GB Iriver H10 Merory says 2.9GB remaining but there is nothing on the player.
Considered formatting disk?
For you what this would mean is just a complete refresh of the device (you will lose everything).
You will need to read everything carefully.
Check this out
http://www.misticriver.net/boards/showthread.php?t=14853
I converted my H10 to the "UMS" mode mentioned in the site a long time back (so I could directly transfer files as a USB mass storage device) and had the issue mentioned in that post. Works great. Converting to UMS mode is done here http://www.misticriver.net/wiki/index.php/H10_Firmware_Conversion:_MTP/UMS
You will also need the iRiver Plus software that you can download for free here http://www.iriver.com.au/iriver/index.cfm?pageID=10001&
Feb 17, 2008 | iRiver H10 MP3 Player
IRIVER PLUS 3 MEDIA TRANSFER SCREEN
My understanding, as a new user, is that IRiver plus 3 only communicates with the player via UMS mode, which is not the default. Windows Explorer and Windows Media Player only communicate through MTP mode. If you change from MTP (the default) to UMS, it will reformat the player and delete all your files.
In other words, do not use iriver plus 3 unless that is the only software that you want to use. Boing back to MTP mode after a sync or download will then delete all THOSE files you just downloaded.
I just say NO to Plus 3.
Good luck.
Dec 30, 2007 | iRiver Clix Digital Media Player
iRiver H10 MP3 Player Logo
147 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
