Question about Toshiba Satellite A135 Notebook
Problems with Toshiba Satellite A135
We have only had our A135 for about 5 months and have random problems with it:
1) we close the monitor with the power still on and when we open the monitor back up we get a message along the lines of windows was not shut down properly and the option to start normal, in safe mode, etc...any ideas why the CPU would just shut down?
2) Sometimes we will boot our computer and the icons will be rearranged on the desktop, the system time/date will be changed. Ran virus, spyware software and found nothing.
Thank you for the suggestions
  • 55 Answers
It sounds like you need to adjust your setting when you close the lid. If you set it to do nothing when the lid closes that should sort out your problem. Often it won't let you adjust them so if you uninstall the power management and then do the adjustments in the power settings then you should be ok
Posted on Dec 25, 2007
Toshiba Windows 7 satellite pro. screen goes
Your laptop is damaged from the hinges which is a pretty common issue
The only solutions would be to:
1) plug in a monitor
2) buy a new laptop
Sep 08, 2013 | Toshiba Computers & Internet
Toshiba Satellite A505 - Most of the time when I turn it on the screen is grey, with no text.
This sounds like a bad display on the laptop. Hook up an external monitor to the vga port on the laptop. You may need to toggle the display to output to the external monitor. This is generally accomplished by pressing the "FN" key + one of the F# keys. Look for an icon that resembles a monitor or it may say LCD. If the graphics display correctly on the external monitor, then you will need to replace the computer screen.
Dec 29, 2012 | Toshiba Computers & Internet
Internet Explorer/Firefox stops responding
I had a few people who had problems similar to yours it needs a lot of work arounds.
1. Make sure your firwall or virus program does not interupt the IE. (try closing it for a while)
2. Put everything in IE in defaults.
3. Update the IE directly from the net
Feb 27, 2009 | Toshiba Satellite 1415-S105 Notebook
Toshiba satellite P15-S420 odd power & freezing problems
  1. Click Start and then Control Panel.
  2. If you're in Category view, click Performance and Maintenance.
  3. Then click on Power Options.
    If you're in Classic view, double-click on Power Options.
  4. Click the Hibernate tab.
  5. The Enable Hibernation box should be unchecked.
  6. Click Apply.
  7. Click the Power Schemes tab.
  8. In the Plugged in column, from System Standby option, set a time out period.
  9. Click Apply.
  10. You can adjust the Turn off monitor and Turn off hard disks settings as well.
  11. Click Apply. Click OK. Close the control panel.
This is what you should see
Please rate this a fixya
Feb 09, 2009 | Toshiba Satellite P15-S420 Notebook
Laptop monitor have vertical lines apearing out of nowhere...
LCD needs to be replaced.
Common problem called "Tab separation".
Jan 10, 2009 | Toshiba 14" LCD Monitor
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website ( & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite that randomly shuts off
may be hitting event of your laptop
also u can try to reset your bios.
go to your bios setting load default settings.
then restart pc.
Apr 01, 2008 | Toshiba Satellite 1805-S274 Notebook
Toshiba Satellite M30 Montior Blackout
have you tried changing the resolution, if not try this power on your laptop press F8 run in safe mode go to device manager an disable your display adapter after disabling reboot windows after rebooting go back to device manager enable display adapter and go display properties an change resolution.
Mar 15, 2008 | Toshiba Satellite M30 Notebook
Random screen freeze
You are going to need your WINDOWS CD:
Dec 03, 2007 | Toshiba Satellite M45-S265 Notebook
Screen problems
have you checked the cable between the base and monitor for a fault ie broken cable, lose conector as it sounds like a signal problem, common fault for alot of laptops with the screen being open and closed allot all my best ric
Oct 12, 2007 | Toshiba Satellite 1905-S277 Notebook
Toshiba Satellite A135 Notebook Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
